pqLinkedObjectQTextEdit implements the pqLinkedObjectInterface for a QTextEdit More...
#include <pqLinkedObjectQTextEdit.h>
| pqLinkedObjectQTextEdit ()=delete | |
| Default constructor is deleted. More... | |
| pqLinkedObjectQTextEdit (QTextEdit &textEdit) noexcept | |
| Constructor that takes the QTextEdit as parameter. More... | |
| pqLinkedObjectQTextEdit (const pqLinkedObjectQTextEdit &other) noexcept | |
| Copy constructor. More... | |
| ~pqLinkedObjectQTextEdit () noexcept override | |
| Destructor that unlink this object on deletion. More... | |
| std::unique_ptr< pqLinkedObjectInterface > | clone () const override |
| Constructs a new instance of pqLinkedObjectQTextEdit using the default copy constructor of this class. More... | |
| void | link (pqLinkedObjectInterface *other) override |
| Link this object to the other. More... | |
| void | unlink () override |
| Unlink this object with the other. More... | |
| void | setText (const QString &txt) override |
| See pqLinkedObjectInterface::setText. More... | |
| QString | getText () const override |
| See pqLinkedObjectInterface::getText. More... | |
| QObject * | getLinked () const noexcept override |
| See pqLinkedObjectInterface::getLinked. More... | |
| QString | getName () const override |
| See pqLinkedObjectInterface::getName. More... | |
Public Member Functions inherited from pqLinkedObjectInterface | |
| pqLinkedObjectInterface ()=default | |
| pqLinkedObjectInterface (const pqLinkedObjectInterface &)=default | |
| Copy constructor needed for the clone method. More... | |
| virtual | ~pqLinkedObjectInterface () noexcept=default |
| Default virtual destructor. More... | |
| bool | isLinked () const noexcept |
| Returns true if this object is connected to another one. More... | |
Public Attributes | |
| QTextEdit & | TextEdit |
Public Types inherited from pqLinkedObjectInterface | |
| enum | QtSignalState : bool { QtSignalState::On = true, QtSignalState::Off = false } |
| Used to trigger on and off an object signal. More... | |
Protected Attributes inherited from pqLinkedObjectInterface | |
| pqLinkedObjectInterface * | ConnectedTo = nullptr |
| QMetaObject::Connection | Connection |
| bool | SettingText = false |
Definition at line 16 of file pqLinkedObjectQTextEdit.h.
delete |
inlineexplicitnoexcept |
Definition at line 26 of file pqLinkedObjectQTextEdit.h.
Copy constructor.
Do link the other object to this one if it exists
Definition at line 34 of file pqLinkedObjectQTextEdit.h.
inlineoverridenoexcept |
Definition at line 47 of file pqLinkedObjectQTextEdit.h.
inlineoverridevirtual |
Implements pqLinkedObjectInterface.
Reimplemented in pqLinkedObjectPythonTextArea.
Definition at line 53 of file pqLinkedObjectQTextEdit.h.
Note that the link is established if and only if the given pqLinkedObjectInterface is not nullptr.
overridevirtualnoexcept |
| QTextEdit& pqLinkedObjectQTextEdit::TextEdit |
Definition at line 89 of file pqLinkedObjectQTextEdit.h.
