pqApplyBehavior collects the logic that needs to happen after the user hits "Apply" on the pqPropertiesPanel. More...
#include <pqApplyBehavior.h>
Inherits QObject.
Signals | |
| void | triggerApply () |
| pqApplyBehavior (QObject *parent=nullptr) | |
| ~pqApplyBehavior () override | |
| void | registerPanel (pqPropertiesPanel *panel) |
| Register/unregister pqPropertiesPanel instances to monitor. More... | |
| void | unregisterPanel (pqPropertiesPanel *panel) |
| static void | hideInputIfRequired (pqPipelineFilter *filter, pqView *view) |
Protected Slots | |
| virtual void | applied (pqPropertiesPanel *panel, pqProxy *proxy) |
| virtual void | applied (pqPropertiesPanel *panel=nullptr) |
| virtual void | showData (pqPipelineSource *source, pqView *view) |
Since "Apply" is an important concept in ParaView application, it gets its own behavior so applications can customize it, if needed.
pqApplyBehavior can work with or without registered pqPropertiesPanel. One could still manually register any pqPropertiesPanel instance(s). pqParaViewBehaviors does that automatically for pqPropertiesPanel instances available during the startup.
This behavior is also responsible for managing the AutoApply mechanism with is controllable using vtkPVGeneralSettings
Definition at line 32 of file pqApplyBehavior.h.
| pqApplyBehavior::pqApplyBehavior | ( | QObject * | parent = nullptr | ) |
| void pqApplyBehavior::registerPanel | ( | pqPropertiesPanel * | panel | ) |
| void pqApplyBehavior::unregisterPanel | ( | pqPropertiesPanel * | panel | ) |
signal |
protectedvirtualslot |
protectedvirtual |
