vtkInSituPipelineIO Class Reference
insitu pipeline for IO More...
#include <vtkInSituPipelineIO.h>
Inheritance diagram for vtkInSituPipelineIO:
Collaboration diagram for vtkInSituPipelineIO:
typedef vtkInSituPipeline Superclass
- Public Types inherited from vtkInSituPipeline
virtual std::string GetCurrentFileName (const char *fname, int timestep, double time)
 Helper function to format a filename using current timestep and time. More...
 Get/Set the filename. More...
virtual char * GetFileName ()
virtual void SetChannelName (const char *)
 Get/Set the channel name. More...
virtual char * GetChannelName ()
bool Initialize () override
 vtkInSituPipeline API implementaton More...
bool Execute (int timestep, double time) override
bool Finalize () override
- Public Member Functions inherited from vtkInSituPipeline
 Set/Get the name of the pipeline to be executed. More...
virtual char * GetName ()
static vtkInSituPipelineIO * New ()
static vtkInSituPipelineIO * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkInSituPipeline
static vtkInSituPipeline * SafeDownCast (vtkObject *o)
 vtkInSituPipelineIO ()
 ~vtkInSituPipelineIO () override
- Protected Member Functions inherited from vtkInSituPipeline
 vtkInSituPipeline ()
 ~vtkInSituPipeline () override
- Protected Attributes inherited from vtkInSituPipeline
char * Name
vtkInSituPipelineIO is a hard-coded pipeline that can be used to save out data using writers supported by ParaView.
Definition at line 23 of file vtkInSituPipelineIO.h.
Definition at line 27 of file vtkInSituPipelineIO.h.
◆ vtkInSituPipelineIO()
vtkInSituPipelineIO::vtkInSituPipelineIO ( )
◆ ~vtkInSituPipelineIO()
vtkInSituPipelineIO::~vtkInSituPipelineIO ( )
static vtkInSituPipelineIO* vtkInSituPipelineIO::New ( )
virtual const char* vtkInSituPipelineIO::GetClassName ( )
Reimplemented from vtkInSituPipeline.
static int vtkInSituPipelineIO::IsTypeOf ( const char *  type)
virtual int vtkInSituPipelineIO::IsA ( const char *  type)
static vtkInSituPipelineIO* vtkInSituPipelineIO::SafeDownCast ( vtkObject *  o)
void vtkInSituPipelineIO::PrintSelf ( ostream &  os,
◆ SetFileName()
virtual void vtkInSituPipelineIO::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkInSituPipelineIO::GetFileName ( )
◆ SetChannelName()
virtual void vtkInSituPipelineIO::SetChannelName ( const char *  )
◆ GetChannelName()
virtual char* vtkInSituPipelineIO::GetChannelName ( )
◆ Initialize()
bool vtkInSituPipelineIO::Initialize ( )
◆ Execute()
bool vtkInSituPipelineIO::Execute ( int  timestep,
double  time
Implements vtkInSituPipeline.
◆ Finalize()
bool vtkInSituPipelineIO::Finalize ( )
◆ GetCurrentFileName()
virtual std::string vtkInSituPipelineIO::GetCurrentFileName ( const char *  fname,
int  timestep,
double  time
