vtkPVCameraKeyFrame Class Reference
#include <vtkPVCameraKeyFrame.h>
Inheritance diagram for vtkPVCameraKeyFrame:
Collaboration diagram for vtkPVCameraKeyFrame:
typedef vtkPVKeyFrame Superclass
- Public Types inherited from vtkPVKeyFrame
void UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) override
 If the vtkPVCameraCueManipulator is in CAMERA mode, then this method is not even called since the interpolation is done by vtkCameraInterpolator maintained by vtkPVCameraCueManipulator itself. More...
void SetKeyValue (unsigned int, double) override
 Get/Set the animated value at this key frame. More...
void SetKeyValue (double) override
virtual double GetKeyValue (unsigned int)
virtual vtkCamera * GetCamera ()
 Get the camera i.e. More...
void SetPosition (double x, double y, double z)
 Methods to set the current camera value. More...
void SetFocalPoint (double x, double y, double z)
void SetViewUp (double x, double y, double z)
void SetViewAngle (double angle)
void SetParallelScale (double scale)
void AddPositionPathPoint (double x, double y, double z)
 Forwarded to vtkCameraInterpolator2. More...
void ClearPositionPath ()
void AddFocalPathPoint (double x, double y, double z)
void ClearFocalPath ()
void SetFocalPointMode (int val)
void SetPositionMode (int val)
void SetClosedFocalPath (bool val)
void SetClosedPositionPath (bool val)
- Public Member Functions inherited from vtkPVKeyFrame
virtual void RemoveAllKeyValues ()
 Removes all key values. More...
virtual void SetKeyTime (double)
 Key time is the time at which this key frame is associated. More...
virtual double GetKeyTime ()
double GetKeyValue ()
double GetKeyValue (unsigned int index)
unsigned int GetNumberOfKeyValues ()
 Set/Get the number of key values this key frame currently stores. More...
virtual void SetNumberOfKeyValues (unsigned int num)
static vtkPVCameraKeyFrame * New ()
static vtkPVCameraKeyFrame * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVKeyFrame
static vtkPVKeyFrame * SafeDownCast (vtkObject *o)
static vtkPVKeyFrame * New ()
 vtkPVCameraKeyFrame ()
 ~vtkPVCameraKeyFrame () override
- Protected Member Functions inherited from vtkPVKeyFrame
 vtkPVKeyFrame ()
 ~vtkPVKeyFrame () override
vtkCamera * Camera
vtkCameraInterpolator2 * Interpolator
- Protected Attributes inherited from vtkPVKeyFrame
double KeyTime
vtkPVKeyFrameInternals * Internals
Special key frame for animating Camera. Unlike typical keyframes, this keyframe interpolates a camera and not a property on the camera.
Definition at line 20 of file vtkPVCameraKeyFrame.h.
Definition at line 24 of file vtkPVCameraKeyFrame.h.
◆ vtkPVCameraKeyFrame()
vtkPVCameraKeyFrame::vtkPVCameraKeyFrame ( )
◆ ~vtkPVCameraKeyFrame()
vtkPVCameraKeyFrame::~vtkPVCameraKeyFrame ( )
static vtkPVCameraKeyFrame* vtkPVCameraKeyFrame::New ( )
virtual const char* vtkPVCameraKeyFrame::GetClassName ( )
Reimplemented from vtkPVKeyFrame.
static int vtkPVCameraKeyFrame::IsTypeOf ( const char *  type)
virtual int vtkPVCameraKeyFrame::IsA ( const char *  type)
static vtkPVCameraKeyFrame* vtkPVCameraKeyFrame::SafeDownCast ( vtkObject *  o)
void vtkPVCameraKeyFrame::PrintSelf ( ostream &  os,
◆ UpdateValue()
void vtkPVCameraKeyFrame::UpdateValue ( double  currenttime,
vtkPVAnimationCue *  cue,
vtkPVKeyFrame *  next
However, in PATH mode, this method is called to allow the key frame to use vtkCameraInterpolator2 to do path-based interpolations for the camera.
◆ SetKeyValue() [1/2]
void vtkPVCameraKeyFrame::SetKeyValue ( unsigned int  index,
double  val
inlineoverridevirtual
Note that is the number of values is adjusted to fit the index specified in SetKeyValue.
Definition at line 37 of file vtkPVCameraKeyFrame.h.
◆ SetKeyValue() [2/2]
void vtkPVCameraKeyFrame::SetKeyValue ( double  val)
Definition at line 38 of file vtkPVCameraKeyFrame.h.
◆ GetKeyValue()
virtual double vtkPVCameraKeyFrame::GetKeyValue ( unsigned int  )
inlinevirtual
Definition at line 39 of file vtkPVCameraKeyFrame.h.
◆ GetCamera()
virtual vtkCamera* vtkPVCameraKeyFrame::GetCamera ( )
Get the camera i.e.
the key value for this key frame.
◆ SetPosition()
void vtkPVCameraKeyFrame::SetPosition ( double  x,
double  y,
double  z
◆ SetFocalPoint()
void vtkPVCameraKeyFrame::SetFocalPoint ( double  x,
double  y,
double  z
◆ SetViewUp()
void vtkPVCameraKeyFrame::SetViewUp ( double  x,
double  y,
double  z
◆ SetViewAngle()
void vtkPVCameraKeyFrame::SetViewAngle ( double  angle)
◆ SetParallelScale()
void vtkPVCameraKeyFrame::SetParallelScale ( double  scale)
◆ AddPositionPathPoint()
void vtkPVCameraKeyFrame::AddPositionPathPoint ( double  x,
double  y,
double  z
◆ ClearPositionPath()
void vtkPVCameraKeyFrame::ClearPositionPath ( )
◆ AddFocalPathPoint()
void vtkPVCameraKeyFrame::AddFocalPathPoint ( double  x,
double  y,
double  z
◆ ClearFocalPath()
void vtkPVCameraKeyFrame::ClearFocalPath ( )
◆ SetFocalPointMode()
void vtkPVCameraKeyFrame::SetFocalPointMode ( int  val)
◆ SetPositionMode()
void vtkPVCameraKeyFrame::SetPositionMode ( int  val)
◆ SetClosedFocalPath()
void vtkPVCameraKeyFrame::SetClosedFocalPath ( bool  val)
◆ SetClosedPositionPath()
void vtkPVCameraKeyFrame::SetClosedPositionPath ( bool  val)
◆ Camera
vtkCamera* vtkPVCameraKeyFrame::Camera
Definition at line 77 of file vtkPVCameraKeyFrame.h.
◆ Interpolator
vtkCameraInterpolator2* vtkPVCameraKeyFrame::Interpolator
Definition at line 78 of file vtkPVCameraKeyFrame.h.
