Convert a client-side selection into proxies holding server-side selection sources.
| virtual bool | ProcessSelection (vtkSelection *rawSelection, vtkSMRenderViewProxy *viewProxy, bool multipleSelectionsAllowed, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, int modifier, bool selectBlocks) |
| | Populate the selection sources given a raw (client-side) selection. More...
In ParaView, selection occurs on the client using a framebuffer whose pixel-values have associated prop, cell, and point IDs obtained by compositing images rendered on each server. The selection is then simplified and broadcast to the server(s) where representations are provided access.
By subclassing this object and registering a vtkObjectFactory override, it is possible for applications to get access to the raw selection (with prop IDs and other information) that is created on the client before it is simplified, serialized, and sent to the server.
Definition at line 32 of file vtkPVEncodeSelectionForServer.h.
