vtkPVExponentialKeyFrame Class Reference
#include <vtkPVExponentialKeyFrame.h>
Inheritance diagram for vtkPVExponentialKeyFrame:
Collaboration diagram for vtkPVExponentialKeyFrame:
typedef vtkPVKeyFrame Superclass
- Public Types inherited from vtkPVKeyFrame
void UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) override
 This method will do the actual interpolation. More...
virtual void SetStartPower (double)
virtual double GetStartPower ()
virtual void SetEndPower (double)
virtual double GetEndPower ()
virtual void SetBase (double)
 Base to be used for exponential function. More...
virtual double GetBase ()
- Public Member Functions inherited from vtkPVKeyFrame
virtual void RemoveAllKeyValues ()
 Removes all key values. More...
virtual void SetKeyTime (double)
 Key time is the time at which this key frame is associated. More...
virtual double GetKeyTime ()
virtual void SetKeyValue (double val)
 Get/Set the animated value at this key frame. More...
virtual void SetKeyValue (unsigned int index, double val)
double GetKeyValue ()
double GetKeyValue (unsigned int index)
unsigned int GetNumberOfKeyValues ()
 Set/Get the number of key values this key frame currently stores. More...
virtual void SetNumberOfKeyValues (unsigned int num)
static vtkPVExponentialKeyFrame * SafeDownCast (vtkObject *o)
static vtkPVExponentialKeyFrame * New ()
- Static Public Member Functions inherited from vtkPVKeyFrame
static vtkPVKeyFrame * SafeDownCast (vtkObject *o)
static vtkPVKeyFrame * New ()
 vtkPVExponentialKeyFrame ()
 ~vtkPVExponentialKeyFrame () override
- Protected Member Functions inherited from vtkPVKeyFrame
 vtkPVKeyFrame ()
 ~vtkPVKeyFrame () override
double Base
double StartPower
double EndPower
- Protected Attributes inherited from vtkPVKeyFrame
double KeyTime
vtkPVKeyFrameInternals * Internals
Interplates lineraly between consecutive key frames.
Definition at line 14 of file vtkPVExponentialKeyFrame.h.
Definition at line 17 of file vtkPVExponentialKeyFrame.h.
◆ vtkPVExponentialKeyFrame()
vtkPVExponentialKeyFrame::vtkPVExponentialKeyFrame ( )
◆ ~vtkPVExponentialKeyFrame()
vtkPVExponentialKeyFrame::~vtkPVExponentialKeyFrame ( )
virtual const char* vtkPVExponentialKeyFrame::GetClassName ( )
Reimplemented from vtkPVKeyFrame.
static int vtkPVExponentialKeyFrame::IsTypeOf ( const char *  type)
virtual int vtkPVExponentialKeyFrame::IsA ( const char *  type)
static vtkPVExponentialKeyFrame* vtkPVExponentialKeyFrame::SafeDownCast ( vtkObject *  o)
void vtkPVExponentialKeyFrame::PrintSelf ( ostream &  os,
static vtkPVExponentialKeyFrame* vtkPVExponentialKeyFrame::New ( )
◆ UpdateValue()
void vtkPVExponentialKeyFrame::UpdateValue ( double  currenttime,
vtkPVAnimationCue *  cue,
vtkPVKeyFrame *  next
currenttime is normalized to the time range between this key frame and the next key frame.
◆ SetBase()
virtual void vtkPVExponentialKeyFrame::SetBase ( double  )
◆ GetBase()
virtual double vtkPVExponentialKeyFrame::GetBase ( )
◆ SetStartPower()
virtual void vtkPVExponentialKeyFrame::SetStartPower ( double  )
◆ GetStartPower()
virtual double vtkPVExponentialKeyFrame::GetStartPower ( )
◆ SetEndPower()
virtual void vtkPVExponentialKeyFrame::SetEndPower ( double  )
◆ GetEndPower()
virtual double vtkPVExponentialKeyFrame::GetEndPower ( )
◆ Base
double vtkPVExponentialKeyFrame::Base
Definition at line 46 of file vtkPVExponentialKeyFrame.h.
◆ StartPower
double vtkPVExponentialKeyFrame::StartPower
Definition at line 47 of file vtkPVExponentialKeyFrame.h.
◆ EndPower
double vtkPVExponentialKeyFrame::EndPower
Definition at line 48 of file vtkPVExponentialKeyFrame.h.
