vtkRulerSourceRepresentation Class Reference
#include <vtkRulerSourceRepresentation.h>
Inheritance diagram for vtkRulerSourceRepresentation:
Collaboration diagram for vtkRulerSourceRepresentation:
enum  DesiredOutputPrecision
void SetTextProperty (vtkTextProperty *prop)
 Set the text property for the printed distance. More...
void SetAxisLineWidth (float width)
 Set the line width for the displayed axis in screen units. More...
void SetAxisColor (double red, double green, double blue)
 Set the color for the displayed axis. More...
void SetVisibility (bool) override
 Set the visibility. More...
void SetLabelFormat (char *labelFormat)
 Specify the format to use for labeling the distance. More...
void SetNumberOfRulerTicks (int numberOfRulerTicks)
 Specify the number of major ruler ticks. More...
void SetDistanceRepresentation (vtkDistanceRepresentation2D *)
 Set the text widget. More...
virtual vtkDistanceRepresentation2D * GetDistanceRepresentation ()
void SetRulerMode (int choice)
 Enable or disable ruler mode. More...
int GetRulerMode ()
void SetRulerDistance (double distance)
 Specify the RulerDistance which indicates the spacing of the major ticks in the unit space obtained after the Scale is applied (see SetScale()). More...
double GetRulerDistance ()
void SetScale (double distance)
 Set scale factor to apply to the ruler graduation scale and the displayed distance. More...
double GetScale ()
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkRulerSourceRepresentation * New ()
static vtkRulerSourceRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkRulerSourceRepresentation ()
 ~vtkRulerSourceRepresentation () override
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkDistanceRepresentation2D * DistanceRepresentation
vtkNew< vtkPolyData > Clone
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkRulerSourceRepresentation is a representation to show a ruler. The input is expected to be vtkPolyData with two points.
Definition at line 22 of file vtkRulerSourceRepresentation.h.
Definition at line 26 of file vtkRulerSourceRepresentation.h.
◆ vtkRulerSourceRepresentation()
vtkRulerSourceRepresentation::vtkRulerSourceRepresentation ( )
◆ ~vtkRulerSourceRepresentation()
vtkRulerSourceRepresentation::~vtkRulerSourceRepresentation ( )
static vtkRulerSourceRepresentation* vtkRulerSourceRepresentation::New ( )
virtual const char* vtkRulerSourceRepresentation::GetClassName ( )
static int vtkRulerSourceRepresentation::IsTypeOf ( const char *  type)
virtual int vtkRulerSourceRepresentation::IsA ( const char *  type)
static vtkRulerSourceRepresentation* vtkRulerSourceRepresentation::SafeDownCast ( vtkObject *  o)
void vtkRulerSourceRepresentation::PrintSelf ( ostream &  os,
◆ SetDistanceRepresentation()
void vtkRulerSourceRepresentation::SetDistanceRepresentation ( vtkDistanceRepresentation2D *  )
◆ GetDistanceRepresentation()
virtual vtkDistanceRepresentation2D* vtkRulerSourceRepresentation::GetDistanceRepresentation ( )
◆ SetTextProperty()
void vtkRulerSourceRepresentation::SetTextProperty ( vtkTextProperty *  prop)
◆ SetAxisLineWidth()
void vtkRulerSourceRepresentation::SetAxisLineWidth ( float  width)
◆ SetAxisColor()
void vtkRulerSourceRepresentation::SetAxisColor ( double  red,
double  green,
double  blue
◆ SetVisibility()
void vtkRulerSourceRepresentation::SetVisibility ( bool  )
Set the visibility.
◆ SetLabelFormat()
void vtkRulerSourceRepresentation::SetLabelFormat ( char *  labelFormat)
Note that an empty string results in no label, or a format string without a "%" character will not print the distance value.
◆ SetRulerMode()
void vtkRulerSourceRepresentation::SetRulerMode ( int  choice)
When enabled, the ticks on the distance widget are separated by the amount specified by vtkDistanceRepresentation::RulerDistance. Otherwise, the value vtkDistanceRepresentation::NumberOfRulerTicks is used to draw the tick marks.
◆ GetRulerMode()
int vtkRulerSourceRepresentation::GetRulerMode ( )
◆ SetRulerDistance()
void vtkRulerSourceRepresentation::SetRulerDistance ( double  distance)
This ivar only has effect when the RulerMode is on.
◆ GetRulerDistance()
double vtkRulerSourceRepresentation::GetRulerDistance ( )
◆ SetScale()
void vtkRulerSourceRepresentation::SetScale ( double  distance)
Used to transform VTK world space units to a desired unit, e.g., inches to centimeters.
◆ GetScale()
double vtkRulerSourceRepresentation::GetScale ( )
◆ SetNumberOfRulerTicks()
void vtkRulerSourceRepresentation::SetNumberOfRulerTicks ( int  numberOfRulerTicks)
Note: the number of ticks is the number between the two handle endpoints. This ivar only has effect when the RulerMode is off.
◆ ProcessViewRequest()
int vtkRulerSourceRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ RequestData()
int vtkRulerSourceRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
Overridden to invoke vtkCommand::UpdateDataEvent.
◆ FillInputPortInformation()
int vtkRulerSourceRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
Fill input port information.
◆ AddToView()
bool vtkRulerSourceRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkRulerSourceRepresentation::RemoveFromView ( vtkView *  view)
◆ DistanceRepresentation
vtkDistanceRepresentation2D* vtkRulerSourceRepresentation::DistanceRepresentation
Definition at line 137 of file vtkRulerSourceRepresentation.h.
◆ Clone
vtkNew<vtkPolyData> vtkRulerSourceRepresentation::Clone
Definition at line 138 of file vtkRulerSourceRepresentation.h.
