helper class used to write animations. More...
#include <vtkSMAnimationSceneWriter.h>
| virtual void | SetAnimationScene (vtkSMProxy *) |
| Convenience method to set the proxy. More... | |
| bool | Save () |
| Begin the saving. More... | |
| virtual void | SetAnimationScene (vtkSMAnimationScene *) |
| Get/Set the animation scene that this writer will write. More... | |
| virtual vtkSMAnimationScene * | GetAnimationScene () |
| virtual void | SetFileName (const char *) |
| Get/Set the filename. More... | |
| virtual char * | GetFileName () |
| virtual void | SetStartFileCount (int) |
| Get/Set the start file count. More... | |
| virtual int | GetStartFileCount () |
| virtual void | SetPlaybackTimeWindow (double, double) |
| Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More... | |
| void | SetPlaybackTimeWindow (double [2]) |
| virtual double * | GetPlaybackTimeWindow () |
| virtual void | GetPlaybackTimeWindow (double &, double &) |
| virtual void | GetPlaybackTimeWindow (double [2]) |
| virtual void | SetStride (int) |
| Set/Get The stride which is used to extract the next frame. More... | |
| virtual int | GetStride () |
| static vtkSMAnimationSceneWriter * | SafeDownCast (vtkObject *o) |
| vtkSMAnimationSceneWriter () | |
| ~vtkSMAnimationSceneWriter () override | |
| virtual bool | SaveInitialize (int countStart)=0 |
| Subclasses should override this method. More... | |
| virtual bool | SaveFrame (double time)=0 |
| virtual bool | SaveFinalize ()=0 |
| void | ExecuteEvent (vtkObject *caller, unsigned long eventid, void *calldata) |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes | |
| unsigned long | ObserverID |
| vtkSMAnimationScene * | AnimationScene |
| bool | Saving |
| bool | SaveFailed |
| char * | FileName |
| double | PlaybackTimeWindow [2] |
| int | StartFileCount |
| int | Stride = 1 |
vtkSMAnimationSceneWriter is an abstract superclass for writers that can write animations out.
Definition at line 21 of file vtkSMAnimationSceneWriter.h.
Definition at line 24 of file vtkSMAnimationSceneWriter.h.
Reimplemented from vtkSMSessionObject.
Reimplemented in vtkSMAnimationSceneGeometryWriter, and vtkSMAnimationSceneWebWriter.
| bool vtkSMAnimationSceneWriter::Save | ( | ) |
Begin the saving.
This will result in playing of the animation. Returns the status of the save.
| void vtkSMAnimationSceneWriter::SetPlaybackTimeWindow | ( | double | [2] | ) |
E.g. 1, 2, 3, would have stride = 1, while 1, 3, 5 would have stride = 2.
Default value is 1.
Default value is 1.
protectedpure virtual |
Called to initialize saving.
Implemented in vtkSMAnimationSceneWebWriter, and vtkSMAnimationSceneGeometryWriter.
Called to save a particular frame.
Called to finalize saving.
Definition at line 87 of file vtkSMAnimationSceneWriter.h.
Definition at line 88 of file vtkSMAnimationSceneWriter.h.
Definition at line 112 of file vtkSMAnimationSceneWriter.h.
Definition at line 113 of file vtkSMAnimationSceneWriter.h.
Definition at line 114 of file vtkSMAnimationSceneWriter.h.
Definition at line 115 of file vtkSMAnimationSceneWriter.h.
Definition at line 116 of file vtkSMAnimationSceneWriter.h.
Definition at line 117 of file vtkSMAnimationSceneWriter.h.
