vtkProtractorRepresentation Class Reference
#include <vtkProtractorRepresentation.h>
Inheritance diagram for vtkProtractorRepresentation:
Collaboration diagram for vtkProtractorRepresentation:
enum  DesiredOutputPrecision
void SetAngleRepresentation (vtkAngleRepresentation2D *)
 Set the text widget. More...
 vtkGetSmartPointerMacro (AngleRepresentation, vtkAngleRepresentation2D)
void SetTextProperty (vtkTextProperty *prop)
 Forward properties to the underlying representation. More...
void SetLineColor (double r, double g, double b)
void SetLineThickness (double thickness)
void SetArrowStyle (int style)
void SetLabelFactorSize (double size)
void SetVisibility (bool) override
void SetLabelFormat (char *labelFormat)
void SetAngleScale (double factor)
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkProtractorRepresentation * New ()
static vtkProtractorRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkProtractorRepresentation ()
 ~vtkProtractorRepresentation () override=default
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkSmartPointer< vtkAngleRepresentation2D > AngleRepresentation
vtkNew< vtkPolyData > Clone
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkProtractorRepresentation is a representation to show a protractor. The input is expected to be vtkPolyData with 3 points. It uses a vtkAngleRepresentation2D for the actual display, so the lines and labels are always visible.
See also
Definition at line 26 of file vtkProtractorRepresentation.h.
Definition at line 30 of file vtkProtractorRepresentation.h.
◆ vtkProtractorRepresentation()
vtkProtractorRepresentation::vtkProtractorRepresentation ( )
◆ ~vtkProtractorRepresentation()
vtkProtractorRepresentation::~vtkProtractorRepresentation ( )
overrideprotecteddefault
static vtkProtractorRepresentation* vtkProtractorRepresentation::New ( )
virtual const char* vtkProtractorRepresentation::GetClassName ( )
static int vtkProtractorRepresentation::IsTypeOf ( const char *  type)
virtual int vtkProtractorRepresentation::IsA ( const char *  type)
static vtkProtractorRepresentation* vtkProtractorRepresentation::SafeDownCast ( vtkObject *  o)
void vtkProtractorRepresentation::PrintSelf ( ostream &  os,
◆ SetAngleRepresentation()
void vtkProtractorRepresentation::SetAngleRepresentation ( vtkAngleRepresentation2D *  )
◆ vtkGetSmartPointerMacro()
vtkProtractorRepresentation::vtkGetSmartPointerMacro ( AngleRepresentation  ,
◆ SetTextProperty()
void vtkProtractorRepresentation::SetTextProperty ( vtkTextProperty *  prop)
◆ SetLineColor()
void vtkProtractorRepresentation::SetLineColor ( double  r,
double  g,
double  b
◆ SetLineThickness()
void vtkProtractorRepresentation::SetLineThickness ( double  thickness)
◆ SetArrowStyle()
void vtkProtractorRepresentation::SetArrowStyle ( int  style)
◆ SetLabelFactorSize()
void vtkProtractorRepresentation::SetLabelFactorSize ( double  size)
◆ SetVisibility()
void vtkProtractorRepresentation::SetVisibility ( bool  )
◆ SetLabelFormat()
void vtkProtractorRepresentation::SetLabelFormat ( char *  labelFormat)
◆ SetAngleScale()
void vtkProtractorRepresentation::SetAngleScale ( double  factor)
◆ ProcessViewRequest()
int vtkProtractorRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ RequestData()
int vtkProtractorRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkProtractorRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
Fill input port information.
◆ AddToView()
bool vtkProtractorRepresentation::AddToView ( vtkView *  view)
This is called from vtkView::AddRepresentation(). Add the underlying representation. Returns true if the addition succeeds.
◆ RemoveFromView()
bool vtkProtractorRepresentation::RemoveFromView ( vtkView *  view)
This is called from vtkView::RemoveRepresentation(). Remove the underlying representation. Returns true if the removal succeeds.
◆ AngleRepresentation
vtkSmartPointer<vtkAngleRepresentation2D> vtkProtractorRepresentation::AngleRepresentation
Definition at line 89 of file vtkProtractorRepresentation.h.
◆ Clone
vtkNew<vtkPolyData> vtkProtractorRepresentation::Clone
Definition at line 90 of file vtkProtractorRepresentation.h.
