vtkSIDoubleMapProperty Class Reference
#include <vtkSIDoubleMapProperty.h>
Inheritance diagram for vtkSIDoubleMapProperty:
Collaboration diagram for vtkSIDoubleMapProperty:
typedef vtkSIProperty Superclass
- Public Types inherited from vtkSIProperty
virtual char * GetCleanCommand ()
virtual void SetCleanCommand (const char *)
- Public Member Functions inherited from vtkSIProperty
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual char * GetCommand ()
 The command name used to set the value on the server object. More...
virtual bool GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
virtual void SetIsInternal (bool)
 This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool GetIsInternal ()
static vtkSIDoubleMapProperty * New ()
static vtkSIDoubleMapProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSIProperty
static vtkSIProperty * New ()
static vtkSIProperty * SafeDownCast (vtkObject *o)
 vtkSIDoubleMapProperty ()
 ~vtkSIDoubleMapProperty () override
bool Push (vtkSMMessage *, int) override
 Push a new state to the underneath implementation. More...
bool ReadXMLAttributes (vtkSIProxy *parent, vtkPVXMLElement *element) override
 Parse the xml for the property. More...
- Protected Member Functions inherited from vtkSIProperty
 vtkSIProperty ()
 ~vtkSIProperty () override
vtkSIObject * GetSIObject (vtkTypeUInt32 globalid)
 Convenience method to obtain a vtkSIObject subclass given its global id. More...
virtual bool Pull (vtkSMMessage *)
 Pull the current state of the underneath implementation. More...
virtual void SetCommand (const char *)
void SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset)
bool ProcessMessage (vtkClientServerStream &stream)
 Interprets the message. More...
const vtkClientServerStream & GetLastResult ()
vtkObjectBase * GetVTKObject ()
unsigned int NumberOfComponents
char * CleanCommand
- Protected Attributes inherited from vtkSIProperty
char * XMLName
char * Command
bool InformationOnly
bool Repeatable
bool IsInternal
vtkWeakPointer< vtkSIProxy > SIProxyObject
Map property that manage double value to be set through a method on a vtkObject.
Definition at line 16 of file vtkSIDoubleMapProperty.h.
Definition at line 20 of file vtkSIDoubleMapProperty.h.
◆ vtkSIDoubleMapProperty()
vtkSIDoubleMapProperty::vtkSIDoubleMapProperty ( )
◆ ~vtkSIDoubleMapProperty()
vtkSIDoubleMapProperty::~vtkSIDoubleMapProperty ( )
static vtkSIDoubleMapProperty* vtkSIDoubleMapProperty::New ( )
virtual const char* vtkSIDoubleMapProperty::GetClassName ( )
static int vtkSIDoubleMapProperty::IsTypeOf ( const char *  type)
virtual int vtkSIDoubleMapProperty::IsA ( const char *  type)
static vtkSIDoubleMapProperty* vtkSIDoubleMapProperty::SafeDownCast ( vtkObject *  o)
void vtkSIDoubleMapProperty::PrintSelf ( ostream &  os,
◆ GetCleanCommand()
virtual char* vtkSIDoubleMapProperty::GetCleanCommand ( )
◆ SetCleanCommand()
virtual void vtkSIDoubleMapProperty::SetCleanCommand ( const char *  )
◆ Push()
bool vtkSIDoubleMapProperty::Push ( vtkSMMessage *  ,
int
overrideprotectedvirtual
◆ ReadXMLAttributes()
bool vtkSIDoubleMapProperty::ReadXMLAttributes ( vtkSIProxy *  proxyhelper,
vtkPVXMLElement *  element
◆ NumberOfComponents
unsigned int vtkSIDoubleMapProperty::NumberOfComponents
Definition at line 33 of file vtkSIDoubleMapProperty.h.
◆ CleanCommand
char* vtkSIDoubleMapProperty::CleanCommand
Definition at line 34 of file vtkSIDoubleMapProperty.h.
