vtkParticlePipeline Class Reference
#include <vtkParticlePipeline.h>
Inheritance diagram for vtkParticlePipeline:
Collaboration diagram for vtkParticlePipeline:
typedef vtkCPPipeline Superclass
- Public Types inherited from vtkCPPipeline
int RequestDataDescription (vtkCPDataDescription *desc) override
 Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More...
int CoProcess (vtkCPDataDescription *desc) override
 Execute the pipeline. Returns 1 for success and 0 for failure. More...
virtual void SetFilename (const char *)
virtual char * GetFilename ()
virtual void SetParticleRadius (double)
virtual double GetParticleRadius ()
virtual void SetCameraThetaAngle (double)
virtual double GetCameraThetaAngle ()
virtual void SetCameraPhiAngle (double)
virtual double GetCameraPhiAngle ()
virtual void SetCameraDistance (double)
virtual double GetCameraDistance ()
virtual void SetBounds (double, double, double, double, double, double)
virtual void SetBounds (double[6])
virtual double * GetBounds ()
virtual void GetBounds (double data[6])
virtual void SetAttributeMaximum (double)
virtual double GetAttributeMaximum ()
virtual void SetAttributeMinimum (double)
virtual double GetAttributeMinimum ()
- Public Member Functions inherited from vtkCPPipeline
virtual int Finalize ()
 Finalize the pipeline before deleting it. More...
static vtkParticlePipeline * New ()
static vtkParticlePipeline * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPPipeline
static vtkCPPipeline * SafeDownCast (vtkObject *o)
 vtkParticlePipeline ()
 ~vtkParticlePipeline () override
void SetupPipeline ()
- Protected Member Functions inherited from vtkCPPipeline
 vtkCPPipeline ()
 ~vtkCPPipeline () override
char * Filename
double ParticleRadius
double CameraThetaAngle
double CameraPhiAngle
double CameraDistance
double Bounds [6]
double AttributeMaximum
double AttributeMinimum
vtkTrivialProducer * input
vtkColorTransferFunction * lut
vtkSphereSource * sphere
vtkOutlineSource * outline
vtkGlyph3DMapper * particleMapper
vtkPolyDataMapper * outlineMapper
vtkActor * particleActor
vtkActor * outlineActor
vtkLightKit * lightKit
vtkIceTSynchronizedRenderers * syncRen
vtkSynchronizedRenderWindows * syncWin
vtkRenderWindow * window
vtkRenderer * renderer
vtkWindowToImageFilter * w2i
vtkPNGWriter * writer
Definition at line 25 of file vtkParticlePipeline.h.
Definition at line 29 of file vtkParticlePipeline.h.
◆ vtkParticlePipeline()
vtkParticlePipeline::vtkParticlePipeline ( )
◆ ~vtkParticlePipeline()
vtkParticlePipeline::~vtkParticlePipeline ( )
static vtkParticlePipeline* vtkParticlePipeline::New ( )
virtual const char* vtkParticlePipeline::GetClassName ( )
Reimplemented from vtkCPPipeline.
static int vtkParticlePipeline::IsTypeOf ( const char *  type)
virtual int vtkParticlePipeline::IsA ( const char *  type)
static vtkParticlePipeline* vtkParticlePipeline::SafeDownCast ( vtkObject *  o)
void vtkParticlePipeline::PrintSelf ( ostream &  os,
◆ RequestDataDescription()
int vtkParticlePipeline::RequestDataDescription ( vtkCPDataDescription *  dataDescription)
If coprocessing does need to be performed this time step it fills in the FieldNames array that the coprocessor requires in order to fulfill all the coprocessing requests for this TimeStep/Time combination.
Implements vtkCPPipeline.
◆ CoProcess()
int vtkParticlePipeline::CoProcess ( vtkCPDataDescription *  dataDescription)
◆ SetFilename()
virtual void vtkParticlePipeline::SetFilename ( const char *  )
◆ GetFilename()
virtual char* vtkParticlePipeline::GetFilename ( )
◆ SetParticleRadius()
virtual void vtkParticlePipeline::SetParticleRadius ( double  )
◆ GetParticleRadius()
virtual double vtkParticlePipeline::GetParticleRadius ( )
◆ SetCameraThetaAngle()
virtual void vtkParticlePipeline::SetCameraThetaAngle ( double  )
◆ GetCameraThetaAngle()
virtual double vtkParticlePipeline::GetCameraThetaAngle ( )
◆ SetCameraPhiAngle()
virtual void vtkParticlePipeline::SetCameraPhiAngle ( double  )
◆ GetCameraPhiAngle()
virtual double vtkParticlePipeline::GetCameraPhiAngle ( )
◆ SetCameraDistance()
virtual void vtkParticlePipeline::SetCameraDistance ( double  )
◆ GetCameraDistance()
virtual double vtkParticlePipeline::GetCameraDistance ( )
◆ SetBounds() [1/2]
virtual void vtkParticlePipeline::SetBounds ( double  ,
double  ,
double  ,
double  ,
double  ,
double
◆ SetBounds() [2/2]
virtual void vtkParticlePipeline::SetBounds ( double  [6])
◆ GetBounds() [1/2]
virtual double* vtkParticlePipeline::GetBounds ( )
◆ GetBounds() [2/2]
virtual void vtkParticlePipeline::GetBounds ( double  data[6])
◆ SetAttributeMaximum()
virtual void vtkParticlePipeline::SetAttributeMaximum ( double  )
◆ GetAttributeMaximum()
virtual double vtkParticlePipeline::GetAttributeMaximum ( )
◆ SetAttributeMinimum()
virtual void vtkParticlePipeline::SetAttributeMinimum ( double  )
◆ GetAttributeMinimum()
virtual double vtkParticlePipeline::GetAttributeMinimum ( )
◆ SetupPipeline()
void vtkParticlePipeline::SetupPipeline ( )
◆ Filename
char* vtkParticlePipeline::Filename
Definition at line 81 of file vtkParticlePipeline.h.
◆ ParticleRadius
double vtkParticlePipeline::ParticleRadius
Definition at line 83 of file vtkParticlePipeline.h.
◆ CameraThetaAngle
double vtkParticlePipeline::CameraThetaAngle
Definition at line 85 of file vtkParticlePipeline.h.
◆ CameraPhiAngle
double vtkParticlePipeline::CameraPhiAngle
Definition at line 86 of file vtkParticlePipeline.h.
◆ CameraDistance
double vtkParticlePipeline::CameraDistance
Definition at line 87 of file vtkParticlePipeline.h.
◆ Bounds
double vtkParticlePipeline::Bounds[6]
Definition at line 89 of file vtkParticlePipeline.h.
◆ AttributeMaximum
double vtkParticlePipeline::AttributeMaximum
Definition at line 91 of file vtkParticlePipeline.h.
◆ AttributeMinimum
double vtkParticlePipeline::AttributeMinimum
Definition at line 92 of file vtkParticlePipeline.h.
◆ input
vtkTrivialProducer* vtkParticlePipeline::input
Definition at line 94 of file vtkParticlePipeline.h.
◆ lut
vtkColorTransferFunction* vtkParticlePipeline::lut
Definition at line 95 of file vtkParticlePipeline.h.
◆ sphere
vtkSphereSource* vtkParticlePipeline::sphere
Definition at line 96 of file vtkParticlePipeline.h.
◆ outline
vtkOutlineSource* vtkParticlePipeline::outline
Definition at line 97 of file vtkParticlePipeline.h.
◆ particleMapper
vtkGlyph3DMapper* vtkParticlePipeline::particleMapper
Definition at line 98 of file vtkParticlePipeline.h.
◆ outlineMapper
vtkPolyDataMapper* vtkParticlePipeline::outlineMapper
Definition at line 99 of file vtkParticlePipeline.h.
◆ particleActor
vtkActor* vtkParticlePipeline::particleActor
Definition at line 100 of file vtkParticlePipeline.h.
◆ outlineActor
vtkActor* vtkParticlePipeline::outlineActor
Definition at line 101 of file vtkParticlePipeline.h.
◆ lightKit
vtkLightKit* vtkParticlePipeline::lightKit
Definition at line 102 of file vtkParticlePipeline.h.
◆ syncRen
vtkIceTSynchronizedRenderers* vtkParticlePipeline::syncRen
Definition at line 103 of file vtkParticlePipeline.h.
◆ syncWin
vtkSynchronizedRenderWindows* vtkParticlePipeline::syncWin
Definition at line 104 of file vtkParticlePipeline.h.
◆ window
vtkRenderWindow* vtkParticlePipeline::window
Definition at line 105 of file vtkParticlePipeline.h.
◆ renderer
vtkRenderer* vtkParticlePipeline::renderer
Definition at line 106 of file vtkParticlePipeline.h.
◆ w2i
vtkWindowToImageFilter* vtkParticlePipeline::w2i
Definition at line 107 of file vtkParticlePipeline.h.
◆ writer
vtkPNGWriter* vtkParticlePipeline::writer
Definition at line 108 of file vtkParticlePipeline.h.
