| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| std::vector< double > | GetValues () |
| | Returns the vector of values. More...
| bool | GetValuesExists () |
| | Returns if Values is non empty. More...
| void | Update (vtkSMProperty *property) override |
| | Updates this from the property. More...
| | Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| | vtkSMDiscreteDoubleDomain () |
| | ~vtkSMDiscreteDoubleDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| | Reads the "values" property, with a maximum of 256 values. More...
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
set of double
vtkSMDiscreteDoubleDomain represents a set of double values. It supports a maximum of 256 values.
Values are specified in xml as follow:
<DiscreteDoubleDomain values='val1 val2 ... valX' />
Definition at line 26 of file vtkSMDiscreteDoubleDomain.h.
