Superclass for image compressor/decompressor used by Composite Managers. More...
#include <vtkImageCompressor.h>
| virtual int | Compress ()=0 |
| Call this method to compress the input and generate the compressed data. More... | |
| virtual int | Decompress ()=0 |
| Decompresses and geenartes the decompressed data as output. More... | |
| virtual void | SetImageResolution (int width, int height) |
| Communicates the next expected image resolution. More... | |
| virtual void | SaveConfiguration (vtkMultiProcessStream *stream) |
| Serialize compressor configuration (but not the data) into the stream. More... | |
| virtual bool | RestoreConfiguration (vtkMultiProcessStream *stream) |
| Restore state from the stream. More... | |
| virtual const char * | SaveConfiguration () |
| virtual const char * | RestoreConfiguration (const char *stream) |
| Restore state from the stream, The stream format for all image compressor is: [ClassName, LossLessMode, [Derived Class Stream]]. More... | |
| void | SetInput (vtkUnsignedCharArray *input) |
| Get/Set the input to this compressor. More... | |
| virtual vtkUnsignedCharArray * | GetInput () |
| virtual vtkUnsignedCharArray * | GetOutput () |
| Get/Set the output of the compressor. More... | |
| void | SetOutput (vtkUnsignedCharArray *) |
| virtual void | SetLossLessMode (int) |
| When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More... | |
| virtual int | GetLossLessMode () |
| static vtkImageCompressor * | SafeDownCast (vtkObject *o) |
| virtual void | SetConfiguration (const char *) |
| vtkImageCompressor () | |
| Construct with nullptr input array and empty but allocated output array. More... | |
| ~vtkImageCompressor () override | |
Protected Attributes | |
| vtkUnsignedCharArray * | Output |
| vtkUnsignedCharArray * | Input |
| int | LossLessMode |
| char * | Configuration |
vtkImageCompressor is an abstract superclass for the helper object used to compress images by the vtkParallelManager subclasses. Compressors must implement Compress,Decomperss methods, which respect the LossLessMode ivar, which is used by the composite manager to force loss less compression during a still render. Additionally compressors must be able to seriealize and restore their setting from a stream.
Definition at line 27 of file vtkImageCompressor.h.
Definition at line 30 of file vtkImageCompressor.h.
Reimplemented in vtkSquirtCompressor, vtkZlibImageCompressor, vtkLZ4Compressor, and vtkNvPipeCompressor.
| void vtkImageCompressor::SetInput | ( | vtkUnsignedCharArray * | input | ) |
| void vtkImageCompressor::SetOutput | ( | vtkUnsignedCharArray * | ) |
Reimplemented in vtkZlibImageCompressor.
pure virtual |
Implemented in vtkSquirtCompressor, vtkLZ4Compressor, vtkNvPipeCompressor, and vtkZlibImageCompressor.
pure virtual |
Input must be compressed data.
Reimplemented in vtkNvPipeCompressor.
Reimplemented in vtkSquirtCompressor, vtkLZ4Compressor, vtkNvPipeCompressor, and vtkZlibImageCompressor.
A pointer to the internally managed stream is returned (ie do not free it!).
Upon success the stream is returned otherwise 0 is returned indicating an error.
protectedvirtual |
Definition at line 110 of file vtkImageCompressor.h.
Definition at line 111 of file vtkImageCompressor.h.
Definition at line 113 of file vtkImageCompressor.h.
Definition at line 115 of file vtkImageCompressor.h.
