The interface to a linked Qt text widget. More...
#include <pqLinkedObjectInterface.h>
| enum | QtSignalState : bool { QtSignalState::On = true, QtSignalState::Off = false } |
| Used to trigger on and off an object signal. More... | |
| pqLinkedObjectInterface ()=default | |
| pqLinkedObjectInterface (const pqLinkedObjectInterface &)=default | |
| Copy constructor needed for the clone method. More... | |
| virtual | ~pqLinkedObjectInterface () noexcept=default |
| Default virtual destructor. More... | |
| virtual std::unique_ptr< pqLinkedObjectInterface > | clone () const =0 |
| Pure virtual cloning this widget. More... | |
| virtual void | link (pqLinkedObjectInterface *other)=0 |
| Link this object to the other. More... | |
| virtual void | unlink ()=0 |
| Unlinks the objects. More... | |
| virtual void | setText (const QString &txt)=0 |
| Updates the object text. More... | |
| virtual QString | getText () const =0 |
| Returns the current buffer associated with this widget. More... | |
| virtual QObject * | getLinked () const noexcept=0 |
| Returns the linked QOBject. More... | |
| virtual QString | getName () const =0 |
| Returns the linked QObject name. More... | |
| bool | isLinked () const noexcept |
| Returns true if this object is connected to another one. More... | |
Protected Attributes | |
| pqLinkedObjectInterface * | ConnectedTo = nullptr |
| QMetaObject::Connection | Connection |
| bool | SettingText = false |
Derived classes should implement the proper behavior for all abstract functions.
The pqLinkedObjectInterface acts as an interface between two Qt text widgets that needs to be linked: when the associated text is updated the linked one gets updated too.
Definition at line 21 of file pqLinkedObjectInterface.h.
strong |
| Enumerator | |
| On | |
| Off | |
Definition at line 57 of file pqLinkedObjectInterface.h.
default |
Default constructor.
explicitdefault |
virtualdefaultnoexcept |
pure virtual |
Implemented in pqLinkedObjectQTextEdit, and pqLinkedObjectPythonTextArea.
pure virtual |
The expected behavior should be that when this object is updated, the other is too.
pure virtual |
Implemented in pqLinkedObjectQTextEdit.
pure virtual |
This effectively should override the current content of the widget
pure virtual |
pure virtualnoexcept |
pure virtual |
inlinenoexcept |
Definition at line 86 of file pqLinkedObjectInterface.h.
Definition at line 89 of file pqLinkedObjectInterface.h.
Definition at line 90 of file pqLinkedObjectInterface.h.
Definition at line 91 of file pqLinkedObjectInterface.h.
