Public Slots | Signals | Public Member Functions | Protected Slots | Protected Member Functions | Protected Attributes | List of all members
pqProxyGroupMenuManager Class Reference
pqProxyGroupMenuManager is a menu-populator that fills up a menu with proxies defined in an XML configuration file. More...
#include <pqProxyGroupMenuManager.h>
Inherits QObject.
Collaboration diagram for pqProxyGroupMenuManager:
Public Slots
void setEnabled (bool)
void loadConfiguration (vtkPVXMLElement *)
 Update from servermanager. More...
void lookForNewDefinitions ()
 Look for new proxy definition to add inside the menu Iter over known proxy definitions to parse Hints tag. More...
void removeProxyDefinitionUpdateObservers ()
 Remove all ProxyDefinitionUpdate observers to active server. More...
void addProxyDefinitionUpdateObservers ()
 Update the list of ProxyDefinitionUpdate observers to server. More...
Signals
void triggered (const QString &group, const QString &name)
void menuPopulated ()
 fired when the menu gets repopulated,typically means that the actions have been updated. More...
void categoriesUpdated ()
 Fired when categories were updated. More...
 pqProxyGroupMenuManager (QMenu *menu, const QString &resourceTagName, bool supportsQuickLaunch=true, bool enableFavorites=false)
 Constructor. More...
 ~pqProxyGroupMenuManager () override
QMenu * menu () const
 Access the menu. More...
QWidget * widgetActionsHolder () const
 returns the widget that hold actions created by this menu manager. More...
QMenu * getFavoritesMenu ()
void setRecentlyUsedMenuSize (unsigned int val)
 When size>0 a recently used category will be added to the menu. More...
unsigned int recentlyUsedMenuSize () const
bool supportsQuickLaunch () const
 Returns true if the pqProxyGroupMenuManager has been registered with quick-launch mechanism maintained by pqApplicationCore. More...
void setEnableFavorites (bool enable)
vtkSMProxy * getPrototype (QAction *action) const
 Returns the prototype proxy for the action. More...
void addProxy (const QString &xmlgroup, const QString &xmlname)
 Provides mechanism to explicitly add a proxy to the menu. More...
void removeProxy (const QString &xmlgroup, const QString &xmlname)
 Provides mechanism to explicitly remove a proxy to the menu. More...
void addProxyDefinitionUpdateListener (const QString &proxyGroupName)
 Attach an observer to proxy manager to monitor any proxy definition update The detected proxy have to own a hint: More...
void removeProxyDefinitionUpdateListener (const QString &proxyGroupName)
virtual void populateMenu ()
 Forces a re-population of the menu. More...
void writeCategoryToSettings ()
 Write categories to settings. More...
QStringList getToolbarCategories () const
 Categories information. More...
QString getToolbarName (pqProxyCategory *category)
 Return a name for the toolbar. More...
QString categoryLabel (const QString &category)
 Given a category name, return the category label. More...
bool hideForTests (const QString &) const
 Returns whether or not the category's toolbar should be hidden initially. More...
QList< QAction * > actions () const
 List actions. More...
QList< QAction * > categoryActions (const QString &category)
 Returns actions from given category. More...
QList< QAction * > categoryActions (pqProxyCategory *category)
QList< QAction * > actionsInToolbars ()
 Returns this list of actions that appear in toolbars. More...
QAction * getAction (pqProxyInfo *proxy)
 Return the action for a given proxy. More...
void updateActionIcon (pqProxyInfo *proxy)
 Update action icon from proxy info. More...
pqProxyCategory * getApplicationCategory ()
 Specific-meaning categories. More...
pqProxyCategory * getMenuCategory ()
 Returns the invisible root category containing all categories to display. More...
pqProxyCategory * getFavoritesCategory ()
 Returns the Favorites category. More...
bool isFavorites (pqProxyCategory *category)
 Returns true if the given category is a favorites. More...
Protected Slots
void triggered ()
void quickLaunch ()
void switchActiveServer ()
void updateMenuStyle ()
void updateActionsStyle ()
void populateRecentlyUsedMenu ()
 Fill recently used submenu. More...
void populateFavoritesMenu ()
 called when "favorites" menu is being shown. More...
void loadRecentlyUsedItems ()
void saveRecentlyUsedItems ()
void loadFavoritesItems ()
 Load the favorites from settings. More...
QAction * getAddToFavoritesAction (const QString &path)
QAction * getAction (const QString &pgroup, const QString &proxyname)
QString ResourceTagName
vtkPVXMLElement * MenuRoot = nullptr
int RecentlyUsedMenuSize = 0
bool Enabled
bool EnableFavorites = false
This is use to automatically build the sources and filters menu in ParaView.
Definition at line 25 of file pqProxyGroupMenuManager.h.
◆ pqProxyGroupMenuManager()
pqProxyGroupMenuManager::pqProxyGroupMenuManager ( QMenu *  menu,
const QString &  resourceTagName,
bool  supportsQuickLaunch = true,
bool  enableFavorites = false
Constructor.
menu is the Menu to be populated. resourceTagName is the tag name eg. "ParaViewSources" in the client configuration files which contains lists the items shown by this menu. supportsQuickLaunch, set to false if quick-launch is not to be supported for this menu.
◆ ~pqProxyGroupMenuManager()
pqProxyGroupMenuManager::~pqProxyGroupMenuManager ( )
override
◆ menu()
QMenu* pqProxyGroupMenuManager::menu ( ) const
inline
Access the menu.
Definition at line 46 of file pqProxyGroupMenuManager.h.
◆ widgetActionsHolder()
QWidget* pqProxyGroupMenuManager::widgetActionsHolder ( ) const
◆ getFavoritesMenu()
QMenu* pqProxyGroupMenuManager::getFavoritesMenu ( )
◆ setRecentlyUsedMenuSize()
void pqProxyGroupMenuManager::setRecentlyUsedMenuSize ( unsigned int  val)
inline
One must call update() or initialize() after changing this value.
Definition at line 58 of file pqProxyGroupMenuManager.h.
◆ recentlyUsedMenuSize()
unsigned int pqProxyGroupMenuManager::recentlyUsedMenuSize ( ) const
inline
Definition at line 59 of file pqProxyGroupMenuManager.h.
◆ supportsQuickLaunch()
bool pqProxyGroupMenuManager::supportsQuickLaunch ( ) const
inline
Definition at line 64 of file pqProxyGroupMenuManager.h.
◆ setEnableFavorites()
void pqProxyGroupMenuManager::setEnableFavorites ( bool  enable)
inline
Definition at line 65 of file pqProxyGroupMenuManager.h.
◆ getPrototype()
vtkSMProxy* pqProxyGroupMenuManager::getPrototype ( QAction *  action) const
◆ addProxy()
void pqProxyGroupMenuManager::addProxy ( const QString &  xmlgroup,
const QString &  xmlname
◆ removeProxy()
void pqProxyGroupMenuManager::removeProxy ( const QString &  xmlgroup,
◆ getToolbarCategories()
QStringList pqProxyGroupMenuManager::getToolbarCategories ( ) const
Returns a list of categories that have the "show_in_toolbar" attribute set to 1.
◆ getToolbarName()
QString pqProxyGroupMenuManager::getToolbarName ( pqProxyCategory *  category)
This is based on category name and proxy group.
◆ categoryLabel()
QString pqProxyGroupMenuManager::categoryLabel ( const QString &  category)
◆ hideForTests()
bool pqProxyGroupMenuManager::hideForTests ( const QString &  ) const
inline
Definition at line 105 of file pqProxyGroupMenuManager.h.
◆ actions()
QList<QAction*> pqProxyGroupMenuManager::actions ( ) const
List actions.
returns the actions holds by the widgetActionsHolder
◆ categoryActions() [1/2]
QList<QAction*> pqProxyGroupMenuManager::categoryActions ( const QString &  category)
Create actions as needed. Looks for category in the default categories list.
◆ categoryActions() [2/2]
QList<QAction*> pqProxyGroupMenuManager::categoryActions ( pqProxyCategory *  category)
◆ actionsInToolbars()
QList<QAction*> pqProxyGroupMenuManager::actionsInToolbars ( )
◆ getAction() [1/2]
QAction* pqProxyGroupMenuManager::getAction ( pqProxyInfo *  proxy)
◆ updateActionIcon()
void pqProxyGroupMenuManager::updateActionIcon ( pqProxyInfo *  proxy)
◆ addProxyDefinitionUpdateListener()
void pqProxyGroupMenuManager::addProxyDefinitionUpdateListener ( const QString &  proxyGroupName)
<ShowInMenu category="" icon=""/>
where all the attribute are fully optional.
◆ removeProxyDefinitionUpdateListener()
void pqProxyGroupMenuManager::removeProxyDefinitionUpdateListener ( const QString &  proxyGroupName)
◆ getApplicationCategory()
pqProxyCategory* pqProxyGroupMenuManager::getApplicationCategory ( )
Returns the invisible root category containing all categories to display, as defined by the application.
◆ getMenuCategory()
pqProxyCategory* pqProxyGroupMenuManager::getMenuCategory ( )
Use settings if existing.
◆ getFavoritesCategory()
pqProxyCategory* pqProxyGroupMenuManager::getFavoritesCategory ( )
◆ isFavorites()
bool pqProxyGroupMenuManager::isFavorites ( pqProxyCategory *  category)
Based on name.
◆ loadConfiguration
void pqProxyGroupMenuManager::loadConfiguration ( vtkPVXMLElement *  )
slot
Load a configuration XML. It will find the elements with resourceTagName in the XML and populate the menu accordingly. Applications do not need to call this method directly, it's by default connected to pqApplicationCore::loadXML()
◆ lookForNewDefinitions
void pqProxyGroupMenuManager::lookForNewDefinitions ( )
slot
◆ removeProxyDefinitionUpdateObservers
void pqProxyGroupMenuManager::removeProxyDefinitionUpdateObservers ( )
slot
◆ addProxyDefinitionUpdateObservers
void pqProxyGroupMenuManager::addProxyDefinitionUpdateObservers ( )
slot
◆ setEnabled
void pqProxyGroupMenuManager::setEnabled ( bool  )
inlineslot
Definition at line 203 of file pqProxyGroupMenuManager.h.
◆ populateMenu()
virtual void pqProxyGroupMenuManager::populateMenu ( )
Create the main submenu entries. Actions are mostly created on "aboutToShow" signal, as menu should present the currently available proxies. See also populateRecentlyUsedMenu, populateAlphabeticalMenu, populateMiscMenu, populateCategoriesMenus, clearMenu
◆ writeCategoryToSettings()
void pqProxyGroupMenuManager::writeCategoryToSettings ( )
◆ triggered [1/2]
void pqProxyGroupMenuManager::triggered ( const QString &  group,
const QString &  name
signal
◆ menuPopulated
void pqProxyGroupMenuManager::menuPopulated ( )
signal
◆ categoriesUpdated
void pqProxyGroupMenuManager::categoriesUpdated ( )
signal
◆ triggered [2/2]
void pqProxyGroupMenuManager::triggered ( )
protectedslot
◆ quickLaunch
void pqProxyGroupMenuManager::quickLaunch ( )
protectedslot
◆ switchActiveServer
void pqProxyGroupMenuManager::switchActiveServer ( )
protectedslot
◆ updateMenuStyle
void pqProxyGroupMenuManager::updateMenuStyle ( )
protectedslot
◆ updateActionsStyle
void pqProxyGroupMenuManager::updateActionsStyle ( )
protectedslot
◆ populateRecentlyUsedMenu
void pqProxyGroupMenuManager::populateRecentlyUsedMenu ( )
protectedslot
◆ populateFavoritesMenu
void pqProxyGroupMenuManager::populateFavoritesMenu ( )
protectedslot
create the menu (and submenu) with actions for the filters in the favorites list.
◆ loadRecentlyUsedItems()
void pqProxyGroupMenuManager::loadRecentlyUsedItems ( )
◆ saveRecentlyUsedItems()
void pqProxyGroupMenuManager::saveRecentlyUsedItems ( )
◆ loadFavoritesItems()
void pqProxyGroupMenuManager::loadFavoritesItems ( )
◆ getAddToFavoritesAction()
QAction* pqProxyGroupMenuManager::getAddToFavoritesAction ( const QString &  path)
◆ getAction() [2/2]
QAction* pqProxyGroupMenuManager::getAction ( const QString &  pgroup,
const QString &  proxyname
◆ ResourceTagName
QString pqProxyGroupMenuManager::ResourceTagName
Definition at line 252 of file pqProxyGroupMenuManager.h.
◆ MenuRoot
vtkPVXMLElement* pqProxyGroupMenuManager::MenuRoot = nullptr
Definition at line 253 of file pqProxyGroupMenuManager.h.
◆ RecentlyUsedMenuSize
int pqProxyGroupMenuManager::RecentlyUsedMenuSize = 0
Definition at line 254 of file pqProxyGroupMenuManager.h.
◆ Enabled
bool pqProxyGroupMenuManager::Enabled
Definition at line 256 of file pqProxyGroupMenuManager.h.
◆ EnableFavorites
bool pqProxyGroupMenuManager::EnableFavorites = false
Definition at line 257 of file pqProxyGroupMenuManager.h.
