A reader for XML camera configuration. More...
#include <vtkSMCameraConfigurationReader.h>
| typedef vtkSMProxyConfigurationReader | Superclass |
Public Types inherited from vtkSMProxyConfigurationReader | |
| void | SetRenderViewProxy (vtkSMProxy *rvProxy) |
| Set the render view proxy to extract camera properties from. More... | |
| int | ReadConfiguration (const char *filename) override |
| Read the named file, and push the properties into the underying managed render view proxy. More... | |
| int | ReadConfiguration (vtkPVXMLElement *x) override |
| int | ReadConfiguration () override |
Public Member Functions inherited from vtkSMProxyConfigurationReader | |
| virtual void | SetFileDescription (const char *) |
| virtual char * | GetFileDescription () |
| virtual void | SetFileExtension (const char *) |
| virtual char * | GetFileExtension () |
| virtual const char * | GetReaderVersion () |
| Return the reader version. More... | |
| virtual bool | CanReadVersion (const char *version) |
| Return true if the reader can read the specified version. More... | |
| virtual void | SetFileName (const char *) |
| Set/Get the file name. More... | |
| virtual char * | GetFileName () |
| virtual vtkSMProxy * | GetProxy () |
| Set the proxy to write out. More... | |
| virtual void | SetFileIdentifier (const char *) |
| Set/get file meta data. More... | |
| virtual char * | GetFileIdentifier () |
| virtual void | SetValidateProxyType (int) |
| Turns on/off proxy type validation. More... | |
| virtual int | GetValidateProxyType () |
Public Member Functions inherited from vtkSMObject | |
| static vtkSMCameraConfigurationReader * | SafeDownCast (vtkObject *o) |
| static vtkSMCameraConfigurationReader * | New () |
Static Public Member Functions inherited from vtkSMProxyConfigurationReader | |
| static vtkSMProxyConfigurationReader * | New () |
| static vtkSMProxyConfigurationReader * | SafeDownCast (vtkObject *o) |
A reader for XML camera configuration. Reades camera configuration files. written by the vtkSMCameraConfigurationWriter.
Definition at line 28 of file vtkSMCameraConfigurationReader.h.
Definition at line 31 of file vtkSMCameraConfigurationReader.h.
Reimplemented from vtkSMProxyConfigurationReader.
| void vtkSMCameraConfigurationReader::SetRenderViewProxy | ( | vtkSMProxy * | rvProxy | ) |
This will make sure the renderview is updated after the read.
inlineoverridevirtual |
Definition at line 49 of file vtkSMCameraConfigurationReader.h.
inlineoverrideprotectedvirtual |
Definition at line 58 of file vtkSMCameraConfigurationReader.h.
