vtkTrackballPan Class Reference
Pans camera with x y mouse movements. More...
#include <vtkTrackballPan.h>
Inheritance diagram for vtkTrackballPan:
Collaboration diagram for vtkTrackballPan:
typedef vtkCameraManipulator Superclass
- Public Types inherited from vtkCameraManipulator
void OnKeyUp (vtkRenderWindowInteractor *) override
void OnKeyDown (vtkRenderWindowInteractor *) override
void OnMouseMove (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) override
void OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) override
void OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren) override
- Public Member Functions inherited from vtkCameraManipulator
virtual void SetButton (int)
virtual int GetButton ()
virtual void SetShift (int)
virtual int GetShift ()
virtual void ShiftOn ()
virtual void ShiftOff ()
virtual void SetControl (int)
virtual int GetControl ()
virtual void ControlOn ()
virtual void ControlOff ()
virtual void SetCenter (double[3])
virtual double * GetCenter ()
virtual void GetCenter (double[3])
static vtkTrackballPan * New ()
static vtkTrackballPan * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCameraManipulator
static vtkCameraManipulator * New ()
static vtkCameraManipulator * SafeDownCast (vtkObject *o)
 vtkTrackballPan ()
 ~vtkTrackballPan () override
 vtkTrackballPan (const vtkTrackballPan &)=delete
void operator= (const vtkTrackballPan &)=delete
- Protected Member Functions inherited from vtkCameraManipulator
 vtkCameraManipulator ()
 ~vtkCameraManipulator () override
std::unique_ptr< Internal > Internals
- Protected Attributes inherited from vtkCameraManipulator
char * ManipulatorName
int Button
int Shift
int Control
double Center [3]
double RotationFactor
double DisplayCenter [2]
vtkTrackballPan allows the user to interactively manipulate the camera, the viewpoint of the scene. Moving the mouse down zooms in. Up zooms out. This manipulator has not been extended to parallel projection yet. It works in perspective by rotating the camera.
Definition at line 21 of file vtkTrackballPan.h.
Definition at line 25 of file vtkTrackballPan.h.
◆ vtkTrackballPan() [1/2]
vtkTrackballPan::vtkTrackballPan ( )
◆ ~vtkTrackballPan()
vtkTrackballPan::~vtkTrackballPan ( )
◆ vtkTrackballPan() [2/2]
vtkTrackballPan::vtkTrackballPan ( const vtkTrackballPan &  )
protecteddelete
static vtkTrackballPan* vtkTrackballPan::New ( )
virtual const char* vtkTrackballPan::GetClassName ( )
Reimplemented from vtkCameraManipulator.
static int vtkTrackballPan::IsTypeOf ( const char *  type)
virtual int vtkTrackballPan::IsA ( const char *  type)
static vtkTrackballPan* vtkTrackballPan::SafeDownCast ( vtkObject *  o)
void vtkTrackballPan::PrintSelf ( ostream &  os,
◆ OnKeyUp()
void vtkTrackballPan::OnKeyUp ( vtkRenderWindowInteractor *  iren)
These methods are called on all registered manipulators, not just the active one.
Hence, these should just be used to record state and not perform any interactions.
◆ OnKeyDown()
void vtkTrackballPan::OnKeyDown ( vtkRenderWindowInteractor *  iren)
◆ OnMouseMove()
void vtkTrackballPan::OnMouseMove ( int  x,
int  y,
vtkRenderer *  ren,
◆ OnButtonDown()
void vtkTrackballPan::OnButtonDown ( int  x,
int  y,
vtkRenderer *  ren,
◆ OnButtonUp()
void vtkTrackballPan::OnButtonUp ( int  x,
int  y,
vtkRenderer *  ren,
◆ operator=()
void vtkTrackballPan::operator= ( const vtkTrackballPan &  )
protecteddelete
◆ Internals
std::unique_ptr<Internal> vtkTrackballPan::Internals
Definition at line 48 of file vtkTrackballPan.h.
