| virtual void | UpdateGUI ()=0 |
| | Called by the manipulator to update the GUI. More...
| virtual int | GetActiveSourceBounds (double bounds[6])=0 |
| | Some interactors use the bounds of the active source. More...
| virtual int | GetActiveActorTranslate (double translate[3])=0 |
| | Called to get/set the translation for the actor for the active source in the active view. More...
| virtual int | SetActiveActorTranslate (double translate[3])=0 |
Helper class for Camera Manipulators.
This class is the interaface that defines API for a helper class used by some specialized camera manipulators that needed access to GUI. GUI implementations subclass this. vtkPVInteractorStyle sets the helper on every manipulator, if available so that the manipulator can use it.
- See also
- vtkPVInteractorStyle
Definition at line 23 of file vtkCameraManipulatorGUIHelper.h.
