vtkPVSinusoidKeyFrame Class Reference
#include <vtkPVSinusoidKeyFrame.h>
Inheritance diagram for vtkPVSinusoidKeyFrame:
Collaboration diagram for vtkPVSinusoidKeyFrame:
typedef vtkPVKeyFrame Superclass
- Public Types inherited from vtkPVKeyFrame
void UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) override
 This method will do the actual interpolation. More...
virtual void SetPhase (double)
 Get/Set the phase for the sine wave. More...
virtual double GetPhase ()
virtual void SetFrequency (double)
 Get/Set the frequency for the sine wave in number of cycles for the entire length of this keyframe i.e. More...
virtual double GetFrequency ()
virtual void SetOffset (double)
 Get/Set the Wave offset. More...
virtual double GetOffset ()
- Public Member Functions inherited from vtkPVKeyFrame
virtual void RemoveAllKeyValues ()
 Removes all key values. More...
virtual void SetKeyTime (double)
 Key time is the time at which this key frame is associated. More...
virtual double GetKeyTime ()
virtual void SetKeyValue (double val)
 Get/Set the animated value at this key frame. More...
virtual void SetKeyValue (unsigned int index, double val)
double GetKeyValue ()
double GetKeyValue (unsigned int index)
unsigned int GetNumberOfKeyValues ()
 Set/Get the number of key values this key frame currently stores. More...
virtual void SetNumberOfKeyValues (unsigned int num)
static vtkPVSinusoidKeyFrame * New ()
static vtkPVSinusoidKeyFrame * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVKeyFrame
static vtkPVKeyFrame * SafeDownCast (vtkObject *o)
static vtkPVKeyFrame * New ()
 vtkPVSinusoidKeyFrame ()
 ~vtkPVSinusoidKeyFrame () override
- Protected Member Functions inherited from vtkPVKeyFrame
 vtkPVKeyFrame ()
 ~vtkPVKeyFrame () override
double Phase
double Frequency
double Offset
- Protected Attributes inherited from vtkPVKeyFrame
double KeyTime
vtkPVKeyFrameInternals * Internals
Interplates a sinusoid. At any given time t, the resultant value obtained from this keyframe is given by : value = this->Offset + (Key Value) * Sin (2*pi*theta); where theta = this->Frequency*t + (this->Phase/360). As is clear from the equation, the amplitude of the wave is obtained from the value of the keyframe.
Definition at line 19 of file vtkPVSinusoidKeyFrame.h.
Definition at line 23 of file vtkPVSinusoidKeyFrame.h.
◆ vtkPVSinusoidKeyFrame()
vtkPVSinusoidKeyFrame::vtkPVSinusoidKeyFrame ( )
◆ ~vtkPVSinusoidKeyFrame()
vtkPVSinusoidKeyFrame::~vtkPVSinusoidKeyFrame ( )
static vtkPVSinusoidKeyFrame* vtkPVSinusoidKeyFrame::New ( )
virtual const char* vtkPVSinusoidKeyFrame::GetClassName ( )
Reimplemented from vtkPVKeyFrame.
static int vtkPVSinusoidKeyFrame::IsTypeOf ( const char *  type)
virtual int vtkPVSinusoidKeyFrame::IsA ( const char *  type)
static vtkPVSinusoidKeyFrame* vtkPVSinusoidKeyFrame::SafeDownCast ( vtkObject *  o)
void vtkPVSinusoidKeyFrame::PrintSelf ( ostream &  os,
◆ UpdateValue()
void vtkPVSinusoidKeyFrame::UpdateValue ( double  currenttime,
vtkPVAnimationCue *  cue,
vtkPVKeyFrame *  next
currenttime is normalized to the time range between this key frame and the next key frame.
◆ SetPhase()
virtual void vtkPVSinusoidKeyFrame::SetPhase ( double  )
◆ GetPhase()
virtual double vtkPVSinusoidKeyFrame::GetPhase ( )
◆ SetFrequency()
virtual void vtkPVSinusoidKeyFrame::SetFrequency ( double  )
until the next key frame.
◆ GetFrequency()
virtual double vtkPVSinusoidKeyFrame::GetFrequency ( )
◆ SetOffset()
virtual void vtkPVSinusoidKeyFrame::SetOffset ( double  )
◆ GetOffset()
virtual double vtkPVSinusoidKeyFrame::GetOffset ( )
◆ Phase
double vtkPVSinusoidKeyFrame::Phase
Definition at line 62 of file vtkPVSinusoidKeyFrame.h.
◆ Frequency
double vtkPVSinusoidKeyFrame::Frequency
Definition at line 63 of file vtkPVSinusoidKeyFrame.h.
◆ Offset
double vtkPVSinusoidKeyFrame::Offset
Definition at line 64 of file vtkPVSinusoidKeyFrame.h.
