| void | SetRenderViewProxy (vtkSMProxy *rvProxy) |
| | Set the render view proxy to extract camera properties from. More...
| int | ReadConfiguration (const char *filename) override |
| | Read the named file, and push the properties into the underying managed render view proxy. More...
| int | ReadConfiguration (vtkPVXMLElement *x) override |
| int | ReadConfiguration () override |
| virtual void | SetFileDescription (const char *) |
| virtual char * | GetFileDescription () |
| virtual void | SetFileExtension (const char *) |
| virtual char * | GetFileExtension () |
| virtual const char * | GetReaderVersion () |
| | Return the reader version. More...
| virtual bool | CanReadVersion (const char *version) |
| | Return true if the reader can read the specified version. More...
| virtual void | SetFileName (const char *) |
| | Set/Get the file name. More...
| virtual char * | GetFileName () |
| virtual vtkSMProxy * | GetProxy () |
| | Set the proxy to write out. More...
| virtual void | SetFileIdentifier (const char *) |
| | Set/get file meta data. More...
| virtual char * | GetFileIdentifier () |
| virtual void | SetValidateProxyType (int) |
| | Turns on/off proxy type validation. More...
| virtual int | GetValidateProxyType () |
A reader for XML camera configuration.
A reader for XML camera configuration. Reades camera configuration files. written by the vtkSMCameraConfigurationWriter.
- See also
- vtkSMCameraConfigurationWriter, vtkSMProxyConfigurationReader
- This class was contributed by SciberQuest Inc.
Definition at line 28 of file vtkSMCameraConfigurationReader.h.
