vtkSMSelectionHelper Class Reference
Utility class to help with selection tasks. More...
#include <vtkSMSelectionHelper.h>
Inheritance diagram for vtkSMSelectionHelper:
Collaboration diagram for vtkSMSelectionHelper:
enum  CombineOperation { CombineOperation::DEFAULT = 0, CombineOperation::ADDITION = 1, CombineOperation::SUBTRACTION = 2, CombineOperation::TOGGLE = 3 }
static vtkSMSelectionHelper * New ()
static vtkSMSelectionHelper * SafeDownCast (vtkObject *o)
static vtkSMProxy * NewAppendSelectionsFromSelectionSource (vtkSMSourceProxy *selectionSource)
 Create an append selection proxy from a selection source. More...
static vtkSMProxy * NewSelectionSourceFromSelection (vtkSMSession *session, vtkSelection *selection, bool ignore_composite_keys=false)
 Given a selection, returns a proxy for a selection source that has the ids specified by it. More...
static void NewSelectionSourcesFromSelection (vtkSelection *selection, vtkSMProxy *view, vtkCollection *selSources, vtkCollection *selRepresentations)
static vtkSMProxy * ConvertAppendSelections (int outputType, vtkSMSourceProxy *appendSelections, vtkSMSourceProxy *dataSource, int dataPort, bool &selectionChanged)
 Given the ContentType for an output vtkSelection, this create a new append selections proxy generating the selection, the input appendSelections is used to fill the default values for created selection source. More...
static vtkSMProxy * ConvertSelectionSource (int outputType, vtkSMSourceProxy *selectionSourceProxy, vtkSMSourceProxy *dataSource, int dataPort)
 Given the ContentType for an output vtkSelection, this create a new source proxy generating the selection, the input selectionSourceProxy is used to fill the default values for created selection source. More...
static bool CombineSelection (vtkSMSourceProxy *appendSelections1, vtkSMSourceProxy *appendSelections2, CombineOperation operation, bool deepCopy=false)
 Combine appendSelections1 with appendSelections2 using a combine operation and store the result into appendSelections2. More...
static bool IgnoreSelection (vtkSMSourceProxy *appendSelections1, vtkSMSourceProxy *appendSelections2, bool deepCopy=false)
static bool AddSelection (vtkSMSourceProxy *appendSelections1, vtkSMSourceProxy *appendSelections2, bool deepCopy=false)
static bool SubtractSelection (vtkSMSourceProxy *appendSelections1, vtkSMSourceProxy *appendSelections2, bool deepCopy=false)
static bool ToggleSelection (vtkSMSourceProxy *appendSelections1, vtkSMSourceProxy *appendSelections2, bool deepCopy=false)
static vtkSMObject * New ()
 vtkSMSelectionHelper ()=default
 ~vtkSMSelectionHelper () override=default
 vtkSMObject ()
 ~vtkSMObject () override
This class contains several static methods that help with the complicated selection task.
Definition at line 24 of file vtkSMSelectionHelper.h.
Definition at line 28 of file vtkSMSelectionHelper.h.
◆ CombineOperation
Enumerator
DEFAULT
ADDITION
SUBTRACTION
TOGGLE
Definition at line 36 of file vtkSMSelectionHelper.h.
◆ vtkSMSelectionHelper()
vtkSMSelectionHelper::vtkSMSelectionHelper ( )
protecteddefault
◆ ~vtkSMSelectionHelper()
vtkSMSelectionHelper::~vtkSMSelectionHelper ( )
overrideprotecteddefault
static vtkSMSelectionHelper* vtkSMSelectionHelper::New ( )
virtual const char* vtkSMSelectionHelper::GetClassName ( )
static int vtkSMSelectionHelper::IsTypeOf ( const char *  type)
virtual int vtkSMSelectionHelper::IsA ( const char *  type)
static vtkSMSelectionHelper* vtkSMSelectionHelper::SafeDownCast ( vtkObject *  o)
void vtkSMSelectionHelper::PrintSelf ( ostream &  os,
◆ NewAppendSelectionsFromSelectionSource()
static vtkSMProxy* vtkSMSelectionHelper::NewAppendSelectionsFromSelectionSource ( vtkSMSourceProxy *  selectionSource)
◆ CombineSelection()
static bool vtkSMSelectionHelper::CombineSelection ( vtkSMSourceProxy *  appendSelections1,
vtkSMSourceProxy *  appendSelections2,
bool  deepCopy = false
appendSelections1 and appendSelections2 can be combined if they have the same fieldType and containing cells qualifiers. The returned value indicates if the selections could/have be combined.
If operation is DEFAULT, appendSelections2 = appendSelections2 if operation is ADDITION, appendSelections2 = appendSelections1 | appendSelections2 if operation is SUBTRACTION, appendSelections2 = appendSelections1 & !appendSelections2 if operation is TOGGLE, appendSelections2 = appendSelections1 ^ appendSelections2
Note: appendSelections2 must have at least one selection source, but appendSelections1 can be empty (but valid).
◆ IgnoreSelection()
static bool vtkSMSelectionHelper::IgnoreSelection ( vtkSMSourceProxy *  appendSelections1,
inlinestatic
Definition at line 61 of file vtkSMSelectionHelper.h.
◆ AddSelection()
static bool vtkSMSelectionHelper::AddSelection ( vtkSMSourceProxy *  appendSelections1,
inlinestatic
Definition at line 67 of file vtkSMSelectionHelper.h.
◆ SubtractSelection()
static bool vtkSMSelectionHelper::SubtractSelection ( vtkSMSourceProxy *  appendSelections1,
inlinestatic
Definition at line 73 of file vtkSMSelectionHelper.h.
◆ ToggleSelection()
static bool vtkSMSelectionHelper::ToggleSelection ( vtkSMSourceProxy *  appendSelections1,
inlinestatic
Definition at line 79 of file vtkSMSelectionHelper.h.
◆ NewSelectionSourceFromSelection()
static vtkSMProxy* vtkSMSelectionHelper::NewSelectionSourceFromSelection ( vtkSMSession *  session,
vtkSelection *  selection,
bool  ignore_composite_keys = false
This source can then be used as input to a vtkExtractSelection filter. CAVEAT: Make sure to specify the connection id for the server on which the selection was performed. This method can only handle 3 types of selection FRUSTUM, INDICES and GLOBALIDS. We can easily change this to handle all other types of selection but that's not required currently and hence we not adding that code.
◆ NewSelectionSourcesFromSelection()
static void vtkSMSelectionHelper::NewSelectionSourcesFromSelection ( vtkSelection *  selection,
vtkSMProxy *  view,
vtkCollection *  selSources,
vtkCollection *  selRepresentations
◆ ConvertAppendSelections()
static vtkSMProxy* vtkSMSelectionHelper::ConvertAppendSelections ( int  outputType,
vtkSMSourceProxy *  appendSelections,
vtkSMSourceProxy *  dataSource,
int  dataPort,
bool &  selectionChanged
◆ ConvertSelectionSource()
static vtkSMProxy* vtkSMSelectionHelper::ConvertSelectionSource ( int  outputType,
vtkSMSourceProxy *  selectionSourceProxy,
int  dataPort
