vtkImageCompressor Class Referenceabstract
Superclass for image compressor/decompressor used by Composite Managers. More...
#include <vtkImageCompressor.h>
Inheritance diagram for vtkImageCompressor:
Collaboration diagram for vtkImageCompressor:
virtual int Compress ()=0
 Call this method to compress the input and generate the compressed data. More...
virtual int Decompress ()=0
 Decompresses and geenartes the decompressed data as output. More...
virtual void SetImageResolution (int width, int height)
 Communicates the next expected image resolution. More...
virtual void SaveConfiguration (vtkMultiProcessStream *stream)
 Serialize compressor configuration (but not the data) into the stream. More...
virtual bool RestoreConfiguration (vtkMultiProcessStream *stream)
 Restore state from the stream. More...
virtual const char * SaveConfiguration ()
virtual const char * RestoreConfiguration (const char *stream)
 Restore state from the stream, The stream format for all image compressor is: [ClassName, LossLessMode, [Derived Class Stream]]. More...
void SetInput (vtkUnsignedCharArray *input)
 Get/Set the input to this compressor. More...
virtual vtkUnsignedCharArray * GetInput ()
virtual vtkUnsignedCharArray * GetOutput ()
 Get/Set the output of the compressor. More...
void SetOutput (vtkUnsignedCharArray *)
virtual void SetLossLessMode (int)
 When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More...
virtual int GetLossLessMode ()
static vtkImageCompressor * SafeDownCast (vtkObject *o)
virtual void SetConfiguration (const char *)
 vtkImageCompressor ()
 Construct with nullptr input array and empty but allocated output array. More...
 ~vtkImageCompressor () override
vtkUnsignedCharArray * Output
vtkUnsignedCharArray * Input
int LossLessMode
char * Configuration
vtkImageCompressor is an abstract superclass for the helper object used to compress images by the vtkParallelManager subclasses. Compressors must implement Compress,Decomperss methods, which respect the LossLessMode ivar, which is used by the composite manager to force loss less compression during a still render. Additionally compressors must be able to seriealize and restore their setting from a stream.
Definition at line 27 of file vtkImageCompressor.h.
Definition at line 30 of file vtkImageCompressor.h.
◆ vtkImageCompressor()
vtkImageCompressor::vtkImageCompressor ( )
◆ ~vtkImageCompressor()
vtkImageCompressor::~vtkImageCompressor ( )
virtual const char* vtkImageCompressor::GetClassName ( )
static int vtkImageCompressor::IsTypeOf ( const char *  type)
virtual int vtkImageCompressor::IsA ( const char *  type)
static vtkImageCompressor* vtkImageCompressor::SafeDownCast ( vtkObject *  o)
void vtkImageCompressor::PrintSelf ( ostream &  os,
◆ SetInput()
void vtkImageCompressor::SetInput ( vtkUnsignedCharArray *  input)
◆ GetInput()
virtual vtkUnsignedCharArray* vtkImageCompressor::GetInput ( )
◆ GetOutput()
virtual vtkUnsignedCharArray* vtkImageCompressor::GetOutput ( )
◆ SetOutput()
void vtkImageCompressor::SetOutput ( vtkUnsignedCharArray *  )
◆ SetLossLessMode()
virtual void vtkImageCompressor::SetLossLessMode ( int  )
Reimplemented in vtkZlibImageCompressor.
◆ GetLossLessMode()
virtual int vtkImageCompressor::GetLossLessMode ( )
◆ Compress()
virtual int vtkImageCompressor::Compress ( )
pure virtual
Implemented in vtkSquirtCompressor, vtkLZ4Compressor, vtkZlibImageCompressor, and vtkNvPipeCompressor.
◆ Decompress()
virtual int vtkImageCompressor::Decompress ( )
pure virtual
Input must be compressed data.
◆ SetImageResolution()
virtual void vtkImageCompressor::SetImageResolution ( int  width,
int  height
Reimplemented in vtkNvPipeCompressor.
◆ SaveConfiguration() [1/2]
virtual void vtkImageCompressor::SaveConfiguration ( vtkMultiProcessStream *  stream)
Reimplemented in vtkSquirtCompressor, vtkLZ4Compressor, vtkZlibImageCompressor, and vtkNvPipeCompressor.
◆ RestoreConfiguration() [1/2]
virtual bool vtkImageCompressor::RestoreConfiguration ( vtkMultiProcessStream *  stream)
◆ SaveConfiguration() [2/2]
virtual const char* vtkImageCompressor::SaveConfiguration ( )
A pointer to the internally managed stream is returned (ie do not free it!).
◆ RestoreConfiguration() [2/2]
virtual const char* vtkImageCompressor::RestoreConfiguration ( const char *  stream)
Upon success the stream is returned otherwise 0 is returned indicating an error.
◆ SetConfiguration()
virtual void vtkImageCompressor::SetConfiguration ( const char *  )
protectedvirtual
◆ Output
vtkUnsignedCharArray* vtkImageCompressor::Output
Definition at line 110 of file vtkImageCompressor.h.
◆ Input
vtkUnsignedCharArray* vtkImageCompressor::Input
Definition at line 111 of file vtkImageCompressor.h.
◆ LossLessMode
int vtkImageCompressor::LossLessMode
Definition at line 113 of file vtkImageCompressor.h.
◆ Configuration
char* vtkImageCompressor::Configuration
Definition at line 115 of file vtkImageCompressor.h.
