runtime configuration options for vtkRemotingCore module. More...
#include <vtkRemotingCoreConfiguration.h>
| virtual bool | GetTellVersion () |
| Flag set when user expects the executable to simply print out the version number and exit. More... | |
| virtual bool | GetDisableRegistry () |
| Get whether to load user-specific session/configuration files from previous session or start the application using default configuration. More... | |
| virtual bool | GetPrintMonitors () |
| Print monitor information and exit. More... | |
| virtual std::string | GetServerURL () |
| On client processes, this returns the server connection url to use to connect to the server process(es) on startup, if any. More... | |
| virtual std::string | GetServerResourceName () |
| On client processes, this returns the server connection resource name to use to connect to the server process(es) on startup, if any. More... | |
| const std::vector< std::string > & | GetServerConfigurationsFiles () const |
| On client processes, this provides list of server configurations files to use instead of the default user-specific server configurations file. More... | |
| const std::vector< std::string > & | GetPluginSearchPaths () const |
| Get a list of paths to add to plugin search paths. More... | |
| const std::vector< std::string > & | GetPlugins () const |
| Get a list of names for plugins to load. More... | |
| virtual bool | GetUseStereoRendering () |
| Get whether stereo rendering is enabled. More... | |
| virtual int | GetStereoType () |
| Get stereo type requested. More... | |
| const char * | GetStereoTypeAsString () const |
| double | GetEyeSeparation () const |
| Eye separation to use when using stereo rendering. More... | |
| virtual int * | GetTileMullions () |
| Get the gap in pixel between tiles in a tile display. More... | |
| virtual void | GetTileMullions (int &, int &) |
| virtual void | GetTileMullions (int [2]) |
| void | GetTileDimensions (int dims[2]) |
| Get the dimensions of the tile display. More... | |
| const int * | GetTileDimensions () |
| bool | GetIsInTileDisplay () const |
| Returns true if in tile display mode. More... | |
| bool | GetIsInCave () const |
| Returns true of in CAVE mode. More... | |
| vtkDisplayConfiguration * | GetDisplayConfiguration () const |
| When in CAVE mode, returns the display configurations. More... | |
| virtual bool | GetDisableXDisplayTests () |
| XDisplay test on server processes during initialization sometimes happens too early and may result in remote rendering prematurely disabled. More... | |
| virtual bool | GetForceOffscreenRendering () |
| When set to true, ParaView will create headless only render windows on the current process. More... | |
| virtual bool | GetForceOnscreenRendering () |
| When set to true, ParaView will create on-screen render windows. More... | |
| int | GetEGLDeviceIndex () |
| Returns the EGL device index for the current process. More... | |
| std::string | GetDisplay () |
| Returns the display setting, if any, for the current process. More... | |
| virtual bool | GetMultiServerMode () |
| Returns true on client process if it should enable connecting to multiple servers at the same time. More... | |
| virtual bool | GetMultiClientMode () |
| Returns true data server process if the server should allow connecting to multiple clients in a collaboration mode. More... | |
| virtual bool | GetDisableFurtherConnections () |
| Returns if this server does not allow connection after the first client. More... | |
| bool | PopulateOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType) |
| Populates vtkCLIOptions with available command line options. More... | |
| bool | PopulateGlobalOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType) |
| bool | PopulateConnectionOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType) |
| bool | PopulatePluginOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType) |
| bool | PopulateRenderingOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType) |
| bool | PopulateMiscellaneousOptions (vtkCLIOptions *app, vtkProcessModule::ProcessTypes processType) |
| void | HandleDisplayEnvironment () |
| Method to setup environment variables for display. More... | |
| virtual void | SetHostName (std::string) |
| Set/Get the hostname to use. More... | |
| virtual std::string | GetHostName () |
| virtual void | SetClientHostName (std::string) |
| Set/Get the hostname for the "client" process. More... | |
| virtual std::string | GetClientHostName () |
| virtual void | SetServerPort (int) |
| Set/Get the server-port number to use. More... | |
| virtual int | GetServerPort () |
| virtual void | SetBindAddress (std::string) |
| Set/Get the address the server socket is bound to. More... | |
| virtual std::string | GetBindAddress () |
| virtual void | SetReverseConnection (bool) |
| Set/Get if the process is acting in reverse connection mode. More... | |
| virtual bool | GetReverseConnection () |
| virtual void | SetConnectID (int) |
| Set/Get the connection identifier used to validate client-server connections. More... | |
| virtual int | GetConnectID () |
| virtual void | SetTimeout (int) |
| Set/Get the expected infrastructure imposed timeout of the server. More... | |
| virtual int | GetTimeout () |
| virtual void | SetTimeoutCommand (std::string) |
| Set/Get the timeout command, called regularly on server side and giving remaining time available for server access. More... | |
| virtual std::string | GetTimeoutCommand () |
| virtual void | SetTimeoutCommandInterval (int) |
Set/Get the interval in seconds between consecutive calls of TimeoutCommand, on the server. More... | |
| virtual int | GetTimeoutCommandInterval () |
| static vtkRemotingCoreConfiguration * | SafeDownCast (vtkObject *o) |
| static vtkRemotingCoreConfiguration * | GetInstance () |
| Provides access to the singleton. More... | |
| vtkRemotingCoreConfiguration () | |
| ~vtkRemotingCoreConfiguration () override | |
vtkRemotingCoreConfiguration is a singleton that maintains runtime configuration for the process. These can be thought of as options settable by command line arguments and hence are initialized when the process launches and are not changed during the lifetime of the process.
vtkRemotingCoreConfiguration can be setup via command line arguments. For that, create a vtkCLIOptions object and populate it using PopulateOptions method. vtkCLIOptions can then pass command line arguments for parsing.
Definition at line 30 of file vtkRemotingCoreConfiguration.h.
Definition at line 33 of file vtkRemotingCoreConfiguration.h.
This is currently only supported on Windows.
By default, this is initialized to the hostname determined automatically using system calls (specifically, vtksys::SystemInformation). Default is "localhost".
This is used by server processes when in reverse-connection mode to determine where the client can be reached. Default is "localhost".
This is the port number that a server-process is expected to use as the 'listening' port. For reverse-connection, this is the port number that the client process is listening on. Default is 0 but this value will be computed depending on the process type when populating options.
Default is "0.0.0.0"
This flag is only read on the server processes since client is capable of supported reverse and non-reverse connections in the same process. Default is false.
Default is 0.
Default is 0.
Timeout <= 0 means no timeout. Default is 0.
Default is empty string.
Default is 60.
Default is 60.
Definition at line 179 of file vtkRemotingCoreConfiguration.h.
Any plugin requested by name will be searched under these paths.
Definition at line 194 of file vtkRemotingCoreConfiguration.h.
Definition at line 199 of file vtkRemotingCoreConfiguration.h.
This is only valid on rendering processes.
Returned values are VTK_STEREO_* defined in vtkRenderWindow.h.
| const char* vtkRemotingCoreConfiguration::GetStereoTypeAsString | ( | ) | const |
| double vtkRemotingCoreConfiguration::GetEyeSeparation | ( | ) | const |
| void vtkRemotingCoreConfiguration::GetTileDimensions | ( | int | dims[2] | ) |
| bool vtkRemotingCoreConfiguration::GetIsInTileDisplay | ( | ) | const |
| bool vtkRemotingCoreConfiguration::GetIsInCave | ( | ) | const |
Definition at line 248 of file vtkRemotingCoreConfiguration.h.
When this flag is set, ParaView will skip such X-display tests. Note, if the display is truly inaccessible when ParaView tries to connect to the server, we will indeed get runtimes errors, including segfaults.
| int vtkRemotingCoreConfiguration::GetEGLDeviceIndex | ( | ) |
This uses vtkMultiProcessController::GetLocalProcessId to determine the rank of the process. -1 indicates no index was specified.
| std::string vtkRemotingCoreConfiguration::GetDisplay | ( | ) |
This requires MultiClientMode.
| bool vtkRemotingCoreConfiguration::PopulateOptions | ( | vtkCLIOptions * | app, |
| vtkProcessModule::ProcessTypes | processType | ||
processType indicates which type of ParaView process the options are being setup for. That may affect available options.
| bool vtkRemotingCoreConfiguration::PopulateGlobalOptions | ( | vtkCLIOptions * | app, |
| bool vtkRemotingCoreConfiguration::PopulateConnectionOptions | ( | vtkCLIOptions * | app, |
| bool vtkRemotingCoreConfiguration::PopulatePluginOptions | ( | vtkCLIOptions * | app, |
| bool vtkRemotingCoreConfiguration::PopulateRenderingOptions | ( | vtkCLIOptions * | app, |
| bool vtkRemotingCoreConfiguration::PopulateMiscellaneousOptions | ( | vtkCLIOptions * | app, |
| void vtkRemotingCoreConfiguration::HandleDisplayEnvironment | ( | ) |
