vtkPointGaussianRepresentation Class Reference
#include <vtkPointGaussianRepresentation.h>
Inheritance diagram for vtkPointGaussianRepresentation:
Collaboration diagram for vtkPointGaussianRepresentation:
enum  ShaderPresets {
  GAUSSIAN_BLUR, SPHERE, BLACK_EDGED_CIRCLE, PLAIN_CIRCLE,
  TRIANGLE, SQUARE_OUTLINE, CUSTOM, NUMBER_OF_PRESETS
 An enum specifying some preset fragment shaders. More...
enum  DesiredOutputPrecision
void SetLookupTable (vtkScalarsToColors *lut)
 Use to set the color map for the data in this representation. More...
void SetVisibility (bool val) override
 Use to set whether the data in this representation is visible or not. More...
virtual void SetEmissive (bool val)
 Use to set whether the splat emits light. More...
virtual void SetMapScalars (int val)
 Use to make sure scalars will be mapped through lookup table, and not inadvertently used as colors by themselves. More...
virtual void SetOrientation (double, double, double)
virtual void SetOrigin (double, double, double)
virtual void SetPickable (int val)
virtual void SetPosition (double, double, double)
virtual void SetScale (double, double, double)
virtual void SetAmbientColor (double r, double g, double b)
virtual void SetDiffuseColor (double r, double g, double b)
virtual void SetEdgeColor (double r, double g, double b)
virtual void SetInterpolation (int val)
virtual void SetLineWidth (double val)
virtual void SetOpacity (double val)
virtual void SetPointSize (double val)
virtual void SetSpecularColor (double r, double g, double b)
virtual void SetSpecularPower (double val)
virtual void SetSplatSize (double radius)
 Sets the radius of the gaussian splats if there is no scale array or if the scale array is disabled. More...
void SelectShaderPreset (int preset)
 Allows to select one of several preset options for shading the points. More...
void SetCustomShader (const char *shaderString)
 Sets the snippet of fragment shader code used to color the sprites. More...
void SetCustomTriangleScale (double scale)
 Sets the scale of the triangle geometry drawn for the custom shader. More...
void SelectScaleArray (int, int, int, int, const char *name)
 Sets the point array to scale the guassians by. More...
void SelectScaleArrayComponent (int component)
 Sets the point array component to scale the gaussians by. More...
void SetUseScaleFunction (bool enable)
 Use scale transfer function. More...
void SetScaleTransferFunction (vtkPiecewiseFunction *pwf)
 Sets a vtkPiecewiseFunction to use in mapping array values to sprite sizes. More...
void SetOpacityTransferFunction (vtkPiecewiseFunction *pwf)
 Sets a vtkPiecewiseFunction to use in mapping array values to sprite opacities. More...
void SelectOpacityArray (int, int, int, int, const char *name)
 Sets the point array to use in calculating point sprite opacities. More...
void SelectOpacityArrayComponent (int component)
 Sets the point array component to opacify the gaussians with. More...
void SetOpacityByArray (bool newVal)
 Enables or disables setting opacity by an array. More...
virtual bool GetOpacityByArray ()
virtual void OpacityByArrayOn ()
virtual void OpacityByArrayOff ()
void SetScaleByArray (bool newVal)
 Enables or disables scaling by a data array vs. More...
virtual bool GetScaleByArray ()
virtual void ScaleByArrayOn ()
virtual void ScaleByArrayOff ()
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPointGaussianRepresentation * SafeDownCast (vtkObject *o)
static vtkPointGaussianRepresentation * New ()
static vtkAlgorithm * New ()
 vtkPointGaussianRepresentation ()
 ~vtkPointGaussianRepresentation () override
void UpdateColoringParameters ()
virtual void SetLastScaleArray (const char *)
virtual void SetLastOpacityArray (const char *)
void InitializeShaderPresets ()
void UpdateMapperScaleFunction ()
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkSmartPointer< vtkActor > Actor
vtkSmartPointer< vtkPointGaussianMapper > Mapper
vtkSmartPointer< vtkDataObject > ProcessedData
vtkSmartPointer< vtkPiecewiseFunction > ScaleFunction
int SelectedPreset
bool ScaleByArray
char * LastScaleArray
int LastScaleArrayComponent
bool OpacityByArray
char * LastOpacityArray
int LastOpacityArrayComponent
bool UseScaleFunction
std::vector< std::string > PresetShaderStrings
std::vector< float > PresetShaderScales
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Representation for showing point data as sprites, including gaussian splats, spheres, or some custom shaded representation.
Definition at line 25 of file vtkPointGaussianRepresentation.h.
Definition at line 28 of file vtkPointGaussianRepresentation.h.
◆ ShaderPresets
Enumerator
GAUSSIAN_BLUR
SPHERE
BLACK_EDGED_CIRCLE
PLAIN_CIRCLE
TRIANGLE
SQUARE_OUTLINE
CUSTOM
NUMBER_OF_PRESETS
Definition at line 85 of file vtkPointGaussianRepresentation.h.
◆ vtkPointGaussianRepresentation()
vtkPointGaussianRepresentation::vtkPointGaussianRepresentation ( )
◆ ~vtkPointGaussianRepresentation()
vtkPointGaussianRepresentation::~vtkPointGaussianRepresentation ( )
virtual const char* vtkPointGaussianRepresentation::GetClassName ( )
static int vtkPointGaussianRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPointGaussianRepresentation::IsA ( const char *  type)
static vtkPointGaussianRepresentation* vtkPointGaussianRepresentation::SafeDownCast ( vtkObject *  o)
static vtkPointGaussianRepresentation* vtkPointGaussianRepresentation::New ( )
void vtkPointGaussianRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkPointGaussianRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
Note
Starting with ParaView 5.8, this method is no longer called for hidden representation i.e. representations for which vtkDataRepresentation::GetVisibility() returns false.
◆ SetLookupTable()
void vtkPointGaussianRepresentation::SetLookupTable ( vtkScalarsToColors *  lut)
◆ SetVisibility()
void vtkPointGaussianRepresentation::SetVisibility ( bool  val)
◆ SetEmissive()
virtual void vtkPointGaussianRepresentation::SetEmissive ( bool  val)
◆ SetMapScalars()
virtual void vtkPointGaussianRepresentation::SetMapScalars ( int  val)
◆ SetOrientation()
virtual void vtkPointGaussianRepresentation::SetOrientation ( double  ,
double  ,
double
◆ SetOrigin()
virtual void vtkPointGaussianRepresentation::SetOrigin ( double  ,
double  ,
double
◆ SetPickable()
virtual void vtkPointGaussianRepresentation::SetPickable ( int  val)
◆ SetPosition()
virtual void vtkPointGaussianRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetScale()
virtual void vtkPointGaussianRepresentation::SetScale ( double  ,
double  ,
double
◆ SetAmbientColor()
virtual void vtkPointGaussianRepresentation::SetAmbientColor ( double  r,
double  g,
double  b
◆ SetDiffuseColor()
virtual void vtkPointGaussianRepresentation::SetDiffuseColor ( double  r,
double  g,
double  b
◆ SetEdgeColor()
virtual void vtkPointGaussianRepresentation::SetEdgeColor ( double  r,
double  g,
double  b
◆ SetInterpolation()
virtual void vtkPointGaussianRepresentation::SetInterpolation ( int  val)
◆ SetLineWidth()
virtual void vtkPointGaussianRepresentation::SetLineWidth ( double  val)
◆ SetOpacity()
virtual void vtkPointGaussianRepresentation::SetOpacity ( double  val)
◆ SetPointSize()
virtual void vtkPointGaussianRepresentation::SetPointSize ( double  val)
◆ SetSpecularColor()
virtual void vtkPointGaussianRepresentation::SetSpecularColor ( double  r,
double  g,
double  b
◆ SetSpecularPower()
virtual void vtkPointGaussianRepresentation::SetSpecularPower ( double  val)
◆ SetSplatSize()
virtual void vtkPointGaussianRepresentation::SetSplatSize ( double  radius)
Defaults to 1.
◆ SelectShaderPreset()
void vtkPointGaussianRepresentation::SelectShaderPreset ( int  preset)
◆ SetCustomShader()
void vtkPointGaussianRepresentation::SetCustomShader ( const char *  shaderString)
◆ SetCustomTriangleScale()
void vtkPointGaussianRepresentation::SetCustomTriangleScale ( double  scale)
◆ SelectScaleArray()
void vtkPointGaussianRepresentation::SelectScaleArray ( int  ,
int  ,
int  ,
int  ,
const char *  name
The array should be a float array. The first four parameters are unused and only needed for the ParaView GUI's signature recognition.
◆ SelectScaleArrayComponent()
void vtkPointGaussianRepresentation::SelectScaleArrayComponent ( int  component)
◆ SetUseScaleFunction()
void vtkPointGaussianRepresentation::SetUseScaleFunction ( bool  enable)
If false, no mapping is done.
◆ SetScaleTransferFunction()
void vtkPointGaussianRepresentation::SetScaleTransferFunction ( vtkPiecewiseFunction *  pwf)
Performance decreases (along with understandability) when large values are used for sprite sizes. This is only used when "SetScaleArray" is also set.
◆ SetOpacityTransferFunction()
void vtkPointGaussianRepresentation::SetOpacityTransferFunction ( vtkPiecewiseFunction *  pwf)
Only used when "Opacity Array" is set.
◆ SelectOpacityArray()
void vtkPointGaussianRepresentation::SelectOpacityArray ( int  ,
int  ,
int  ,
int  ,
const char *  name
The array should be a float or double array. The first four parameters are unused and only needed for the ParaView GUI's signature recognition.
◆ SelectOpacityArrayComponent()
void vtkPointGaussianRepresentation::SelectOpacityArrayComponent ( int  component)
◆ SetOpacityByArray()
void vtkPointGaussianRepresentation::SetOpacityByArray ( bool  newVal)
Set which array should be used for opacity with SelectOpacityArray, and set an opacity transfer function with SetOpacityTransferFunction.
◆ GetOpacityByArray()
virtual bool vtkPointGaussianRepresentation::GetOpacityByArray ( )
◆ OpacityByArrayOn()
virtual void vtkPointGaussianRepresentation::OpacityByArrayOn ( )
◆ OpacityByArrayOff()
virtual void vtkPointGaussianRepresentation::OpacityByArrayOff ( )
◆ SetScaleByArray()
void vtkPointGaussianRepresentation::SetScaleByArray ( bool  newVal)
a constant factor. Set which data array with SelectScaleArray and SetSplatSize.
◆ GetScaleByArray()
virtual bool vtkPointGaussianRepresentation::GetScaleByArray ( )
◆ ScaleByArrayOn()
virtual void vtkPointGaussianRepresentation::ScaleByArrayOn ( )
◆ ScaleByArrayOff()
virtual void vtkPointGaussianRepresentation::ScaleByArrayOff ( )
◆ AddToView()
bool vtkPointGaussianRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkPointGaussianRepresentation::RemoveFromView ( vtkView *  view)
◆ FillInputPortInformation()
int vtkPointGaussianRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestData()
int vtkPointGaussianRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
◆ UpdateColoringParameters()
void vtkPointGaussianRepresentation::UpdateColoringParameters ( )
◆ SetLastScaleArray()
virtual void vtkPointGaussianRepresentation::SetLastScaleArray ( const char *  )
protectedvirtual
◆ SetLastOpacityArray()
virtual void vtkPointGaussianRepresentation::SetLastOpacityArray ( const char *  )
protectedvirtual
◆ InitializeShaderPresets()
void vtkPointGaussianRepresentation::InitializeShaderPresets ( )
◆ UpdateMapperScaleFunction()
void vtkPointGaussianRepresentation::UpdateMapperScaleFunction ( )
◆ Actor
vtkSmartPointer<vtkActor> vtkPointGaussianRepresentation::Actor
Definition at line 193 of file vtkPointGaussianRepresentation.h.
◆ Mapper
vtkSmartPointer<vtkPointGaussianMapper> vtkPointGaussianRepresentation::Mapper
Definition at line 194 of file vtkPointGaussianRepresentation.h.
◆ ProcessedData
vtkSmartPointer<vtkDataObject> vtkPointGaussianRepresentation::ProcessedData
Definition at line 195 of file vtkPointGaussianRepresentation.h.
◆ ScaleFunction
vtkSmartPointer<vtkPiecewiseFunction> vtkPointGaussianRepresentation::ScaleFunction
Definition at line 196 of file vtkPointGaussianRepresentation.h.
◆ SelectedPreset
int vtkPointGaussianRepresentation::SelectedPreset
Definition at line 198 of file vtkPointGaussianRepresentation.h.
◆ ScaleByArray
bool vtkPointGaussianRepresentation::ScaleByArray
Definition at line 200 of file vtkPointGaussianRepresentation.h.
◆ LastScaleArray
char* vtkPointGaussianRepresentation::LastScaleArray
Definition at line 201 of file vtkPointGaussianRepresentation.h.
◆ LastScaleArrayComponent
int vtkPointGaussianRepresentation::LastScaleArrayComponent
Definition at line 202 of file vtkPointGaussianRepresentation.h.
◆ OpacityByArray
bool vtkPointGaussianRepresentation::OpacityByArray
Definition at line 204 of file vtkPointGaussianRepresentation.h.
◆ LastOpacityArray
char* vtkPointGaussianRepresentation::LastOpacityArray
Definition at line 205 of file vtkPointGaussianRepresentation.h.
◆ LastOpacityArrayComponent
int vtkPointGaussianRepresentation::LastOpacityArrayComponent
Definition at line 206 of file vtkPointGaussianRepresentation.h.
◆ UseScaleFunction
bool vtkPointGaussianRepresentation::UseScaleFunction
Definition at line 208 of file vtkPointGaussianRepresentation.h.
◆ PresetShaderStrings
std::vector<std::string> vtkPointGaussianRepresentation::PresetShaderStrings
Definition at line 210 of file vtkPointGaussianRepresentation.h.
◆ PresetShaderScales
std::vector<float> vtkPointGaussianRepresentation::PresetShaderScales
Definition at line 211 of file vtkPointGaussianRepresentation.h.
