| | Update the domain using the "unchecked" values (if available) for all required properties. More...
Public Member Functions inherited from vtkSMIntRangeDomain |
| virtual int | GetMinimum (unsigned int idx, int &exists) |
| | Return a min. More...
| virtual int | GetMaximum (unsigned int idx, int &exists) |
| | Return a max. More...
| virtual int | GetMinimumExists (unsigned int idx) |
| | Returns if minimum/maximum bound is set for the domain. More...
| virtual int | GetMaximumExists (unsigned int idx) |
| virtual int | GetMinimum (unsigned int idx) |
| | Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
| virtual int | GetMaximum (unsigned int idx) |
| | Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| | vtkSMDimensionsDomain () |
| | ~vtkSMDimensionsDomain () override |
| void | Update (vtkSMProxyProperty *pp, vtkSMIntVectorProperty *ivp) |
| int | GetDirection (vtkSMIntVectorProperty *ivp) |
| void | GetExtent (vtkSMProxyProperty *pp, int extent[6]) |
Protected Member Functions inherited from vtkSMIntRangeDomain |
| | vtkSMIntRangeDomain () |
| | ~vtkSMIntRangeDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
int range domain based on the data dimensions.
vtkSMDimensionsDomain is a subclass of vtkSMIntRangeDomain. It relies on two required properties: "Input", "Direction". "Input" is generally an vtkSMInputProperty which provides the information about the data extents. "Direction" is an option required property which helps determine the direction (VTK_XY_PLANE, VTK_YZ_PLANE or VTK_XZ_PLANE). If "Direction" is not provided then the property must be a 3 element property while when Direction is provided the property must be a 1 element property.
Supported Required-Property functions:
Input : points to a property that provides the data producer.
Direction: points to a property that provides the value for the selected direction.
Definition at line 30 of file vtkSMDimensionsDomain.h.
