vtkPythonRepresentation Class Reference
#include <vtkPythonRepresentation.h>
Inheritance diagram for vtkPythonRepresentation:
Collaboration diagram for vtkPythonRepresentation:
enum  DesiredOutputPrecision
int GetNumberOfAttributeArrays (int attributeType)
 Get number of arrays in an attribute (e.g., vtkDataObject::POINT, vtkDataObject::CELL, vtkDataObject::ROW, vtkDataObject::FIELD_DATA). More...
const char * GetAttributeArrayName (int attributeType, int arrayIndex)
 From the input data, get the name of attribute array at index for the given attribute type. More...
void SetAttributeArrayStatus (int attributeType, const char *name, int status)
 Set the array status for the input data object. More...
int GetAttributeArrayStatus (int attributeType, const char *name)
 Get the status indicating whether the array with the given name and attribute type in the input will be copied to the client. More...
void EnableAllAttributeArrays ()
 Enable all arrays. More...
void DisableAllAttributeArrays ()
 Disable all arrays. More...
virtual vtkDataObject * GetLocalInput ()
 Gets local copy of the input. More...
virtual vtkDataObject * GetClientDataObject ()
 Gets the client's copy of the input. More...
virtual void MarkModified ()
virtual void SetVisibility (bool val)
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPythonRepresentation * New ()
static vtkPythonRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkPythonRepresentation ()
 ~vtkPythonRepresentation () override
 Overridden to make input optional. More...
 Overridden to copy data from the server to the client. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
Representation for showing data in a vtkPythonView. This representation does not create any intermediate data for display. Instead, it simply fetches data from the server.
Definition at line 20 of file vtkPythonRepresentation.h.
Definition at line 24 of file vtkPythonRepresentation.h.
◆ vtkPythonRepresentation()
vtkPythonRepresentation::vtkPythonRepresentation ( )
◆ ~vtkPythonRepresentation()
vtkPythonRepresentation::~vtkPythonRepresentation ( )
static vtkPythonRepresentation* vtkPythonRepresentation::New ( )
virtual const char* vtkPythonRepresentation::GetClassName ( )
static int vtkPythonRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPythonRepresentation::IsA ( const char *  type)
static vtkPythonRepresentation* vtkPythonRepresentation::SafeDownCast ( vtkObject *  o)
void vtkPythonRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkPythonRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
This is typically called by the vtkView to request meta-data from the representations or ask them to perform certain tasks e.g. PrepareForRendering. Overridden to skip processing when visibility if off.
◆ GetLocalInput()
virtual vtkDataObject* vtkPythonRepresentation::GetLocalInput ( )
This will be nullptr on the client when running in client-only mode until after Update() is called.
◆ GetClientDataObject()
virtual vtkDataObject* vtkPythonRepresentation::GetClientDataObject ( )
◆ GetNumberOfAttributeArrays()
int vtkPythonRepresentation::GetNumberOfAttributeArrays ( int  attributeType)
◆ GetAttributeArrayName()
const char* vtkPythonRepresentation::GetAttributeArrayName ( int  attributeType,
int  arrayIndex
◆ SetAttributeArrayStatus()
void vtkPythonRepresentation::SetAttributeArrayStatus ( int  attributeType,
const char *  name,
int  status
A status of 1 means that the array with the given name for the given attribute will be copied to the client. A status of 0 means the array will not be copied to the client. The status is 0 by default.
◆ GetAttributeArrayStatus()
int vtkPythonRepresentation::GetAttributeArrayStatus ( int  attributeType,
const char *  name
Status is 0 by default.
◆ EnableAllAttributeArrays()
void vtkPythonRepresentation::EnableAllAttributeArrays ( )
Enable all arrays.
When called, all arrays will be marked as enabled.
◆ DisableAllAttributeArrays()
void vtkPythonRepresentation::DisableAllAttributeArrays ( )
Disable all arrays.
When called, all arrays will be marked as disabled.
◆ FillInputPortInformation()
int vtkPythonRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestData()
int vtkPythonRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
