vtkSMTooltipSelectionPipeline Class Reference
#include <vtkSMTooltipSelectionPipeline.h>
Inheritance diagram for vtkSMTooltipSelectionPipeline:
Collaboration diagram for vtkSMTooltipSelectionPipeline:
typedef vtkSMPreselectionPipeline Superclass
- Public Types inherited from vtkSMPreselectionPipeline
bool CanDisplayTooltip (bool &showTooltip)
 Return true if a tooltip can be displayed according to the context, otherwise return false. More...
void Hide (vtkSMRenderViewProxy *view) override
 Re-implemented from vtkSMPreselectionPipeline. More...
void Show (vtkSMSourceProxy *sourceRepresentation, vtkSMSourceProxy *selection, vtkSMRenderViewProxy *view) override
bool GetTooltipInfo (int association, std::string &tooltipText)
 Get information about the tooltip to be displayed in a HTML formated string. More...
bool GetTooltipInfo (int association, std::string &tooltipText, std::string &plainTooltipText)
- Public Member Functions inherited from vtkSMPreselectionPipeline
void CopyLabels (vtkSMProxy *representation)
 Copies the labels for interactive selection from the selection labels in the representation parameter. More...
virtual vtkSMProxy * GetSelectionRepresentation () const
 Get/Create the interactive selection representation. More...
virtual vtkSMProxy * GetOrCreateSelectionRepresentation ()
virtual vtkSMProxy * CreateSelectionRepresentation (vtkSMSourceProxy *extract, vtkSMRenderViewProxy *view)
virtual vtkSMProxy * CreateSelectionRepresentation (vtkSMSourceProxy *extract)
static vtkSMTooltipSelectionPipeline * New ()
static vtkSMTooltipSelectionPipeline * SafeDownCast (vtkObject *o)
static vtkSMTooltipSelectionPipeline * GetInstance ()
- Static Public Member Functions inherited from vtkSMPreselectionPipeline
static vtkSMPreselectionPipeline * SafeDownCast (vtkObject *o)
 vtkSMTooltipSelectionPipeline ()
 ~vtkSMTooltipSelectionPipeline () override
void ClearCache () override
vtkDataObject * ConnectPVMoveSelectionToClient (vtkSMSourceProxy *source, unsigned int sourceOutputPort)
 Connect the ClientServerMoveData filter to the pipeline to get the selection on the client side. More...
bool GetCurrentSelectionId (vtkSMRenderViewProxy *view, vtkIdType &selId)
 Get the id of the selected point. More...
vtkDataSet * FindDataSet (vtkDataObject *dataObject, bool &compositeFound, std::string &compositeName)
 Extract dataset from the dataObject, which can be either directly a dataset or a composite dataset containing only one dataset. More...
- Protected Member Functions inherited from vtkSMPreselectionPipeline
 vtkSMPreselectionPipeline ()
 ~vtkSMPreselectionPipeline () override
vtkSMSourceProxy * ConnectPVExtractSelection (vtkSMSourceProxy *source, unsigned int sourceOutputPort, vtkSMSourceProxy *selection)
vtkSmartPointer< vtkSMProxy > DataMover
vtkIdType PreviousSelectionId
bool SelectionFound
bool TooltipEnabled
- Protected Attributes inherited from vtkSMPreselectionPipeline
vtkSMSourceProxy * ExtractInteractiveSelection
vtkSMProxy * SelectionRepresentation
vtkWeakPointer< vtkSMRenderViewProxy > PreviousView
vtkWeakPointer< vtkSMSourceProxy > PreviousRepresentation
vtkCallbackCommand * ColorObserver
vtkCallbackCommand * ConnectionObserver
- Static Protected Member Functions inherited from vtkSMPreselectionPipeline
static void OnColorModified (vtkObject *source, unsigned long eid, void *clientdata, void *calldata)
static void ClearCache (vtkObject *source, unsigned long eid, void *clientdata, void *calldata)
Point tooltip mode enables the user to inspect points (coordinates, data array values) by hovering the mouse cursor over a point. This is a global object that holds the pipeline for showing the point tooltip mode.
See also
vtkSMPreselectionPipeline vtkSMInteractiveSelectionPipeline
Definition at line 28 of file vtkSMTooltipSelectionPipeline.h.
Definition at line 32 of file vtkSMTooltipSelectionPipeline.h.
◆ vtkSMTooltipSelectionPipeline()
vtkSMTooltipSelectionPipeline::vtkSMTooltipSelectionPipeline ( )
◆ ~vtkSMTooltipSelectionPipeline()
vtkSMTooltipSelectionPipeline::~vtkSMTooltipSelectionPipeline ( )
static vtkSMTooltipSelectionPipeline* vtkSMTooltipSelectionPipeline::New ( )
virtual const char* vtkSMTooltipSelectionPipeline::GetClassName ( )
Reimplemented from vtkSMPreselectionPipeline.
static int vtkSMTooltipSelectionPipeline::IsTypeOf ( const char *  type)
virtual int vtkSMTooltipSelectionPipeline::IsA ( const char *  type)
static vtkSMTooltipSelectionPipeline* vtkSMTooltipSelectionPipeline::SafeDownCast ( vtkObject *  o)
void vtkSMTooltipSelectionPipeline::PrintSelf ( ostream &  os,
◆ GetInstance()
static vtkSMTooltipSelectionPipeline* vtkSMTooltipSelectionPipeline::GetInstance ( )
◆ Hide()
void vtkSMTooltipSelectionPipeline::Hide ( vtkSMRenderViewProxy *  view)
◆ Show()
void vtkSMTooltipSelectionPipeline::Show ( vtkSMSourceProxy *  sourceRepresentation,
vtkSMSourceProxy *  selection,
◆ CanDisplayTooltip()
bool vtkSMTooltipSelectionPipeline::CanDisplayTooltip ( bool &  showTooltip)
The argument showTooltip is true if the tooltip must be shown, false if the tooltip must be hidden.
◆ GetTooltipInfo() [1/2]
bool vtkSMTooltipSelectionPipeline::GetTooltipInfo ( int  association,
std::string &  tooltipText
tooltipText received a HTML formatted string, while plainTooltipText receive a plain text version. Return false if the method failed computing information.
◆ GetTooltipInfo() [2/2]
std::string &  tooltipText,
std::string &  plainTooltipText
◆ ClearCache()
void vtkSMTooltipSelectionPipeline::ClearCache ( )
overrideprotectedvirtual
◆ ConnectPVMoveSelectionToClient()
vtkDataObject* vtkSMTooltipSelectionPipeline::ConnectPVMoveSelectionToClient ( vtkSMSourceProxy *  source,
◆ GetCurrentSelectionId()
bool vtkSMTooltipSelectionPipeline::GetCurrentSelectionId ( vtkSMRenderViewProxy *  view,
vtkIdType &  selId
◆ FindDataSet()
vtkDataSet* vtkSMTooltipSelectionPipeline::FindDataSet ( vtkDataObject *  dataObject,
bool &  compositeFound,
std::string &  compositeName
◆ DataMover
vtkSmartPointer<vtkSMProxy> vtkSMTooltipSelectionPipeline::DataMover
Definition at line 90 of file vtkSMTooltipSelectionPipeline.h.
◆ PreviousSelectionId
vtkIdType vtkSMTooltipSelectionPipeline::PreviousSelectionId
Definition at line 91 of file vtkSMTooltipSelectionPipeline.h.
◆ SelectionFound
bool vtkSMTooltipSelectionPipeline::SelectionFound
Definition at line 92 of file vtkSMTooltipSelectionPipeline.h.
◆ TooltipEnabled
bool vtkSMTooltipSelectionPipeline::TooltipEnabled
Definition at line 93 of file vtkSMTooltipSelectionPipeline.h.
