| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the property is a vtkSMIntVectorProperty. More...
| | Update self checking the "unchecked" values of all required properties. More...
| int | SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override |
| | Set Default value. More...
| | Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| | vtkSMDataTypeQueryDomain () |
| | ~vtkSMDataTypeQueryDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
A domain for getting the input data type and setting it.
This domain is used to query the data type of the input to the property and set it as the default value and during the update.
Example usage is as follows:
<SourceProxy ...>
<IntVectorProperty command="SetPlaceHolderDataType"
default_values="38"
name="PlaceHolderDataType"
panel_visibility="never"
number_of_elements="1">
<DataTypeQueryDomain name="data_type_query">
<RequiredProperties>
<Property function="Input"
name="Input"/>
</RequiredProperties>
</DataTypeQueryDomain>
</IntVectorProperty>
</SourceProxy>
- See also
- vtkSMDomain vtkSMIntVectorProperty
Definition at line 39 of file vtkSMDataTypeQueryDomain.h.
