Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Protected Attributes | List of all members
vtkTCPNetworkAccessManager Class Reference
#include <vtkTCPNetworkAccessManager.h>
Inheritance diagram for vtkTCPNetworkAccessManager:
Collaboration diagram for vtkTCPNetworkAccessManager:
typedef vtkNetworkAccessManager Superclass
- Public Types inherited from vtkNetworkAccessManager
enum  ConnectionResult {
  ConnectionResult::CONNECTION_SUCCESS, ConnectionResult::CONNECTION_TIMEOUT, ConnectionResult::CONNECTION_ABORT, ConnectionResult::CONNECTION_HANDSHAKE_ERROR,
  ConnectionResult::CONNECTION_FAILURE
 Possible result of connection when creating a new connection CONNECTION_SUCCESS: Connection was sucessfull CONNECTION_TIMEOUT: After spending a specified amount of time, no connection was initiated CONNECTION_ABORT: User aborted the connection before it was successful or timed out CONNECTION_HANDSHAKE_ERROR: Connection was iniated but the handshake failed CONNECTION_FAILURE: Unspecified connection error. More...
void AbortPendingConnection () override
 Used to abort pending connection creation, if any. More...
int ProcessEvents (unsigned long timeout_msecs) override
 Process any network activity. More...
bool GetNetworkEventsAvailable () override
 Peeks to check if any activity is available. More...
bool GetPendingConnectionsPresent () override
 Returns true is the manager is currently waiting for any connections. More...
void DisableFurtherConnections (int port, bool disable) override
 Enable/disable further connections for given port. More...
bool GetWrongConnectID () override
 Returns true if the last check of connect ids was wrong. More...
vtkMultiProcessController * NewConnection (const char *url, vtkNetworkAccessManager::ConnectionResult &result) override
 Creates a new connection given the url. More...
virtual vtkMultiProcessController * NewConnection (const char *url)
virtual vtkMultiProcessController * NewConnection (const char *url, ConnectionResult &result)=0
- Public Member Functions inherited from vtkNetworkAccessManager
static vtkTCPNetworkAccessManager * New ()
static vtkTCPNetworkAccessManager * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkNetworkAccessManager
static vtkNetworkAccessManager * SafeDownCast (vtkObject *o)
Protected Types
enum  HandshakeErrors {
  HANDSHAKE_NO_ERROR = 0, HANDSHAKE_SOCKET_COMMUNICATOR_DIFFERENT, HANDSHAKE_DIFFERENT_PV_VERSIONS, HANDSHAKE_DIFFERENT_CONNECTION_IDS,
  HANDSHAKE_DIFFERENT_RENDERING_BACKENDS, HANDSHAKE_UNKNOWN_ERROR
 vtkTCPNetworkAccessManager ()
 ~vtkTCPNetworkAccessManager () override
int ProcessEventsInternal (unsigned long timeout_msecs, bool do_processing)
vtkMultiProcessController * ConnectToRemote (const char *hostname, int port, const char *handshake, int timeout_in_seconds, vtkNetworkAccessManager::ConnectionResult &result)
 Connects to remote processes. More...
vtkMultiProcessController * WaitForConnection (int port, bool once, const char *handshake, bool nonblocking, vtkNetworkAccessManager::ConnectionResult &result)
 Waits for connection from remote process. More...
int ParaViewHandshake (vtkMultiProcessController *controller, bool server_side, const char *handshake)
void PrintHandshakeError (int errorcode, bool server_side)
int AnalyzeHandshakeAndGetErrorCode (const char *clientHS, const char *serverHS)
- Protected Member Functions inherited from vtkNetworkAccessManager
 vtkNetworkAccessManager ()
 ~vtkNetworkAccessManager () override
bool AbortPendingConnectionFlag
bool WrongConnectID
vtkTCPNetworkAccessManager is a concrete implementation of vtkNetworkAccessManager that uses tcp/ip sockets for communication between processes. It supports urls that use "tcp" as their protocol specifier.
Definition at line 19 of file vtkTCPNetworkAccessManager.h.
Definition at line 23 of file vtkTCPNetworkAccessManager.h.
◆ HandshakeErrors
Enumerator
HANDSHAKE_NO_ERROR
Definition at line 122 of file vtkTCPNetworkAccessManager.h.
◆ vtkTCPNetworkAccessManager()
vtkTCPNetworkAccessManager::vtkTCPNetworkAccessManager ( )
◆ ~vtkTCPNetworkAccessManager()
vtkTCPNetworkAccessManager::~vtkTCPNetworkAccessManager ( )
static vtkTCPNetworkAccessManager* vtkTCPNetworkAccessManager::New ( )
virtual const char* vtkTCPNetworkAccessManager::GetClassName ( )
Reimplemented from vtkNetworkAccessManager.
static int vtkTCPNetworkAccessManager::IsTypeOf ( const char *  type)
virtual int vtkTCPNetworkAccessManager::IsA ( const char *  type)
static vtkTCPNetworkAccessManager* vtkTCPNetworkAccessManager::SafeDownCast ( vtkObject *  o)
void vtkTCPNetworkAccessManager::PrintSelf ( ostream &  os,
◆ NewConnection() [1/3]
vtkMultiProcessController* vtkTCPNetworkAccessManager::NewConnection ( const char *  url,
vtkNetworkAccessManager::ConnectionResult &  result
This call may block until the connection can be established. To keep user-interfaces responsive, one can listen to the vtkCommand::ProgressEvent fired periodically by this class while waiting. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
vtkNetworkAccessManager can be waiting for atmost one connection at a time. Calling NewConnection() while another connection is pending will raise an error.
To abort the connection and cancel the waiting, simply call AbortPendingConnection() in the vtkCommand::ProgressEvent callback.
Returns the new connection instance on success, otherwise nullptr.
URLs are of the following form: <transport>://<address>
  • tcp://<hostname>:<port>
  • tcp://localhost:<port>?listen=true& – listen for connection on port.
  • tcp://localhost:<port>?listen=true&multiple=true – listen for multiple Examples:
  • tcp://medea:12345
  • tcp://localhost:12345?listen&handshake=3.8.12 Supported parameters: handshake :- specify a message that is matched with the other side listen :- open a server-socket for a client to connect to multiple :- leave server-socket open for more than 1 client to connect (listen must be set to true) nonblocking:- When listen is true, this will result in the call returning nullptr if a client connection is not available immediately. It leaves the server socket open for client to connect. timeout :- When connecting to remote i.e listen==false, specify the time (in seconds) for which this call blocks to retry attempts to connect to the host/port. If absent, default is 60s. 0 implies no retry attempts. A negative value implies an infinite number of retries.
Implements vtkNetworkAccessManager.
◆ AbortPendingConnection()
void vtkTCPNetworkAccessManager::AbortPendingConnection ( )
Refer to NewConnection() for details.
◆ ProcessEvents()
int vtkTCPNetworkAccessManager::ProcessEvents ( unsigned long  timeout_msecs)
◆ GetNetworkEventsAvailable()
bool vtkTCPNetworkAccessManager::GetNetworkEventsAvailable ( )
When this call returns true, ProcessEvents() will always result in some activity processing if called afterword.
◆ GetPendingConnectionsPresent()
bool vtkTCPNetworkAccessManager::GetPendingConnectionsPresent ( )
◆ DisableFurtherConnections()
void vtkTCPNetworkAccessManager::DisableFurtherConnections ( int  port,
bool  disable
◆ GetWrongConnectID()
bool vtkTCPNetworkAccessManager::GetWrongConnectID ( )
◆ ProcessEventsInternal()
int vtkTCPNetworkAccessManager::ProcessEventsInternal ( unsigned long  timeout_msecs,
bool  do_processing
◆ ConnectToRemote()
vtkMultiProcessController* vtkTCPNetworkAccessManager::ConnectToRemote ( const char *  hostname,
int  port,
const char *  handshake,
◆ WaitForConnection()
vtkMultiProcessController* vtkTCPNetworkAccessManager::WaitForConnection ( int  port,
bool  once,
bool  nonblocking,
◆ ParaViewHandshake()
int vtkTCPNetworkAccessManager::ParaViewHandshake ( vtkMultiProcessController *  controller,
bool  server_side,
◆ PrintHandshakeError()
void vtkTCPNetworkAccessManager::PrintHandshakeError ( int  errorcode,
bool  server_side
◆ AnalyzeHandshakeAndGetErrorCode()
int vtkTCPNetworkAccessManager::AnalyzeHandshakeAndGetErrorCode ( const char *  clientHS,
const char *  serverHS
◆ NewConnection() [2/3]
virtual vtkMultiProcessController* vtkNetworkAccessManager::NewConnection
inline
  • tcp://medea:12345
Definition at line 72 of file vtkNetworkAccessManager.h.
◆ NewConnection() [3/3]
  • tcp://medea:12345
◆ AbortPendingConnectionFlag
bool vtkTCPNetworkAccessManager::AbortPendingConnectionFlag
Definition at line 137 of file vtkTCPNetworkAccessManager.h.
◆ WrongConnectID
bool vtkTCPNetworkAccessManager::WrongConnectID
Definition at line 138 of file vtkTCPNetworkAccessManager.h.
