vtkPVRampKeyFrame Class Reference
#include <vtkPVRampKeyFrame.h>
Inheritance diagram for vtkPVRampKeyFrame:
Collaboration diagram for vtkPVRampKeyFrame:
typedef vtkPVKeyFrame Superclass
- Public Types inherited from vtkPVKeyFrame
void UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) override
 This method will do the actual interpolation. More...
- Public Member Functions inherited from vtkPVKeyFrame
virtual void RemoveAllKeyValues ()
 Removes all key values. More...
virtual void SetKeyTime (double)
 Key time is the time at which this key frame is associated. More...
virtual double GetKeyTime ()
virtual void SetKeyValue (double val)
 Get/Set the animated value at this key frame. More...
virtual void SetKeyValue (unsigned int index, double val)
double GetKeyValue ()
double GetKeyValue (unsigned int index)
unsigned int GetNumberOfKeyValues ()
 Set/Get the number of key values this key frame currently stores. More...
virtual void SetNumberOfKeyValues (unsigned int num)
static vtkPVRampKeyFrame * New ()
static vtkPVRampKeyFrame * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVKeyFrame
static vtkPVKeyFrame * SafeDownCast (vtkObject *o)
static vtkPVKeyFrame * New ()
 vtkPVRampKeyFrame ()
 ~vtkPVRampKeyFrame () override
- Protected Member Functions inherited from vtkPVKeyFrame
 vtkPVKeyFrame ()
 ~vtkPVKeyFrame () override
- Protected Attributes inherited from vtkPVKeyFrame
double KeyTime
vtkPVKeyFrameInternals * Internals
Interplates lineraly between consecutive key frames.
Definition at line 14 of file vtkPVRampKeyFrame.h.
Definition at line 18 of file vtkPVRampKeyFrame.h.
◆ vtkPVRampKeyFrame()
vtkPVRampKeyFrame::vtkPVRampKeyFrame ( )
◆ ~vtkPVRampKeyFrame()
vtkPVRampKeyFrame::~vtkPVRampKeyFrame ( )
static vtkPVRampKeyFrame* vtkPVRampKeyFrame::New ( )
virtual const char* vtkPVRampKeyFrame::GetClassName ( )
Reimplemented from vtkPVKeyFrame.
static int vtkPVRampKeyFrame::IsTypeOf ( const char *  type)
virtual int vtkPVRampKeyFrame::IsA ( const char *  type)
static vtkPVRampKeyFrame* vtkPVRampKeyFrame::SafeDownCast ( vtkObject *  o)
void vtkPVRampKeyFrame::PrintSelf ( ostream &  os,
◆ UpdateValue()
void vtkPVRampKeyFrame::UpdateValue ( double  currenttime,
vtkPVAnimationCue *  cue,
vtkPVKeyFrame *  next
currenttime is normalized to the time range between this key frame and the next key frame.
