vtkPVRenderViewDataDeliveryManager.h
11 #ifndef vtkPVRenderViewDataDeliveryManager_h
12 #define vtkPVRenderViewDataDeliveryManager_h
13
14 #include "vtkBoundingBox.h" // needed for iVar.
16 #include "vtkRemotingViewsModule.h" //needed for exports
17 #include "vtkSmartPointer.h" // needed for iVar.
18 #include "vtkTuple.h" // needed for vtkTuple.
19 #include "vtkWeakPointer.h" // needed for iVar.
20
21 class vtkAlgorithmOutput;
22 class vtkDataObject;
24 class vtkInformation;
25 class vtkMatrix4x4;
27 class vtkPVView;
28
29 #include <vector> // for std::vector
30
31 class VTKREMOTINGVIEWS_EXPORT vtkPVRenderViewDataDeliveryManager : public vtkPVDataDeliveryManager
32 {
33 public:
36  void PrintSelf(ostream& os, vtkIndent indent) override;
37
45  void SetDeliverToAllProcesses(vtkPVDataRepresentation*, bool flag, bool low_res, int port = 0);
46
57  void SetDeliverToClientAndRenderingProcesses(vtkPVDataRepresentation*, bool deliver_to_client,
58  bool gather_before_delivery, bool low_res, int port = 0);
59
61
69  void SetRedistributionMode(vtkPVDataRepresentation*, int mode, int port = 0);
70  void SetRedistributionModeToSplitBoundaryCells(vtkPVDataRepresentation* repr, int port = 0);
71  void SetRedistributionModeToDuplicateBoundaryCells(vtkPVDataRepresentation* repr, int port = 0);
72  void SetRedistributionModeToUniquelyAssignBoundaryCells(
73  vtkPVDataRepresentation* repr, int port = 0);
75
80  void RedistributeDataForOrderedCompositing(bool use_lod);
81
88  void ClearRedistributedData(bool use_load);
89
94  void SetOrderedCompositingConfiguration(
95  vtkPVDataRepresentation* repr, int config, const double* bds, int port = 0);
96
98
101  void SetGeometryBounds(vtkPVDataRepresentation* repr, const double bds[6],
102  vtkMatrix4x4* matrix = nullptr, int port = 0);
103  vtkBoundingBox GetGeometryBounds(vtkPVDataRepresentation* repr, int port = 0);
104  vtkBoundingBox GetTransformedGeometryBounds(vtkPVDataRepresentation* repr, int port = 0);
106
107  // *******************************************************************
108  // UNDER CONSTRUCTION STREAMING API
109  // *******************************************************************
110
116  void SetStreamable(vtkPVDataRepresentation*, bool, int port = 0);
117
119
123  void SetNextStreamedPiece(vtkPVDataRepresentation* repr, vtkDataObject* piece, int port = 0);
124  vtkDataObject* GetCurrentStreamedPiece(vtkPVDataRepresentation* repr, int port = 0);
125  void ClearStreamedPieces();
127
133  void DeliverStreamedPieces(unsigned int size, unsigned int* keys);
134
139  bool GetRepresentationsReadyToStreamPieces(std::vector<unsigned int>& keys);
140
142
146  vtkGetMacro(UseRedistributedDataAsDeliveredData, bool);
147  vtkSetMacro(UseRedistributedDataAsDeliveredData, bool);
149
150  int GetDeliveredDataKey(bool low_res) const override;
151
153
159  const std::vector<vtkBoundingBox>& GetCuts() const { return this->Cuts; }
160  vtkTimeStamp GetCutsMTime() const { return this->CutsMTime; }
162
164
174  const std::vector<vtkBoundingBox>& GetRawCuts() const { return this->RawCuts; }
175  const std::vector<int>& GetRawCutsRankAssignments() const { return this->RawCutsRankAssignments; }
177
178 protected:
181
182  void MoveData(vtkPVDataRepresentation* repr, bool low_res, int port) override;
183
184  int GetViewDataDistributionMode(bool low_res) const;
185  int GetMoveMode(vtkInformation* info, int viewMode) const;
186
187  std::vector<vtkBoundingBox> Cuts;
188  std::vector<vtkBoundingBox> RawCuts;
189  std::vector<int> RawCutsRankAssignments;
191
194  bool UseRedistributedDataAsDeliveredData = false;
195
196 private:
198  void operator=(const vtkPVRenderViewDataDeliveryManager&) = delete;
199 };
200
201 #endif
vtkPVDataDeliveryManager.h
vtkPVRenderViewDataDeliveryManager::GetCutsMTime
Provides access to the "cuts" built by this class when doing ordered compositing.
Definition: vtkPVRenderViewDataDeliveryManager.h:160
vtkPVDataDeliveryManager::PrintSelf
vtkPVRenderViewDataDeliveryManager::RawCuts
std::vector< vtkBoundingBox > RawCuts
Definition: vtkPVRenderViewDataDeliveryManager.h:188
vtkObject::New
static vtkObject * New()
vtkTimeStamp
vtkPVDataDeliveryManager::GetDeliveredDataKey
virtual int GetDeliveredDataKey(bool low_res) const
Views that support changing of which ranks do the rendering at runtime based on things like data size...
Definition: vtkPVDataDeliveryManager.h:154
vtkPVRenderView specific subclass of vtkPVDataDeliveryManager.
Definition: vtkPVRenderViewDataDeliveryManager.h:31
vtkPVRenderViewDataDeliveryManager::CutsMTime
vtkTimeStamp CutsMTime
Definition: vtkPVRenderViewDataDeliveryManager.h:190
vtkPVView
baseclass for all ParaView views.
Definition: vtkPVView.h:32
vtkBoundingBox
vtkExtentTranslator
vtkPVRenderViewDataDeliveryManager::LastCutsGeneratorToken
std::string LastCutsGeneratorToken
Definition: vtkPVRenderViewDataDeliveryManager.h:193
vtkIndent
vtkMatrix4x4
vtkPVRenderViewDataDeliveryManager::GetRawCutsRankAssignments
const std::vector< int > & GetRawCutsRankAssignments() const
When using an internally generated kd-tree for ordered compositing, this method provides access to th...
Definition: vtkPVRenderViewDataDeliveryManager.h:175
vtkSmartPointer.h
std::vector< vtkBoundingBox > Cuts
Definition: vtkPVRenderViewDataDeliveryManager.h:187
vtkWeakPointer.h
vtkPVDataDeliveryManager::MoveData
virtual void MoveData(vtkPVDataRepresentation *repr, bool low_res, int port)=0
This method is called to request that the subclass do appropriate transfer for the indicated represen...
const std::vector< vtkBoundingBox > & GetCuts() const
Definition: vtkPVRenderViewDataDeliveryManager.h:159
vtkBoundingBox.h
vtkPVRenderViewDataDeliveryManager::RawCutsRankAssignments
std::vector< int > RawCutsRankAssignments
Definition: vtkPVRenderViewDataDeliveryManager.h:189
vtkInformation
vtkTuple.h
vtkPVRenderViewDataDeliveryManager::RedistributionTimeStamp
vtkTimeStamp RedistributionTimeStamp
Definition: vtkPVRenderViewDataDeliveryManager.h:192
vtkAlgorithmOutput
Definition: vtkPVDataRepresentation.h:23
vtkDataObject
const std::vector< vtkBoundingBox > & GetRawCuts() const
Definition: vtkPVRenderViewDataDeliveryManager.h:174
manager for data-delivery.
Definition: vtkPVDataDeliveryManager.h:35
