creates a link between two proxies. More...
#include <vtkSMProxyLink.h>
| enum | ExceptionListBehavior : int { BLACKLIST = 0, WHITELIST } |
| typedef vtkSMLink | Superclass |
Public Types inherited from vtkSMLink | |
| enum | UpdateDirections { NONE = 0, INPUT = 1, OUTPUT = 2 } |
| virtual void | AddLinkedProxy (vtkSMProxy *proxy, int updateDir) |
| Add a property to the link. More... | |
| virtual void | LinkProxies (vtkSMProxy *proxy1, vtkSMProxy *proxy2) |
| Utility method to add 2 proxies, both as INPUT and OUTPUT. More... | |
| virtual void | LinkProxyPropertyProxies (vtkSMProxy *proxy1, vtkSMProxy *proxy2, const char *pname) |
| Utility method to link the proxies stored as proxy property of input proxies. More... | |
| virtual void | RemoveLinkedProxy (vtkSMProxy *proxy) |
| Remove a linked proxy. More... | |
| vtkSMProxy * | GetLinkedProxy (int index) override |
| Get a proxy involved in this link. More... | |
| void | RemoveAllLinks () override |
| Remove all links. More... | |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
| unsigned int | GetNumberOfLinkedObjects () override |
| Get the number of proxies that are involved in this link. More... | |
| unsigned int | GetNumberOfLinkedProxies () |
| int | GetLinkedObjectDirection (int index) override |
| Get the direction of a proxy involved in this link (see vtkSMLink::UpdateDirections) More... | |
| int | GetLinkedProxyDirection (int index) |
| void | AddException (const char *propertyname) |
| It is possible to exclude certain properties from being synchronized by this link. More... | |
| void | RemoveException (const char *propertyname) |
| void | ClearExceptions () |
| virtual void | SetExceptionBehavior (int) |
| Set/Get exception behavior. More... | |
| virtual int | GetExceptionBehavior () |
| void | SetExceptionBehaviorToBlacklist () |
| void | SetExceptionBehaviorToWhitelist () |
Public Member Functions inherited from vtkSMLink | |
| This method returns the full object state that can be used to create the object from scratch. More... | |
| virtual void | SetPropagateUpdateVTKObjects (int) |
| This flag determines if UpdateVTKObjects calls are to be propagated. More... | |
| virtual int | GetPropagateUpdateVTKObjects () |
| virtual void | PropagateUpdateVTKObjectsOn () |
| virtual void | PropagateUpdateVTKObjectsOff () |
| virtual void | SetEnabled (bool) |
| Get/Set if the link is enabled. More... | |
| virtual bool | GetEnabled () |
| bool | HasGlobalID () |
| virtual void | EnableLocalPushOnly () |
| virtual void | DisableLocalPushOnly () |
| virtual void | SetLocation (vtkTypeUInt32) |
| virtual void | PrototypeOn () |
| virtual void | PrototypeOff () |
| bool | IsPrototype () |
| virtual void | SetPrototype (bool) |
| static vtkSMProxyLink * | New () |
| static vtkSMProxyLink * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMLink | |
| static vtkSMLink * | SafeDownCast (vtkObject *o) |
| vtkSMProxyLink () | |
| ~vtkSMProxyLink () override | |
| void | UpdateVTKObjects (vtkSMProxy *proxy) override |
| Called when an input proxy is updated (UpdateVTKObjects). More... | |
| void | PropertyModified (vtkSMProxy *proxy, const char *pname) override |
| Called when a property of an input proxy is modified. More... | |
| void | UpdateProperty (vtkSMProxy *caller, const char *pname) override |
| Called when a property is pushed. More... | |
| virtual std::string | GetXMLTagName () |
| Get tag name to use in statefile. More... | |
| void | SaveXMLState (const char *linkname, vtkPVXMLElement *parent) override |
| Save the state of the link. More... | |
| int | LoadXMLState (vtkPVXMLElement *linkElement, vtkSMProxyLocator *locator) override |
| Load the link state. More... | |
| void | UpdateState () override |
| Update the internal protobuf state. More... | |
Protected Member Functions inherited from vtkSMLink | |
| vtkSMLink () | |
| ~vtkSMLink () override | |
| void | PushStateToSession () |
| When the state has changed we call that method so the state can be shared if any collaboration is involved. More... | |
| void | ObserveProxyUpdates (vtkSMProxy *proxy) |
| Subclasses call this method to observer events on a INPUT proxy. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes inherited from vtkSMLink | |
| vtkCommand * | Observer |
| int | PropagateUpdateVTKObjects |
| bool | Enabled |
| vtkSMMessage * | State |
Protected Attributes inherited from vtkSMRemoteObject | |
| vtkTypeUInt32 | GlobalID |
| vtkTypeUInt32 | Location |
| bool | Prototype |
| bool | ClientOnlyLocationFlag |
When a link is created between proxy A->B, whenever any property on proxy A is modified, a property with the same name as the modified property (if any) on proxy B is also modified to be the same as the property on the proxy A. Similarly whenever proxy A->UpdateVTKObjects() is called, B->UpdateVTKObjects() is also fired.
Definition at line 24 of file vtkSMProxyLink.h.
| typedef vtkSMLink vtkSMProxyLink::Superclass |
Definition at line 28 of file vtkSMProxyLink.h.
| Enumerator | |
| BLACKLIST | |
| WHITELIST | |
Definition at line 31 of file vtkSMProxyLink.h.
Reimplemented from vtkSMLink.
Reimplemented in vtkSMViewLink, and vtkSMCameraLink.
updateDir determines whether a property of the proxy is read or written. When a property of an input proxy changes, it's value is pushed to all other output proxies in the link. A proxy can be set to be both input and output by adding 2 link, one to INPUT and the other to OUTPUT
Reimplemented in vtkSMCameraLink, and vtkSMViewLink.
This is equivalent to call 4 times AddLinkedProxy() with each combination.
Implements vtkSMLink.
| unsigned int vtkSMProxyLink::GetNumberOfLinkedProxies | ( | ) |
| void vtkSMProxyLink::AddException | ( | const char * | propertyname | ) |
This method can be used to add/remove the names for such exception properties. If ExceptionBehavior is set to BLACKLIST (default), exceptions are excluded from synchronization. If ExceptionBehavior is set to WHITELIST, exceptions are the only one synchronized.
| void vtkSMProxyLink::RemoveException | ( | const char * | propertyname | ) |
| void vtkSMProxyLink::ClearExceptions | ( | ) |
Remove all links.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented in vtkSMCameraLink.
The list can be a blacklist or a whitelist of proxy properties. Properties in the list will not be linked if behavior is set to BLACKLIST, or they will be the only ones linked if behavior is set to WHITELIST. Default: BLACKLIST.
Definition at line 123 of file vtkSMProxyLink.h.
Definition at line 124 of file vtkSMProxyLink.h.
overrideprotectedvirtual |
Argument is the input proxy.
caller:- the input proxy. pname:- name of the property being modified.
caller :- the input proxy. pname :- name of property that was pushed.
inlineprotectedvirtual |
This should match the class name without "vtkSM" prefix. see vtkSMStateLoader::HandleLinks
Definition at line 156 of file vtkSMProxyLink.h.
