vtkPVOrthographicSliceView.h
22 #ifndef vtkPVOrthographicSliceView_h
23 #define vtkPVOrthographicSliceView_h
24
25 #include "vtkPVMultiSliceView.h"
26
27 class vtkPVOrthographicSliceViewInteractorStyle;
28
29 class VTKREMOTINGVIEWS_EXPORT vtkPVOrthographicSliceView : public vtkPVMultiSliceView
30 {
31 public:
34  void PrintSelf(ostream& os, vtkIndent indent) override;
35
40  void Update() override;
41
42  enum
43  {
44  SAGITTAL_VIEW_RENDERER = vtkPVRenderView::NON_COMPOSITED_RENDERER + 1,
47  };
48
52  vtkRenderer* GetRenderer(int rendererType = vtkPVRenderView::DEFAULT_RENDERER) override;
53
54  virtual void ResetCamera();
55  virtual void ResetCamera(double bounds[6]);
56  void SetInteractionMode(int mode) override;
58
60
63  void SetSlicePosition(double x, double y, double z);
64  vtkGetVector3Macro(SlicePosition, double);
66
68
71  vtkSetVector3Macro(SliceIncrements, double);
73
75
78  vtkSetMacro(SliceAnnotationsVisibility, bool);
79  vtkGetMacro(SliceAnnotationsVisibility, bool);
81
85  void SetCenterAxesVisibility(bool) override {}
86
87  //*****************************************************************
88  void SetBackgroundTexture(vtkTexture* val) override;
89
93  void ScaleRendererViewports(const double viewport[4]) override;
94
95 protected:
97  ~vtkPVOrthographicSliceView() override;
98
99  void AboutToRenderOnLocalProcess(bool interactive) override;
100  void UpdateCenterAxes() override;
101
102  //*****************************************************************
103  // Forward to vtkPVOrthographicSliceView instances.
104  void SetCenterOfRotation(double x, double y, double z) override;
105  void SetRotationFactor(double factor) override;
106
111
115  void UpdateBackground(vtkRenderer* renderer = nullptr) override;
116
117  enum
118  {
119  SIDE_VIEW = 0,
120  TOP_VIEW = 1,
121  FRONT_VIEW = 2,
122
123  YZ_PLANE = SIDE_VIEW,
124  ZX_PLANE = TOP_VIEW,
125  XY_PLANE = FRONT_VIEW,
126
127  AXIAL_VIEW = TOP_VIEW,
128  CORONAL_VIEW = FRONT_VIEW,
129  SAGITTAL_VIEW = SIDE_VIEW,
130
131  RIGHT_SIDE_VIEW = SIDE_VIEW
132  };
133
134  vtkNew<vtkRenderer> Renderers[3];
136  vtkNew<vtkPVCenterAxesActor> SlicePositionAxes2D[3];
138  vtkNew<vtkTextRepresentation> SliceAnnotations[3];
140
141  double SliceIncrements[3];
142  double SlicePosition[3];
144
145 private:
147  void operator=(const vtkPVOrthographicSliceView&) = delete;
148
149  void OnMouseWheelForwardEvent();
150  void OnMouseWheelBackwardEvent();
151  void MoveSlicePosition(vtkRenderer* ren, double position[3]);
152
153  unsigned long MouseWheelForwardEventId;
154  unsigned long MouseWheelBackwardEventId;
155
156  friend class vtkPVOrthographicSliceViewInteractorStyle;
157
158  bool GridAxes3DActorsNeedShallowCopy;
159  unsigned long GridAxes3DActorObserverId;
160  void OnGridAxes3DActorModified();
161 };
162
163 #endif
vtkPVRenderView::SetBackgroundTexture
virtual void SetBackgroundTexture(vtkTexture *val)
Forward to 3D renderer.
vtkPVMultiSliceView
Definition: vtkPVMultiSliceView.h:21
vtkPVRenderView::UpdateBackground
virtual void UpdateBackground(vtkRenderer *renderer=nullptr)
Updates background color.
vtkPVRenderView::SetInteractionMode
virtual void SetInteractionMode(int mode)
Get/Set the interaction mode.
vtkPVOrthographicSliceView::AXIAL_VIEW_RENDERER
@ AXIAL_VIEW_RENDERER
Definition: vtkPVOrthographicSliceView.h:45
@ DEFAULT_RENDERER
Definition: vtkPVRenderView.h:121
vtkPVMultiSliceView::AboutToRenderOnLocalProcess
Called just before the local process renders.
vtkPVRenderView::SetRotationFactor
virtual void SetRotationFactor(double factor)
Forward to vtkPVInteractorStyle instances.
vtkPVOrthographicSliceView::OrthographicInteractorStyle
vtkNew< vtkPVOrthographicSliceViewInteractorStyle > OrthographicInteractorStyle
Definition: vtkPVOrthographicSliceView.h:135
vtkSmartPointer< vtkPVGridAxes3DActor >
vtkPVOrthographicSliceView::SliceAnnotationsVisibility
bool SliceAnnotationsVisibility
Definition: vtkPVOrthographicSliceView.h:143
vtkPVRenderView::ResetCamera
void ResetCamera()
Resets the active camera using collective prop-bounds.
vtkPVRenderView::GetRenderer
virtual vtkRenderer * GetRenderer(int rendererType=DEFAULT_RENDERER)
Returns the renderer given an int identifying its type.
vtkPVRenderView::UpdateCenterAxes
virtual void UpdateCenterAxes()
UpdateCenterAxes().
ParaView extensions for vtkGridAxes3DActor.
Definition: vtkPVGridAxes3DActor.h:34
vtkTexture
vtkPVMultiSliceView::PrintSelf
@ NON_COMPOSITED_RENDERER
Definition: vtkPVRenderView.h:122
vtkPVRenderView::SetCenterOfRotation
virtual void SetCenterOfRotation(double x, double y, double z)
vtkIndent
vtkPVRenderView::ScaleRendererViewports
Overridden to scale the OrientationWidget appropriately.
vtkNew< vtkRenderer >
view with 3 orthographic slice views and 1 3D view.
Definition: vtkPVOrthographicSliceView.h:29
vtkRenderWindowInteractor
vtkPVOrthographicSliceView::SlicePositionAxes3D
vtkNew< vtkPVCenterAxesActor > SlicePositionAxes3D
Definition: vtkPVOrthographicSliceView.h:137
vtkPVRenderView::SetGridAxes3DActor
virtual void SetGridAxes3DActor(vtkPVGridAxes3DActor *)
Set the vtkPVGridAxes3DActor to use for the view.
vtkPVOrthographicSliceView::CORONAL_VIEW_RENDERER
@ CORONAL_VIEW_RENDERER
Definition: vtkPVOrthographicSliceView.h:46
vtkRenderer
vtkPVOrthographicSliceView::SetCenterAxesVisibility
To avoid confusion, we don't show the center axes at all in this view.
Definition: vtkPVOrthographicSliceView.h:85
vtkPVRenderView::SetupInteractor
virtual void SetupInteractor(vtkRenderWindowInteractor *)
Set the interactor.
vtkPVMultiSliceView::New
static vtkPVMultiSliceView * New()
vtkPVMultiSliceView::Update
