vtkPVBooleanKeyFrame Class Reference
#include <vtkPVBooleanKeyFrame.h>
Inheritance diagram for vtkPVBooleanKeyFrame:
Collaboration diagram for vtkPVBooleanKeyFrame:
typedef vtkPVKeyFrame Superclass
- Public Types inherited from vtkPVKeyFrame
void UpdateValue (double currenttime, vtkPVAnimationCue *cueProxy, vtkPVKeyFrame *next) override
 This method will do the actual interpolation. More...
- Public Member Functions inherited from vtkPVKeyFrame
virtual void RemoveAllKeyValues ()
 Removes all key values. More...
virtual void SetKeyTime (double)
 Key time is the time at which this key frame is associated. More...
virtual double GetKeyTime ()
virtual void SetKeyValue (double val)
 Get/Set the animated value at this key frame. More...
virtual void SetKeyValue (unsigned int index, double val)
double GetKeyValue ()
double GetKeyValue (unsigned int index)
unsigned int GetNumberOfKeyValues ()
 Set/Get the number of key values this key frame currently stores. More...
virtual void SetNumberOfKeyValues (unsigned int num)
static vtkPVBooleanKeyFrame * SafeDownCast (vtkObject *o)
static vtkPVBooleanKeyFrame * New ()
- Static Public Member Functions inherited from vtkPVKeyFrame
static vtkPVKeyFrame * SafeDownCast (vtkObject *o)
static vtkPVKeyFrame * New ()
 vtkPVBooleanKeyFrame ()
 ~vtkPVBooleanKeyFrame () override
- Protected Member Functions inherited from vtkPVKeyFrame
 vtkPVKeyFrame ()
 ~vtkPVKeyFrame () override
- Protected Attributes inherited from vtkPVKeyFrame
double KeyTime
vtkPVKeyFrameInternals * Internals
Empty key frame. Can be used to toggle boolean properties.
Definition at line 14 of file vtkPVBooleanKeyFrame.h.
Definition at line 17 of file vtkPVBooleanKeyFrame.h.
◆ vtkPVBooleanKeyFrame()
vtkPVBooleanKeyFrame::vtkPVBooleanKeyFrame ( )
◆ ~vtkPVBooleanKeyFrame()
vtkPVBooleanKeyFrame::~vtkPVBooleanKeyFrame ( )
virtual const char* vtkPVBooleanKeyFrame::GetClassName ( )
Reimplemented from vtkPVKeyFrame.
static int vtkPVBooleanKeyFrame::IsTypeOf ( const char *  type)
virtual int vtkPVBooleanKeyFrame::IsA ( const char *  type)
static vtkPVBooleanKeyFrame* vtkPVBooleanKeyFrame::SafeDownCast ( vtkObject *  o)
void vtkPVBooleanKeyFrame::PrintSelf ( ostream &  os,
static vtkPVBooleanKeyFrame* vtkPVBooleanKeyFrame::New ( )
◆ UpdateValue()
void vtkPVBooleanKeyFrame::UpdateValue ( double  currenttime,
vtkPVAnimationCue *  cueProxy,
vtkPVKeyFrame *  next
currenttime is normalized to the time range between this key frame and the next key frame.
