Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkSITimeLabelProperty Class Reference
#include <vtkSITimeLabelProperty.h>
Inheritance diagram for vtkSITimeLabelProperty:
Collaboration diagram for vtkSITimeLabelProperty:
typedef vtkSIProperty Superclass
- Public Types inherited from vtkSIProperty
- Public Member Functions inherited from vtkSIProperty
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual char * GetCommand ()
 The command name used to set the value on the server object. More...
virtual bool GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
virtual void SetIsInternal (bool)
 This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool GetIsInternal ()
static vtkSITimeLabelProperty * New ()
static vtkSITimeLabelProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProperty
static vtkSIProperty * New ()
static vtkSIProperty * SafeDownCast (vtkObject *o)
 vtkSITimeLabelProperty ()
 ~vtkSITimeLabelProperty () override
bool Pull (vtkSMMessage *) override
 Pull the current state of the underneath implementation. More...
- Protected Member Functions inherited from vtkSIProperty
 vtkSIProperty ()
 ~vtkSIProperty () override
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
virtual bool Push (vtkSMMessage *, int)
 Push a new state to the underneath implementation. More...
virtual bool ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element)
 Parse the xml for the property. More...
virtual void SetCommand (const char *)
void SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset)
bool ProcessMessage (vtkClientServerStream &stream)
 Interprets the message. More...
const vtkClientServerStream & GetLastResult ()
vtkObjectBase * GetVTKObject ()
Friends
class vtkSIProxy
- Protected Attributes inherited from vtkSIProperty
char * XMLName
char * Command
bool InformationOnly
bool Repeatable
bool IsInternal
vtkWeakPointer< vtkSIProxy > SIProxyObject
SIProperty that deals with TimeLabel annotation on Algorithm object type
Definition at line 15 of file vtkSITimeLabelProperty.h.
Definition at line 19 of file vtkSITimeLabelProperty.h.
◆ vtkSITimeLabelProperty()
vtkSITimeLabelProperty::vtkSITimeLabelProperty ( )
◆ ~vtkSITimeLabelProperty()
vtkSITimeLabelProperty::~vtkSITimeLabelProperty ( )
static vtkSITimeLabelProperty* vtkSITimeLabelProperty::New ( )
virtual const char* vtkSITimeLabelProperty::GetClassName ( )
static int vtkSITimeLabelProperty::IsTypeOf ( const char *  type)
virtual int vtkSITimeLabelProperty::IsA ( const char *  type)
static vtkSITimeLabelProperty* vtkSITimeLabelProperty::SafeDownCast ( vtkObject *  o)
void vtkSITimeLabelProperty::PrintSelf ( ostream &  os,
◆ Pull()
bool vtkSITimeLabelProperty::Pull ( vtkSMMessage *  )
overrideprotectedvirtual
◆ vtkSIProxy
friend class vtkSIProxy
friend
Definition at line 26 of file vtkSITimeLabelProperty.h.
