Classes | Macros
vtkPVStringFormatter.h File Reference
#include "vtkLogger.h"
#include "vtkObject.h"
#include "vtkPVVTKExtensionsCoreModule.h"
#include <algorithm>
#include <memory>
#include <sstream>
#include <stack>
#include <vtk_fmt.h>
#include <VTK_FMT(fmt/args.h)>
#include <VTK_FMT(fmt/chrono.h)>
#include <VTK_FMT(fmt/core.h)>
#include <VTK_FMT(fmt/ranges.h)>
Include dependency graph for vtkPVStringFormatter.h:
class  vtkPVStringFormatter
 Utility class used for string formatting. More...
class  vtkPVStringFormatter::TraceScope
 This subclass should ONLY be used to enable automatic push/pop of argument scopes in the same scope of code. More...
struct  vtkPVStringFormatter::vtkNamedArgument::Value
Macros
#define PV_STRING_FORMATTER_SCOPE_0(x, y)   x##y
#define PV_STRING_FORMATTER_SCOPE_1(x, y)   PV_STRING_FORMATTER_SCOPE_0(x, y)
#define PV_STRING_FORMATTER_SCOPE(...)   vtkPVStringFormatter::TraceScope PV_STRING_FORMATTER_SCOPE_1(_trace_item, __LINE__)(__VA_ARGS__)
#define PV_STRING_FORMATTER_NAMED_SCOPE(NAME, ...)
Macro Definition Documentation
◆ PV_STRING_FORMATTER_SCOPE_0
#define PV_STRING_FORMATTER_SCOPE_0 (   x,
  y
)    x##y
Definition at line 534 of file vtkPVStringFormatter.h.
◆ PV_STRING_FORMATTER_SCOPE_1
#define PV_STRING_FORMATTER_SCOPE_1 (   x,
  y
Definition at line 535 of file vtkPVStringFormatter.h.
#define PV_STRING_FORMATTER_SCOPE (   ...)    vtkPVStringFormatter::TraceScope PV_STRING_FORMATTER_SCOPE_1(_trace_item, __LINE__)(__VA_ARGS__)
Definition at line 536 of file vtkPVStringFormatter.h.
◆ PV_STRING_FORMATTER_NAMED_SCOPE
#define PV_STRING_FORMATTER_NAMED_SCOPE (   NAME,
Value:
NAME, __VA_ARGS__)
Definition at line 538 of file vtkPVStringFormatter.h.
This subclass should ONLY be used to enable automatic push/pop of argument scopes in the same scope o...
Definition: vtkPVStringFormatter.h:44
Definition: vtkPVStringFormatter.h:535
