vtkPVComparativeView Class Reference
view for comparative visualization/ film-strips. More...
#include <vtkPVComparativeView.h>
Inheritance diagram for vtkPVComparativeView:
Collaboration diagram for vtkPVComparativeView:
void Initialize (unsigned int)
 Provides empty handlers to simulate the vtkPVView API. More...
void StillRender ()
 Call StillRender() on the root view. More...
void InteractiveRender ()
 Call InteractiveRender() on the root view. More...
void Initialize (vtkSMViewProxy *rootView)
 Initialize the vtkPVComparativeView giving the root view proxy to be used to create the comparative views. More...
void Build (int dx, int dy)
 Builds the MxN views. More...
void AddRepresentation (vtkSMProxy *)
 Adds a representation proxy to this view. More...
void RemoveRepresentation (vtkSMProxy *)
 Removes a representation proxy from this view. More...
void Update ()
 Updates the data pipelines for all visible representations. More...
void GetViews (vtkCollection *collection)
 Get all the internal views. More...
void SetPPI (int)
 Satisfying vtkPVView API. More...
void MarkOutdated ()
 Marks the view dirty i.e. More...
void PrepareForScreenshot ()
 These methods mimic the vtkPVView API. More...
void CleanupAfterScreenshot ()
vtkImageDataCaptureWindow (int magX, int magY)
void SetOverlayAllComparisons (bool)
 When set to true, all comparisons are shown in the same view. More...
virtual bool GetOverlayAllComparisons ()
virtual intGetDimensions ()
 Returns the dimensions used by the most recent Build() request. More...
virtual void GetDimensions (int &, int &)
virtual void GetDimensions (int[2])
virtual vtkSMViewProxyGetRootView ()
 Returns the root view proxy. More...
void SetViewSize (int x, int y)
 ViewSize, ViewPosition need to split up among all the component views correctly. More...
void SetViewPosition (int x, int y)
void SetTileScale (int x, int y)
 When saving screenshots with tiling, these methods get called. More...
void SetTileViewport (double x0, double y0, double x1, double y1)
virtual void SetSpacing (int, int)
 Set spacing between views. More...
void SetSpacing (int[2])
virtual intGetSpacing ()
virtual void GetSpacing (int &, int &)
virtual void GetSpacing (int[2])
void AddCue (vtkSMComparativeAnimationCueProxy *)
 Add/Remove parameter cues. More...
void RemoveCue (vtkSMComparativeAnimationCueProxy *)
virtual double GetViewTime ()
 Get/Set the view time. More...
void SetViewTime (double time)
static vtkPVComparativeViewNew ()
static vtkPVComparativeViewSafeDownCast (vtkObject *o)
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVComparativeView ()
 ~vtkPVComparativeView () override
void UpdateViewLayout ()
 Update layout for internal views. More...
void SetRootView (vtkSMViewProxy *)
int Dimensions [2]
int ViewSize [2]
int ViewPosition [2]
int Spacing [2]
double ViewTime
bool OverlayAllComparisons
bool Outdated
vtkSMViewProxyRootView
vtkPVComparativeView is the view used to generate/view comparative visualizations/film-strips. This is not a proxy
Definition at line 24 of file vtkPVComparativeView.h.
Definition at line 28 of file vtkPVComparativeView.h.
◆ vtkPVComparativeView()
vtkPVComparativeView::vtkPVComparativeView ( )
◆ ~vtkPVComparativeView()
vtkPVComparativeView::~vtkPVComparativeView ( )
static vtkPVComparativeView* vtkPVComparativeView::New ( )
virtual const char* vtkPVComparativeView::GetClassName ( )
static int vtkPVComparativeView::IsTypeOf ( const char *  type)
virtual int vtkPVComparativeView::IsA ( const char *  type)
static vtkPVComparativeView* vtkPVComparativeView::SafeDownCast ( vtkObject o)
void vtkPVComparativeView::PrintSelf ( ostream &  os,
◆ Initialize() [1/2]
void vtkPVComparativeView::Initialize ( unsigned int  )
inline
Definition at line 34 of file vtkPVComparativeView.h.
◆ StillRender()
void vtkPVComparativeView::StillRender ( )
◆ InteractiveRender()
void vtkPVComparativeView::InteractiveRender ( )
◆ Initialize() [2/2]
void vtkPVComparativeView::Initialize ( vtkSMViewProxy rootView)
◆ Build()
void vtkPVComparativeView::Build ( int  dx,
int  dy
This method simply creates the MxN internal view modules. It does not generate the visualization i.e. play the animation scene(s). This method does nothing unless the dimensions have changed, in which case it creates new internal view modules (or destroys extra ones). Note that the it's the responsibility of the application to lay the views out so that they form a MxN grid.
◆ SetOverlayAllComparisons()
void vtkPVComparativeView::SetOverlayAllComparisons ( bool  )
Otherwise, they are tiled in separate views.
◆ GetOverlayAllComparisons()
virtual bool vtkPVComparativeView::GetOverlayAllComparisons ( )
◆ GetDimensions() [1/3]
virtual int* vtkPVComparativeView::GetDimensions ( )
◆ GetDimensions() [2/3]
virtual void vtkPVComparativeView::GetDimensions ( int ,
int
◆ GetDimensions() [3/3]
virtual void vtkPVComparativeView::GetDimensions ( int  [2])
◆ AddRepresentation()
void vtkPVComparativeView::AddRepresentation ( vtkSMProxy )
◆ RemoveRepresentation()
void vtkPVComparativeView::RemoveRepresentation ( vtkSMProxy )
◆ Update()
void vtkPVComparativeView::Update ( )
◆ GetViews()
void vtkPVComparativeView::GetViews ( vtkCollection collection)
The views should only be used to be laid out by the GUI. It's not recommended to directly change the properties of the views.
◆ GetRootView()
virtual vtkSMViewProxy* vtkPVComparativeView::GetRootView ( )
◆ SetViewSize()
void vtkPVComparativeView::SetViewSize ( int  x,
int  y
inline
Definition at line 112 of file vtkPVComparativeView.h.
◆ SetViewPosition()
void vtkPVComparativeView::SetViewPosition ( int  x,
int  y
inline
Definition at line 125 of file vtkPVComparativeView.h.
◆ SetTileScale()
void vtkPVComparativeView::SetTileScale ( int  x,
int  y
Not to be confused with tile scale and viewport setup on tile display.
See also
vtkViewLayout::UpdateLayoutForTileDisplay
◆ SetTileViewport()
void vtkPVComparativeView::SetTileViewport ( double  x0,
double  y0,
double  x1,
double  y1
See also
◆ SetPPI()
void vtkPVComparativeView::SetPPI ( int  )
inline
We don't need to do anything here since the subviews have their own PPI settings.
Definition at line 148 of file vtkPVComparativeView.h.
◆ SetSpacing() [1/2]
virtual void vtkPVComparativeView::SetSpacing ( int  ,
int
◆ SetSpacing() [2/2]
void vtkPVComparativeView::SetSpacing ( int  [2])
◆ GetSpacing() [1/3]
virtual int* vtkPVComparativeView::GetSpacing ( )
◆ GetSpacing() [2/3]
virtual void vtkPVComparativeView::GetSpacing ( int ,
int
◆ GetSpacing() [3/3]
virtual void vtkPVComparativeView::GetSpacing ( int  [2])
◆ AddCue()
void vtkPVComparativeView::AddCue ( vtkSMComparativeAnimationCueProxy )
◆ RemoveCue()
void vtkPVComparativeView::RemoveCue ( vtkSMComparativeAnimationCueProxy )
◆ GetViewTime()
virtual double vtkPVComparativeView::GetViewTime ( )
◆ SetViewTime()
void vtkPVComparativeView::SetViewTime ( double  time)
inline
Definition at line 171 of file vtkPVComparativeView.h.
◆ MarkOutdated()
void vtkPVComparativeView::MarkOutdated ( )
inline
on next Update() it needs to regenerate the comparative vis by replaying the animation(s).
Definition at line 186 of file vtkPVComparativeView.h.
◆ PrepareForScreenshot()
void vtkPVComparativeView::PrepareForScreenshot ( )
inline
They do nothing here since each view internal view will call PrepareForScreenshot and CleanupAfterScreenshot explicitly when we capture the images from each of them as needed.
Definition at line 193 of file vtkPVComparativeView.h.
◆ CleanupAfterScreenshot()
void vtkPVComparativeView::CleanupAfterScreenshot ( )
inline
Definition at line 194 of file vtkPVComparativeView.h.
◆ CaptureWindow()
vtkImageData* vtkPVComparativeView::CaptureWindow ( int  magX,
int  magY
◆ UpdateViewLayout()
void vtkPVComparativeView::UpdateViewLayout ( )
◆ SetRootView()
void vtkPVComparativeView::SetRootView ( vtkSMViewProxy )
◆ Dimensions
int vtkPVComparativeView::Dimensions[2]
Definition at line 206 of file vtkPVComparativeView.h.
◆ ViewSize
int vtkPVComparativeView::ViewSize[2]
Definition at line 207 of file vtkPVComparativeView.h.
◆ ViewPosition
int vtkPVComparativeView::ViewPosition[2]
Definition at line 208 of file vtkPVComparativeView.h.
◆ Spacing
int vtkPVComparativeView::Spacing[2]
Definition at line 209 of file vtkPVComparativeView.h.
◆ ViewTime
double vtkPVComparativeView::ViewTime
Definition at line 210 of file vtkPVComparativeView.h.
◆ OverlayAllComparisons
bool vtkPVComparativeView::OverlayAllComparisons
Definition at line 211 of file vtkPVComparativeView.h.
◆ Outdated
bool vtkPVComparativeView::Outdated
Definition at line 212 of file vtkPVComparativeView.h.
◆ RootView
vtkSMViewProxy* vtkPVComparativeView::RootView
Definition at line 215 of file vtkPVComparativeView.h.
