vtkCPDataDescription Class Reference
#include <vtkCPDataDescription.h>
Inheritance diagram for vtkCPDataDescription:
Collaboration diagram for vtkCPDataDescription:
void SetTimeData (double time, vtkIdType timeStep)
 Set the time step and current simulation time. More...
virtual vtkIdType GetTimeStep ()
 Get the current time step that should be set in the adaptor. More...
virtual double GetTime ()
 Get the current time that should be set in the adaptor. More...
virtual void SetForceOutput (bool)
 Specify whether or not to force output of all coprocessing pipelines. More...
virtual void ForceOutputOn ()
virtual void ForceOutputOff ()
virtual bool GetForceOutput ()
 Return whether or not output is forced for all coprocessing pipelines. More...
void AddInput (const char *gridName)
 Add names for grids produced by the simulation. More...
unsigned int GetNumberOfInputDescriptions ()
 Returns the number of input descriptions. More...
void ResetInputDescriptions ()
 Reset the names of the fields that are needed, the required meshes, etc. More...
void ResetAll ()
vtkCPInputDataDescription * GetInputDescription (unsigned int)
 Provides access to a grid description using the index. More...
const char * GetInputDescriptionName (unsigned int)
 Provides the name for the input description at the given index. More...
vtkCPInputDataDescription * GetInputDescriptionByName (const char *)
 Provides access to a grid description using the grid name. More...
bool GetIfGridIsNecessary (const char *)
 Returns true if the grid is necessary, given the grid's name. More...
bool GetIfAnyGridNecessary ()
 Returns true if any of the grids is necessary. More...
void SetUserData (vtkFieldData *UserData)
 Set user defined information that can be passed from the adaptor to the coprocessing pipelines. More...
virtual vtkFieldData * GetUserData ()
void Copy (vtkCPDataDescription *)
 Copy of dataDescription. More...
static vtkCPDataDescription * New ()
static vtkCPDataDescription * SafeDownCast (vtkObject *o)
 vtkCPDataDescription ()
 ~vtkCPDataDescription () override
This class provides the description of the data for the coprocessor pipelines.
Definition at line 15 of file vtkCPDataDescription.h.
Definition at line 19 of file vtkCPDataDescription.h.
◆ vtkCPDataDescription()
vtkCPDataDescription::vtkCPDataDescription ( )
◆ ~vtkCPDataDescription()
vtkCPDataDescription::~vtkCPDataDescription ( )
static vtkCPDataDescription* vtkCPDataDescription::New ( )
virtual const char* vtkCPDataDescription::GetClassName ( )
static int vtkCPDataDescription::IsTypeOf ( const char *  type)
virtual int vtkCPDataDescription::IsA ( const char *  type)
static vtkCPDataDescription* vtkCPDataDescription::SafeDownCast ( vtkObject *  o)
void vtkCPDataDescription::PrintSelf ( ostream &  os,
◆ SetTimeData()
void vtkCPDataDescription::SetTimeData ( double  time,
vtkIdType  timeStep
◆ GetTimeStep()
virtual vtkIdType vtkCPDataDescription::GetTimeStep ( )
◆ GetTime()
virtual double vtkCPDataDescription::GetTime ( )
◆ SetForceOutput()
virtual void vtkCPDataDescription::SetForceOutput ( bool  )
This is meant to be set in the adaptor and used in the coprocessing pipeline. Default is false. If this is true then GetIsGridNecessary() and GetIfAnyGridIsNecessary() will return true.
◆ ForceOutputOn()
virtual void vtkCPDataDescription::ForceOutputOn ( )
◆ ForceOutputOff()
virtual void vtkCPDataDescription::ForceOutputOff ( )
◆ GetForceOutput()
virtual bool vtkCPDataDescription::GetForceOutput ( )
◆ AddInput()
void vtkCPDataDescription::AddInput ( const char *  gridName)
This allocates a new vtkCPInputDataDescription for that grid, if a grid by that name does not already exist.
◆ GetNumberOfInputDescriptions()
unsigned int vtkCPDataDescription::GetNumberOfInputDescriptions ( )
◆ ResetInputDescriptions()
void vtkCPDataDescription::ResetInputDescriptions ( )
that are stored in the vtkCPInputDescriptions.
◆ ResetAll()
void vtkCPDataDescription::ResetAll ( )
that are stored in the vtkCPInputDescriptions as well as the time information and output forcing. Automatically called after vtkCPProcessor::CoProcess() is called.
◆ GetInputDescription()
vtkCPInputDataDescription* vtkCPDataDescription::GetInputDescription ( unsigned int  )
◆ GetInputDescriptionName()
const char* vtkCPDataDescription::GetInputDescriptionName ( unsigned int  )
◆ GetInputDescriptionByName()
vtkCPInputDataDescription* vtkCPDataDescription::GetInputDescriptionByName ( const char *  )
◆ GetIfGridIsNecessary()
bool vtkCPDataDescription::GetIfGridIsNecessary ( const char *  )
◆ GetIfAnyGridNecessary()
bool vtkCPDataDescription::GetIfAnyGridNecessary ( )
◆ SetUserData()
void vtkCPDataDescription::SetUserData ( vtkFieldData *  UserData)
◆ GetUserData()
virtual vtkFieldData* vtkCPDataDescription::GetUserData ( )
◆ Copy()
void vtkCPDataDescription::Copy ( vtkCPDataDescription *  )
Does a deep copy of the data members but a shallow copy of the vtkDataObjects.
