pqServerConfiguration corresponds to a server connection configuration. More...
#include <pqServerConfiguration.h>
| enum | StartupType { INVALID, MANUAL, COMMAND } |
| Types of start. More... | |
| pqServerConfiguration () | |
| Create an empty server configuration with the default name. More... | |
| ~pqServerConfiguration () | |
| Default destructor. More... | |
| pqServerConfiguration (const QString &name) | |
| Create an empty server configuration with a provided name. More... | |
| pqServerConfiguration (vtkPVXMLElement *xml) | |
| Create a server configuration with the provided xml. More... | |
| bool | isMutable () const |
| Get/Set whether the configuration is mutable. More... | |
| void | setMutable (bool val) |
| void | setName (const QString &name) |
| Get/Set the name for the configuration. More... | |
| QString | name () const |
| bool | isNameDefault () const |
| Returns true if the name for this configuration is the default one i.e. More... | |
| pqServerResource | resource () const |
| Get/Set the resource that describes the server scheme, hostname(s) and port(s). More... | |
| void | setResource (const QString &) |
| void | setResource (const pqServerResource &) |
| pqServerResource | actualResource () |
| Get the actual resource that describes the server scheme, hostname(s) and port(s). More... | |
| QString | URI () const |
| get the resource URI, does not contain the server name More... | |
| int | connectionTimeout (int defaultTimeout=60) const |
| Get/Set the timeout in seconds that will be used when connecting 0 means no retry and -1 means infinite retries. More... | |
| void | setConnectionTimeout (int connectionTimeout) |
| StartupType | startupType () const |
| returns the startup type for this configuration. More... | |
| QString | command (double &processWait, double &delay) const |
| If startupType() == COMMAND, then this method can be used to obtain the command for the startup, from the client side. More... | |
| QString | execCommand (double &processWait, double &delay) const |
| If startupType() == COMMAND, then this method can be used to obtain the command for the startup, on the remote server, contained in the exec attributes. More... | |
| void | setStartupToManual () |
| changes the startup type to manual. More... | |
| void | setStartupToCommand (double processWait, double delay, const QString &command) |
| changes the startup type to command. More... | |
| QString | toString (vtkIndent indent) const |
| serialize to a string. More... | |
| pqServerConfiguration | clone () const |
| Create a new clone (deep copying the vtkPVXMLElement). More... | |
| vtkPVXMLElement * | optionsXML () const |
| returns the <Options> element, if any. More... | |
| vtkPVXMLElement * | hintsXML () const |
| returns the <Hints> element, if any. More... | |
| bool | isPortForwarding () const |
| Get if this is a port forwarding configuration. More... | |
| QString | portForwardingLocalPort () const |
| Get the port forwarding local port. More... | |
| static QString | defaultName () |
| Returns the default name of a server configuration. More... | |
| vtkPVXMLElement * | startupXML () const |
| void | parseSshPortForwardingXML () |
| QString | sshFullCommand (QString sshCommand, vtkPVXMLElement *sshConfigXML) const |
Static Protected Member Functions | |
| static QString | termCommand () |
| static QString | sshCommand () |
| static QString | lookForCommand (QString command) |
These are typically read from pvsc files.
Definition at line 21 of file pqServerConfiguration.h.
Types of start.
| Enumerator | |
| INVALID | |
| MANUAL | |
| COMMAND | |
Definition at line 103 of file pqServerConfiguration.h.
| pqServerConfiguration::pqServerConfiguration | ( | ) |
| pqServerConfiguration::~pqServerConfiguration | ( | ) |
Default destructor.
| pqServerConfiguration::pqServerConfiguration | ( | const QString & | name | ) |
| pqServerConfiguration::pqServerConfiguration | ( | vtkPVXMLElement * | xml | ) |
This variable is not serialized.
Definition at line 48 of file pqServerConfiguration.h.
Definition at line 49 of file pqServerConfiguration.h.
| void pqServerConfiguration::setName | ( | const QString & | name | ) |
| QString pqServerConfiguration::name | ( | ) | const |
| bool pqServerConfiguration::isNameDefault | ( | ) | const |
the one that gets set when none is specified. Useful to determine "empty" configurations.
| pqServerResource pqServerConfiguration::resource | ( | ) | const |
| void pqServerConfiguration::setResource | ( | const QString & | ) |
| void pqServerConfiguration::setResource | ( | const pqServerResource & | ) |
| pqServerResource pqServerConfiguration::actualResource | ( | ) |
Can be different from resource() when using SSH Port Forwarding as it will point to ip and port actually used for the tcp connection, which can be different than the server where the pvserver is running. eg. it will give you localhost:8080, instead of serverip:serverport when using port forwarding. Using this method is needed only when using low level tcp api. resource() method should be used in any other cases.
| QString pqServerConfiguration::URI | ( | ) | const |
If not set in the XML, the defaultTimeout is retuned.
| void pqServerConfiguration::setConnectionTimeout | ( | int | connectionTimeout | ) |
| StartupType pqServerConfiguration::startupType | ( | ) | const |
There are 3 types of startup: manual, simple-command and custom-command.
Note that this does not include any information options etc. that may be specified in the startup. This is the full command to be executed on the client, which includes xterm, ssh... This also recovers processWait and delay attributes. processWait is the amount of time to wait for the process to start in seconds. delay is the amount of time wait for the process to finish, -1 means infinite wait.
Note that this does not include any information options etc. that may be specified in the startup. This also recovers processWait and delay attributes. processWait is the amount of time to wait for the process to start in seconds. delay is the amount of time wait for the process to finish, -1 means infinite wait.
| void pqServerConfiguration::setStartupToManual | ( | ) |
| void pqServerConfiguration::setStartupToCommand | ( | double | processWait, |
| double | delay, | ||
| const QString & | command | ||
| QString pqServerConfiguration::toString | ( | vtkIndent | indent | ) | const |
| pqServerConfiguration pqServerConfiguration::clone | ( | ) | const |
| vtkPVXMLElement* pqServerConfiguration::optionsXML | ( | ) | const |
| vtkPVXMLElement* pqServerConfiguration::hintsXML | ( | ) | const |
PortForwardingConfiguration uses SSH tunneling and is configured directly in xml server file
Definition at line 176 of file pqServerConfiguration.h.
| QString pqServerConfiguration::portForwardingLocalPort | ( | ) | const |
Initialized by the server xml if port forwarding is used. Equal to the resource port if port forwarding is not used.
staticprotected |
staticprotected |
staticprotected |
