vtkSMRemoteObject undo element. More...
#include <vtkSMRemoteObjectUpdateUndoElement.h>
| typedef vtkSMUndoElement | Superclass |
Public Types inherited from vtkSMUndoElement | |
| typedef vtkUndoElement | Superclass |
Public Types inherited from vtkUndoElement | |
| int | Undo () override |
| Undo the operation encapsulated by this element. More... | |
| int | Redo () override |
| Redo the operation encaspsulated by this element. More... | |
| virtual void | SetProxyLocator (vtkSMProxyLocator *) |
| Set ProxyLocator to use if any. More... | |
| virtual void | SetUndoRedoState (const vtkSMMessage *before, const vtkSMMessage *after) |
| Set the state of the UndoElement. More... | |
| virtual vtkTypeUInt32 | GetGlobalId () |
Public Member Functions inherited from vtkSMUndoElement | |
Public Member Functions inherited from vtkUndoElement | |
| virtual bool | Merge (vtkUndoElement *vtkNotUsed(new_element)) |
Called on the older element in the UndoSet to merge with the element being added if both the elements are mergeable. More... | |
| virtual void | SetUndoSetWorkingContext (vtkCollection *workCTX) |
| virtual bool | GetMergeable () |
| Returns if this undo element can be merged with other undo elements. More... | |
| static vtkSMRemoteObjectUpdateUndoElement * | New () |
| static vtkSMRemoteObjectUpdateUndoElement * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMUndoElement | |
| static vtkSMUndoElement * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkUndoElement | |
| static vtkUndoElement * | SafeDownCast (vtkObject *o) |
Public Attributes | |
| vtkSMMessage * | BeforeState |
| vtkSMMessage * | AfterState |
| vtkSMRemoteObjectUpdateUndoElement () | |
| ~vtkSMRemoteObjectUpdateUndoElement () override | |
| int | UpdateState (const vtkSMMessage *state) |
Protected Member Functions inherited from vtkSMUndoElement | |
| vtkSMUndoElement () | |
| ~vtkSMUndoElement () override | |
Protected Member Functions inherited from vtkUndoElement | |
| vtkUndoElement () | |
| ~vtkUndoElement () override | |
| virtual void | SetMergeable (bool) |
| Subclasses must set this flag to enable merging of consecutive elements in an UndoSet. More... | |
Protected Attributes | |
| vtkSMProxyLocator * | ProxyLocator |
Protected Attributes inherited from vtkSMUndoElement | |
Protected Attributes inherited from vtkUndoElement | |
| bool | Mergeable |
| vtkCollection * | UndoSetWorkingContext |
This class keeps the before and after state of the RemoteObject in the vtkSMMessage form. It works with any proxy and RemoteObject. It is a very generic undoElement.
Definition at line 22 of file vtkSMRemoteObjectUpdateUndoElement.h.
Definition at line 26 of file vtkSMRemoteObjectUpdateUndoElement.h.
Reimplemented from vtkSMUndoElement.
Implements vtkUndoElement.
| vtkSMMessage* vtkSMRemoteObjectUpdateUndoElement::BeforeState |
Definition at line 52 of file vtkSMRemoteObjectUpdateUndoElement.h.
| vtkSMMessage* vtkSMRemoteObjectUpdateUndoElement::AfterState |
Definition at line 53 of file vtkSMRemoteObjectUpdateUndoElement.h.
Definition at line 64 of file vtkSMRemoteObjectUpdateUndoElement.h.
