help class for python modules More...
#include <vtkInitializationHelper.h>
| static vtkInitializationHelper * | SafeDownCast (vtkObject *o) |
| static bool | Initialize (int argc, char **argv, int processType, vtkCLIOptions *options=nullptr, bool enableStandardArgs=true) |
| Initializes ParaView engine. More... | |
| static bool | Initialize (vtkStringList *argv, int processType) |
| Overload primary intended for Python wrapping. More... | |
| static bool | Initialize (const char *executable, int type) |
| An overload that does not take argc/argv for convenience. More... | |
| static bool | InitializeProcessModule (int argc, char **argv, int type) |
| Initialize the vtkProcessModule used in ParaView. More... | |
| static bool | InitializeGlobalOptions (int argc, char **argv, int processType, vtkCLIOptions *options=nullptr, bool enableStandardArgs=true) |
| Initialize only the global options (see vtkCLIOptions) of ParaView engine but do not check for options that cause early exit of the program. More... | |
| static bool | InitializeOtherOptions (int argc, char **argv, int processType, vtkCLIOptions *options=nullptr, bool enableStandardArgs=true) |
| Initialize all options of ParaView engine but the global options, then check for options that cause early exit of the program. More... | |
| static bool | InitializeOptions (int argc, char **argv, int processType, vtkCLIOptions *options=nullptr, bool enableStandardArgs=true) |
| Initialize the process module and options of ParaView engine. More... | |
| static bool | InitializeSettings (int type, bool defaultCoreConfig) |
| Initialize the setting by reading the settings file, unless coreConfig DisableRegistry is set to true. More... | |
| static bool | InitializeOthers () |
| Initialize everything that is not initialized by specific methods, see Initialize method for more info. More... | |
| static bool | InitializeMiscellaneous (int type) |
| Initialize everything that needs to be initialized in the paraview engine after the options. More... | |
| static void | InitializePythonVirtualEnvironment () |
| Initialize Python virtual environment from –venv command-line argument if any was provided. More... | |
| static void | Finalize () |
| Finalizes the server manager. More... | |
| static int | GetExitCode () |
Returns the exit code after Initialize. More... | |
| static std::string | GetUserSettingsDirectory () |
| Get directory for user settings file. More... | |
| static std::string | GetUserSettingsFilePath () |
| Get file path for the user settings file. More... | |
| static void | StandaloneInitialize () |
| Initialization for standalone executables linking against a PV library. More... | |
| static void | StandaloneFinalize () |
| static void | SetLoadSettingsFilesDuringInitialization (bool) |
| During initialization, vtkInitializationHelper reads "settings" files for configuring vtkSMSettings. More... | |
| static bool | GetLoadSettingsFilesDuringInitialization () |
| static void | SetOrganizationName (const std::string &organizationName) |
| Sets the organization producing this application. More... | |
| static const std::string & | GetOrganizationName () |
| static void | SetApplicationName (const std::string &appName) |
| Sets the name of the application. More... | |
| static const std::string & | GetApplicationName () |
| vtkInitializationHelper ()=default | |
| ~vtkInitializationHelper () override=default | |
Static Protected Member Functions | |
| static void | LoadSettings () |
| Load user and site settings. More... | |
This class is used by the python modules when they are loaded from python (as opposed to pvpython). It simply initializes the server manager so that it can be used.
Definition at line 28 of file vtkInitializationHelper.h.
Definition at line 31 of file vtkInitializationHelper.h.
protecteddefault |
overrideprotecteddefault |
Returns true on success, false otherwise. When false, use GetExitCode to obtain the exit code. Note, for requests like --help, --version etc, this method returns false with exit-code set to 0.
If vtkCLIOptions is nullptr, then this method internally creates and uses an internal vtkCLIOptions instance. In that case, extra / unknown arguments are simply ignored.
Internally calls, in this order:
This method should be called before any other initialization method Unless that method calls it.
This method should be called only once
This method is used by Initialize but can be used when separating options initialization from the rest of the initialization.
If options is nullptr, then this method internally creates and uses an internal vtkCLIOptions instance. In that case, extra / unknown arguments are simply ignored.
This method is used by Initialize but can be used when separating options initialization from the rest of the initialization, in combination with InitializeOtherOptions.
Returns true on success, false otherwise. When false, use GetExitCode to obtain the exit code. Note, for options that cause early exit of the program like --help, --version etc, this method returns false with exit-code set to 0.
This method is used by Initialize but can be used when separating options initialization from the rest of the initialization, in combination with InitializeGlobalOptions.
This method call InitializeProcessModule, then initialize all options.
Assume that InitializeProcessModule has been called.
If defaultCoreConfig is set to true, this will use the setting to set default values on the vtkRemotingCoreConfiguration
This method always returns true.
Assume that InitializeProcessModule has been called. Returns true on success, false otherwise.
Make sure that the vtkPythonInterpreter has been initialized before calling this function.
Do not use the server manager after calling this.
inlinestatic |
Definition at line 182 of file vtkInitializationHelper.h.
This is needed to insure that linker does not remove object factories' auto init during static linking. It also cleans up after protobuf.
To disable this processing of the settings file for an application (e.g. in Catalyst), turn this off. On by default.
This is "ParaView" by default, but can be different for branded applications.
The last character is always the file path separator appropriate for the system.
staticprotected |
