| const std::vector< ProxyType > & | GetProxyTypes () const |
| | Returns a vector of proxy types for the proxies in the domain. More...
| unsigned int | GetNumberOfProxyTypes () |
| | Returns the number of proxies in the domain. More...
| const char * | GetProxyGroup (unsigned int index) |
| | Returns the xml group name for the proxy at a given index. More...
| const char * | GetProxyName (unsigned int index) |
| | Returns the xml type name for the proxy at a given index. More...
| const char * | GetProxyName (vtkSMProxy *proxy) |
| | If the proxy is part of the domain, then this returns the name used for the proxy in the domain. More...
| vtkSMProxy * | GetProxyWithName (const char *pname) |
| | Inverse of GetProxyName, returns the first proxy with the given name. More...
| int | IsInDomain (vtkSMProperty *property) override |
| | This always returns true. More...
| void | AddProxy (vtkSMProxy *) |
| | Add a proxy to the domain. More...
| bool | HasProxy (vtkSMProxy *) |
| | Returns if the proxy is present in the domain. More...
| unsigned int | GetNumberOfProxies () |
| | Get number of proxies in the domain. More...
| vtkSMProxy * | GetProxy (unsigned int index) |
| | Get proxy at a given index. More...
| vtkSMProxy * | FindProxy (const char *xmlgroup, const char *xmlname) |
| | Find a proxy in the domain of the given group and type. More...
| int | RemoveProxy (vtkSMProxy *proxy) |
| | Removes the first occurrence of the proxy in the domain. More...
| int | RemoveProxy (unsigned int index) |
| | Removes the proxy at the given index. More...
| void | CreateProxies (vtkSMSessionProxyManager *pxm) |
| | Creates and populates the domain with the proxy-types. More...
| int | SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override |
| void | SetLogName (const char *prefix) |
| | Sets log name for each of the proxy in the domain using the prefix provided. More...
| virtual void | SetDefaultIndex (unsigned int) |
| | Set and Get the default proxy index. More...
| virtual unsigned int | GetDefaultIndex () |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| | vtkSMProxyListDomain () |
| | ~vtkSMProxyListDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | AddProxy (const char *group, const char *name) |
| | Adds a proxy type, used by ReadXMLAttributes(). More...
| void | ChildSaveState (vtkPVXMLElement *propertyElement) override |
| | Save state for this domain. More...
| int | LoadState (vtkPVXMLElement *domainElement, vtkSMProxyLocator *loader) override |
| void | SetProxies (vtkSMProxy **proxies, unsigned int count) |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
union of proxies.
This domain is a collection of proxies that can be assigned as the value to a vtkSMProxyProperty. The Server Manager configuration defines the proxy types that form this list, while the value of this domain is the list of instances of proxies. Example usage :
<ProxyListDomain name="proxy_list">
<Proxy group="implicit_functions"
name="Plane" />
<Group name="implicit_functions"/>
</ProxyListDomain>
- See also
- vtkSMDomain vtkSMProxyProperty
Definition at line 40 of file vtkSMProxyListDomain.h.
