#include <vtkNvPipeCompressor.h>
| typedef vtkImageCompressor | Superclass |
Public Types inherited from vtkImageCompressor | |
| void | SetImageResolution (int img_width, int img_height) |
| Communicates the next expected image resolution. More... | |
| virtual void | SetQuality (unsigned int) |
| Set the quality measure. More... | |
| virtual unsigned int | GetQuality () |
| virtual int | Compress () |
| Call this method to compress the input and generate the compressed data. More... | |
| virtual int | Decompress () |
| Decompresses and geenartes the decompressed data as output. More... | |
| virtual void | SaveConfiguration (vtkMultiProcessStream *stream) |
| virtual bool | RestoreConfiguration (vtkMultiProcessStream *stream) |
| virtual const char * | SaveConfiguration () |
| virtual const char * | RestoreConfiguration (const char *stream) |
Public Member Functions inherited from vtkImageCompressor | |
| void | SetInput (vtkUnsignedCharArray *input) |
| Get/Set the input to this compressor. More... | |
| virtual vtkUnsignedCharArray * | GetInput () |
| virtual vtkUnsignedCharArray * | GetOutput () |
| Get/Set the output of the compressor. More... | |
| void | SetOutput (vtkUnsignedCharArray *) |
| virtual void | SetLossLessMode (int) |
| When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More... | |
| virtual int | GetLossLessMode () |
| static vtkNvPipeCompressor * | New () |
| static vtkNvPipeCompressor * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkImageCompressor | |
| static vtkImageCompressor * | SafeDownCast (vtkObject *o) |
| vtkNvPipeCompressor () | |
| virtual | ~vtkNvPipeCompressor () |
Protected Member Functions inherited from vtkImageCompressor | |
| virtual void | SetConfiguration (const char *) |
| vtkImageCompressor () | |
| Construct with nullptr input array and empty but allocated output array. More... | |
| ~vtkImageCompressor () override | |
Protected Attributes | |
| unsigned int | Quality |
Protected Attributes inherited from vtkImageCompressor | |
| vtkUnsignedCharArray * | Output |
| vtkUnsignedCharArray * | Input |
| int | LossLessMode |
| char * | Configuration |
Definition at line 21 of file vtkNvPipeCompressor.h.
Definition at line 25 of file vtkNvPipeCompressor.h.
protectedvirtual |
Reimplemented from vtkImageCompressor.
The value can be between 1 and 5. 1 means preserve input image quality while 5 emphasizes compression ratio at the expense of image quality.
Implements vtkImageCompressor.
Input must be compressed data.
Description: Serialize/Restore compressor configuration (but not the data) into the stream.
Definition at line 61 of file vtkNvPipeCompressor.h.
