| void | Update (vtkSMProperty *requestingProperty) override |
| | Update self based on the "unchecked" values of all required properties. More...
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| virtual void | SetBackwardCompatibilityMode (bool) |
| | When set to true, the domain will use the old functionality setting the assembly default value. More...
| virtual bool | GetBackwardCompatibilityMode () |
| virtual void | BackwardCompatibilityModeOn () |
| virtual void | BackwardCompatibilityModeOff () |
Public Member Functions inherited from vtkSMStringListDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (const char *string, unsigned int &idx) |
| | Returns true if the string is in the domain. More...
| const char * | GetString (unsigned int idx) |
| | Returns a string in the domain. More...
| unsigned int | GetNumberOfStrings () |
| | Returns the number of strings in the domain. More...
| | Update self checking the "unchecked" values of all required properties. More...
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| virtual char * | GetNoneString () |
| | Return the string that is used as "none_string" in XML configuration. More...
| virtual void | SetNoneString (const char *) |
| | Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| | vtkSMDataAssemblyListDomain () |
| | ~vtkSMDataAssemblyListDomain () override |
Protected Member Functions inherited from vtkSMStringListDomain |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| | Call to set the strings. More...
| const std::vector< std::string > & | GetStrings () |
| | vtkSMStringListDomain () |
| | ~vtkSMStringListDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
domain listing available assembly types in the input
vtkSMDataAssemblyListDomain is a string-list domain subclass that populates the list with names of assemblies available in the input.
Example usage is as follows:
<SourceProxy ...>
<StringVectorProperty name="BlockAssembly"
command="SetSelectorAssembly"
number_of_elements="1">
<DataAssemblyListDomain name="data_assembly_list">
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</DataAssemblyListDomain>
</StringVectorProperty>
</SourceProxy>
Definition at line 33 of file vtkSMDataAssemblyListDomain.h.
