Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkLiveInsituLink Class Reference
link for live-coprocessing. More...
#include <vtkLiveInsituLink.h>
Inheritance diagram for vtkLiveInsituLink:
Collaboration diagram for vtkLiveInsituLink:
enum  NotificationTags { CONNECTED = 1200, NEXT_TIMESTEP_AVAILABLE = 1201, DISCONNECTED = 1202 }
bool Initialize ()
 Initializes the link. More...
bool Initialize (vtkSMSessionProxyManager *)
void InsituUpdate (double time, vtkIdType timeStep)
 Every time Insitu is ready to communicate with ParaView visualization engine call this method. More...
void InsituPostProcess (double time, vtkIdType timeStep)
 Every time Insitu is ready to push extracts to ParaView visualization engine, call this method. More...
void RegisterExtract (vtkTrivialProducer *producer, const char *groupname, const char *proxyname, int portnumber)
void UnRegisterExtract (vtkTrivialProducer *producer)
void OnInsituUpdate (double time, vtkIdType timeStep)
void OnInsituPostProcess (double time, vtkIdType timeStep)
void LiveChanged ()
 Signal a change on the ParaView Live side and transmit it to the Insitu side. More...
void UpdateInsituXMLState (const char *txt)
void InsituConnect (vtkMultiProcessController *proc0NodesController)
void DropLiveInsituConnection ()
 Called to drop the connection between Insitu and ParaView Live. More...
virtual void SetInsituPort (int)
 Set the port number. More...
virtual int GetInsituPort ()
virtual void SetHostname (const char *)
 Set the host name. More...
virtual char * GetHostname ()
virtual void SetProxyId (unsigned int)
 When instantiated on the ParaView visualization server side using a vtkSMProxy, ProxyId is used to identify the proxy corresponding to this instance. More...
virtual unsigned int GetProxyId ()
virtual int GetSimulationPaused ()
 'SimulationPaused' is set/reset on Paraview Live and sent to Insitu every time step. More...
void SetSimulationPaused (int paused)
int WaitForLiveChange ()
 is called on the catalyst side. More...
void OnLiveChanged ()
 Description: Called on INSITU side when LIVE has changed. More...
- Public Member Functions inherited from vtkSMObject
static vtkLiveInsituLink * New ()
static vtkLiveInsituLink * SafeDownCast (vtkObject *o)
static bool FilterXMLState (vtkPVXMLElement *xmlState)
 This method will remove references to proxy that shouldn't be shared with ParaView Return true if something has been removed. More...
static vtkSMObject * New ()
Protected Types
enum  RMITags {
  UPDATE_RMI_TAG = 8800, POSTPROCESS_RMI_TAG = 8801, INITIALIZE_CONNECTION = 8802, DROP_CAT2PV_CONNECTION = 8803,
  LIVE_CHANGED = 8804
 vtkLiveInsituLink ()
 ~vtkLiveInsituLink () override
void InitializeLive ()
 Called by Initialize() to initialize on a ParaView Live process. More...
bool InitializeInsitu ()
 Called by Initialize() to initialize on a Insitu process. More...
void OnConnectionCreatedEvent ()
 Callback on Visualization process when a simulation connects to it. More...
void OnConnectionClosedEvent (vtkObject *, unsigned long eventid, void *calldata)
 Callback on Visualization process when a connection dies during vtkNetworkAccessManager::ProcessEvents(). More...
 vtkSMObject ()
 ~vtkSMObject () override
char * Hostname
int InsituPort
int ProcessType
unsigned int ProxyId
bool InsituXMLStateChanged
bool ExtractsChanged
int SimulationPaused
char * InsituXMLState
vtkWeakPointer< vtkPVSessionBase > LiveSession
vtkSmartPointer< vtkMultiProcessController > Proc0NodesController
 The controller that communicates between the INSITU and the LIVE process 0 nodes. More...
vtkSmartPointer< vtkExtractsDeliveryHelper > ExtractsDeliveryHelper
enum  { LIVE = 0, INSITU = 1 }
 Set/Get the link type i.e. More...
virtual void SetProcessType (int)
virtual int GetProcessType ()
vtkLiveInsituLink manages the communication link between Insitu and Live visualization servers. vtkLiveInsituLink is created on both ends of the live-insitu channel i.e. in Insitu code (by instantiating vtkLiveInsituLink directly) and in the Live ParaView application (by using a proxy that instantiates the vtkLiveInsituLink).
Definition at line 42 of file vtkLiveInsituLink.h.
Definition at line 46 of file vtkLiveInsituLink.h.
◆ anonymous enum
anonymous enum
whether the current process is the visualization process or the insitu process.
Enumerator
LIVE
INSITU
Definition at line 71 of file vtkLiveInsituLink.h.
◆ NotificationTags
Enumerator
CONNECTED
DISCONNECTED
Definition at line 161 of file vtkLiveInsituLink.h.
◆ RMITags
Enumerator
UPDATE_RMI_TAG
POSTPROCESS_RMI_TAG
LIVE_CHANGED
Definition at line 189 of file vtkLiveInsituLink.h.
◆ vtkLiveInsituLink()
vtkLiveInsituLink::vtkLiveInsituLink ( )
◆ ~vtkLiveInsituLink()
vtkLiveInsituLink::~vtkLiveInsituLink ( )
static vtkLiveInsituLink* vtkLiveInsituLink::New ( )
virtual const char* vtkLiveInsituLink::GetClassName ( )
static int vtkLiveInsituLink::IsTypeOf ( const char *  type)
virtual int vtkLiveInsituLink::IsA ( const char *  type)
static vtkLiveInsituLink* vtkLiveInsituLink::SafeDownCast ( vtkObject *  o)
void vtkLiveInsituLink::PrintSelf ( ostream &  os,
◆ SetInsituPort()
virtual void vtkLiveInsituLink::SetInsituPort ( int  )
This is the port on which the root data-server node will open a server-socket to accept connections from VTK InSitu Library.
◆ GetInsituPort()
virtual int vtkLiveInsituLink::GetInsituPort ( )
◆ SetHostname()
virtual void vtkLiveInsituLink::SetHostname ( const char *  )
Set the host name.
◆ GetHostname()
virtual char* vtkLiveInsituLink::GetHostname ( )
Set the host name.
◆ SetProcessType()
virtual void vtkLiveInsituLink::SetProcessType ( int  )
◆ GetProcessType()
virtual int vtkLiveInsituLink::GetProcessType ( )
◆ SetProxyId()
virtual void vtkLiveInsituLink::SetProxyId ( unsigned  int)
That helps us construct notification messages that the visualization server can send to the client.
◆ GetProxyId()
virtual unsigned int vtkLiveInsituLink::GetProxyId ( )
◆ GetSimulationPaused()
virtual int vtkLiveInsituLink::GetSimulationPaused ( )
◆ SetSimulationPaused()
void vtkLiveInsituLink::SetSimulationPaused ( int  paused)
◆ Initialize() [1/2]
bool vtkLiveInsituLink::Initialize ( void  )
inline
For in situ this returns true it there is a connection and false otherwise. For live it always returns true.
Definition at line 104 of file vtkLiveInsituLink.h.
◆ Initialize() [2/2]
bool vtkLiveInsituLink::Initialize ( vtkSMSessionProxyManager *  )
◆ InsituUpdate()
void vtkLiveInsituLink::InsituUpdate ( double  time,
vtkIdType  timeStep
The goal of this call is too get the latest updates from ParaView including changes to state for the co-processing pipeline or changes in what extract the visualization engine is expecting. This method's primary goal is to obtain information from ParaView vis engine. If no active connection to ParaView visualization engine exists, this will make an attempt to connect to ParaView.
◆ InsituPostProcess()
void vtkLiveInsituLink::InsituPostProcess ( double  time,
vtkIdType  timeStep
If no active ParaView visualization engine connection exists (or the connection dies), then this method does nothing (besides some bookkeeping). Otherwise, this will push any extracts requested to the ParaView visualization engine.
◆ WaitForLiveChange()
int vtkLiveInsituLink::WaitForLiveChange ( )
Insitu stops until the pipeline is edited, an extract is added or removed or the user continues the simulation. Returns != 0 if the visualization side disconnected, 0 otherwise
◆ OnLiveChanged()
void vtkLiveInsituLink::OnLiveChanged ( )
◆ RegisterExtract()
void vtkLiveInsituLink::RegisterExtract ( vtkTrivialProducer *  producer,
const char *  groupname,
const char *  proxyname,
int  portnumber
◆ UnRegisterExtract()
void vtkLiveInsituLink::UnRegisterExtract ( vtkTrivialProducer *  producer)
◆ OnInsituUpdate()
void vtkLiveInsituLink::OnInsituUpdate ( double  time,
vtkIdType  timeStep
◆ OnInsituPostProcess()
void vtkLiveInsituLink::OnInsituPostProcess ( double  time,
vtkIdType  timeStep
◆ LiveChanged()
void vtkLiveInsituLink::LiveChanged ( )
This is called when the state or extracts are changed or when the simulation is continued.
◆ UpdateInsituXMLState()
void vtkLiveInsituLink::UpdateInsituXMLState ( const char *  txt)
◆ FilterXMLState()
static bool vtkLiveInsituLink::FilterXMLState ( vtkPVXMLElement *  xmlState)
◆ InsituConnect()
void vtkLiveInsituLink::InsituConnect ( vtkMultiProcessController *  proc0NodesController)
◆ DropLiveInsituConnection()
void vtkLiveInsituLink::DropLiveInsituConnection ( )
◆ InitializeLive()
void vtkLiveInsituLink::InitializeLive ( )
◆ InitializeInsitu()
bool vtkLiveInsituLink::InitializeInsitu ( )
Returns true if a connection is made.
◆ OnConnectionCreatedEvent()
void vtkLiveInsituLink::OnConnectionCreatedEvent ( )
◆ OnConnectionClosedEvent()
void vtkLiveInsituLink::OnConnectionClosedEvent ( vtkObject *  ,
void *  calldata
◆ Hostname
char* vtkLiveInsituLink::Hostname
Definition at line 224 of file vtkLiveInsituLink.h.
◆ InsituPort
int vtkLiveInsituLink::InsituPort
Definition at line 225 of file vtkLiveInsituLink.h.
◆ ProcessType
int vtkLiveInsituLink::ProcessType
Definition at line 226 of file vtkLiveInsituLink.h.
◆ ProxyId
unsigned int vtkLiveInsituLink::ProxyId
Definition at line 227 of file vtkLiveInsituLink.h.
◆ InsituXMLStateChanged
bool vtkLiveInsituLink::InsituXMLStateChanged
Definition at line 229 of file vtkLiveInsituLink.h.
◆ ExtractsChanged
bool vtkLiveInsituLink::ExtractsChanged
Definition at line 230 of file vtkLiveInsituLink.h.
◆ SimulationPaused
int vtkLiveInsituLink::SimulationPaused
Definition at line 231 of file vtkLiveInsituLink.h.
◆ InsituXMLState
char* vtkLiveInsituLink::InsituXMLState
Definition at line 233 of file vtkLiveInsituLink.h.
◆ LiveSession
vtkWeakPointer<vtkPVSessionBase> vtkLiveInsituLink::LiveSession
Definition at line 234 of file vtkLiveInsituLink.h.
◆ Proc0NodesController
vtkSmartPointer<vtkMultiProcessController> vtkLiveInsituLink::Proc0NodesController
Definition at line 239 of file vtkLiveInsituLink.h.
◆ ExtractsDeliveryHelper
vtkSmartPointer<vtkExtractsDeliveryHelper> vtkLiveInsituLink::ExtractsDeliveryHelper
Definition at line 240 of file vtkLiveInsituLink.h.
