vtkHyperTreeGridRepresentation Class Reference
representation for showing vtkHyperTreeGrid as with optimized rendering for 2D datasets. More...
#include <vtkHyperTreeGridRepresentation.h>
Inheritance diagram for vtkHyperTreeGridRepresentation:
Collaboration diagram for vtkHyperTreeGridRepresentation:
enum  RepresentationTypes { WIREFRAME = 1, SURFACE, SURFACE_WITH_EDGES }
enum  DesiredOutputPrecision
void SetVisibility (bool val) override
 Set the visibility for this representation. More...
virtual void SetRepresentation (const char *)
 Overload to set representation type using string. More...
vtkDataObject * GetRenderedDataObject (int port) override
void SetUseOutline (int)
 Use Outline representation is NOT SUPPORTED by this representation. More...
virtual void SetMapScalars (bool val)
 Sets if scalars are mapped through a color-map or are used directly as colors (rgb). More...
virtual void SetStatic (int val)
 Turn on/off flag to control whether the mapper's data is static. More...
virtual void SetSelection (vtkSelection *selection)
 Sets the selection used by the mapper. More...
vtkActor * GetActor ()
 Provides access to the actor used by this representation. More...
const char * GetColorArrayName ()
 Convenience method to get the array name used to scalar color with. More...
virtual void SetShaderReplacements (const char *)
 Specify shader replacements using a Json string. More...
virtual bool GetAdaptiveDecimation ()
 Use adaptive decimation to only render the part inside the camera frustum. More...
virtual void SetAdaptiveDecimation (bool)
virtual void AdaptiveDecimationOn ()
virtual void AdaptiveDecimationOff ()
virtual void SetAmbient (double)
 Set/Get the lighting properties of the object. More...
virtual void SetDiffuse (double)
virtual void SetSpecular (double)
virtual double GetAmbient ()
virtual double GetDiffuse ()
virtual double GetSpecular ()
virtual void SetRepresentation (int)
 Set the representation type: WIREFRAME SURFACE SURFACE_WITH_EDGES. More...
virtual int GetRepresentation ()
virtual void SetAmbientColor (double r, double g, double b)
 Forwarded to vtkProperty. More...
virtual void SetBaseIOR (double val)
virtual void SetBaseColorTexture (vtkTexture *tex)
virtual void SetCoatIOR (double val)
virtual void SetCoatStrength (double val)
virtual void SetCoatRoughness (double val)
virtual void SetCoatColor (double a, double b, double c)
virtual void SetCoatNormalScale (double val)
virtual void SetColor (double r, double g, double b)
virtual void SetDiffuseColor (double r, double g, double b)
virtual void SetEdgeColor (double r, double g, double b)
virtual void SetEdgeTint (double r, double g, double b)
virtual void SetEmissiveFactor (double rval, double gval, double bval)
virtual void SetEmissiveTexture (vtkTexture *tex)
virtual void SetInteractiveSelectionColor (double r, double g, double b)
virtual void SetInterpolation (int val)
virtual void SetLineWidth (double val)
virtual void SetMaterial (std::string name)
virtual void SetMaterialTexture (vtkTexture *tex)
virtual void SetMetallic (double val)
virtual void SetNormalScale (double val)
virtual void SetNormalTexture (vtkTexture *tex)
virtual void SetOcclusionStrength (double val)
virtual void SetOpacity (double val)
virtual void SetPointSize (double val)
virtual void SetRenderLinesAsTubes (bool)
virtual void SetRenderPointsAsSpheres (bool)
virtual void SetRoughness (double val)
virtual void SetSpecularColor (double r, double g, double b)
virtual void SetSpecularPower (double val)
virtual void SetFlipTextures (bool)
 Forwarded to Actor. More...
virtual void SetOrientation (double, double, double)
virtual void SetOrigin (double, double, double)
virtual void SetPickable (int val)
virtual void SetPosition (double, double, double)
virtual void SetScale (double, double, double)
virtual void SetTexture (vtkTexture *)
virtual void SetUserTransform (const double[16])
virtual void SetEnableScaling (int val)
 Forwarded to OSPray (via the Actor) More...
virtual void SetScalingArrayName (const char *val)
virtual void SetScalingFunction (vtkPiecewiseFunction *pwf)
virtual void SetMaterial (const char *val)
virtual void SetLuminosity (double val)
virtual void SetRepeatTextures (bool)
 Forwarded to all textures (and stored for later re-use) More...
virtual bool GetRepeatTextures ()
virtual void SetInterpolateTextures (bool)
virtual bool GetInterpolateTextures ()
virtual void SetUseMipmapTextures (bool)
virtual bool GetUseMipmapTextures ()
virtual void SetInterpolateScalarsBeforeMapping (int val)
 Forwarded to Mapper and LODMapper. More...
virtual void SetLookupTable (vtkScalarsToColors *val)
virtual void SetUseShaderReplacements (bool)
 Specify whether or not to shader replacements string must be used. More...
virtual bool GetUseShaderReplacements ()
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkHyperTreeGridRepresentation * New ()
static vtkHyperTreeGridRepresentation * SafeDownCast (vtkObject *o)
static vtkAlgorithm * New ()
 vtkHyperTreeGridRepresentation ()
 ~vtkHyperTreeGridRepresentation () override
virtual void SetupDefaults ()
 This method is called in the constructor. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
virtual void UpdateColoringParameters ()
 Passes on parameters to vtkProperty and vtkMapper. More...
virtual vtkActor * GetRenderedProp ()
 Used in ConvertSelection to locate the prop used for actual rendering. More...
void UpdateShaderReplacements ()
 Update the mapper with the shader replacement strings if feature is enabled. More...
virtual bool NeedsOrderedCompositing ()
 Returns true if this representation has translucent geometry. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkNew< vtkOpenGLHyperTreeGridMapper > Mapper
bool AdaptiveDecimation = true
vtkNew< vtkPVLODActor > Actor
vtkNew< vtkProperty > Property
int Representation = SURFACE
bool RepeatTextures = false
bool InterpolateTextures = false
bool UseMipmapTextures = false
double Ambient = 0.0
double Specular = 0.0
double Diffuse = 1.0
double VisibleDataBounds [6]
bool UseShaderReplacements = false
std::string ShaderReplacementsString
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkHyperTreeGridRepresentation is a representation for showing HyperTreeGrid. When given a 2D dataset, the new HTG representation uses the specific HTG mapper that benefits from the AdaptiveDecimation filter to only render part that are shown on the camera frustum. This requires the Parallel Profection to be enabled.
This work was supported by CEA/DIF Commissariat a l'Energie Atomique, Centre DAM Ile-De-France, Arpajon, France.
Definition at line 36 of file vtkHyperTreeGridRepresentation.h.
Definition at line 41 of file vtkHyperTreeGridRepresentation.h.
◆ RepresentationTypes
Enumerator
WIREFRAME
SURFACE
SURFACE_WITH_EDGES
Definition at line 88 of file vtkHyperTreeGridRepresentation.h.
◆ vtkHyperTreeGridRepresentation()
vtkHyperTreeGridRepresentation::vtkHyperTreeGridRepresentation ( )
◆ ~vtkHyperTreeGridRepresentation()
vtkHyperTreeGridRepresentation::~vtkHyperTreeGridRepresentation ( )
static vtkHyperTreeGridRepresentation* vtkHyperTreeGridRepresentation::New ( )
virtual const char* vtkHyperTreeGridRepresentation::GetClassName ( )
static int vtkHyperTreeGridRepresentation::IsTypeOf ( const char *  type)
virtual int vtkHyperTreeGridRepresentation::IsA ( const char *  type)
static vtkHyperTreeGridRepresentation* vtkHyperTreeGridRepresentation::SafeDownCast ( vtkObject *  o)
void vtkHyperTreeGridRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkHyperTreeGridRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ SetVisibility()
void vtkHyperTreeGridRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
◆ GetAdaptiveDecimation()
virtual bool vtkHyperTreeGridRepresentation::GetAdaptiveDecimation ( )
Default to false, only works for 2D HTG with parallel projection.
◆ SetAdaptiveDecimation()
virtual void vtkHyperTreeGridRepresentation::SetAdaptiveDecimation ( bool  )
◆ AdaptiveDecimationOn()
virtual void vtkHyperTreeGridRepresentation::AdaptiveDecimationOn ( )
◆ AdaptiveDecimationOff()
virtual void vtkHyperTreeGridRepresentation::AdaptiveDecimationOff ( )
◆ SetAmbient()
virtual void vtkHyperTreeGridRepresentation::SetAmbient ( double  )
vtkHyperTreeGridRepresentation overrides these based of the following conditions:
  • When Representation is wireframe or points, it disables diffuse or specular.
  • When scalar coloring is employed, it disabled specular. Default vaules: Ambient = 0, Specular = 0, Diffuse = 1.
Values are expected to be between 0 and 1.
◆ SetDiffuse()
virtual void vtkHyperTreeGridRepresentation::SetDiffuse ( double  )
◆ SetSpecular()
virtual void vtkHyperTreeGridRepresentation::SetSpecular ( double  )
◆ GetAmbient()
virtual double vtkHyperTreeGridRepresentation::GetAmbient ( )
◆ GetDiffuse()
virtual double vtkHyperTreeGridRepresentation::GetDiffuse ( )
◆ GetSpecular()
virtual double vtkHyperTreeGridRepresentation::GetSpecular ( )
◆ SetRepresentation() [1/2]
virtual void vtkHyperTreeGridRepresentation::SetRepresentation ( int  )
Default is SURFACE.
◆ GetRepresentation()
virtual int vtkHyperTreeGridRepresentation::GetRepresentation ( )
Default is SURFACE.
◆ SetRepresentation() [2/2]
virtual void vtkHyperTreeGridRepresentation::SetRepresentation ( const char *  )
Accepted strings are: "Wireframe", "Surface" and "Surface With Edges".
◆ GetRenderedDataObject()
vtkDataObject* vtkHyperTreeGridRepresentation::GetRenderedDataObject ( int  port)
override
Returns the data object that is rendered from the given input port.
◆ SetUseOutline()
void vtkHyperTreeGridRepresentation::SetUseOutline ( int  )
◆ SetAmbientColor()
virtual void vtkHyperTreeGridRepresentation::SetAmbientColor ( double  r,
double  g,
double  b
◆ SetBaseIOR()
virtual void vtkHyperTreeGridRepresentation::SetBaseIOR ( double  val)
◆ SetBaseColorTexture()
virtual void vtkHyperTreeGridRepresentation::SetBaseColorTexture ( vtkTexture *  tex)
◆ SetCoatIOR()
virtual void vtkHyperTreeGridRepresentation::SetCoatIOR ( double  val)
◆ SetCoatStrength()
virtual void vtkHyperTreeGridRepresentation::SetCoatStrength ( double  val)
◆ SetCoatRoughness()
virtual void vtkHyperTreeGridRepresentation::SetCoatRoughness ( double  val)
◆ SetCoatColor()
virtual void vtkHyperTreeGridRepresentation::SetCoatColor ( double  a,
double  b,
double  c
◆ SetCoatNormalScale()
virtual void vtkHyperTreeGridRepresentation::SetCoatNormalScale ( double  val)
◆ SetColor()
virtual void vtkHyperTreeGridRepresentation::SetColor ( double  r,
double  g,
double  b
◆ SetDiffuseColor()
virtual void vtkHyperTreeGridRepresentation::SetDiffuseColor ( double  r,
double  g,
double  b
◆ SetEdgeColor()
virtual void vtkHyperTreeGridRepresentation::SetEdgeColor ( double  r,
double  g,
double  b
◆ SetEdgeTint()
virtual void vtkHyperTreeGridRepresentation::SetEdgeTint ( double  r,
double  g,
double  b
◆ SetEmissiveFactor()
virtual void vtkHyperTreeGridRepresentation::SetEmissiveFactor ( double  rval,
double  gval,
double  bval
◆ SetEmissiveTexture()
virtual void vtkHyperTreeGridRepresentation::SetEmissiveTexture ( vtkTexture *  tex)
◆ SetInteractiveSelectionColor()
virtual void vtkHyperTreeGridRepresentation::SetInteractiveSelectionColor ( double  r,
double  g,
double  b
◆ SetInterpolation()
virtual void vtkHyperTreeGridRepresentation::SetInterpolation ( int  val)
◆ SetLineWidth()
virtual void vtkHyperTreeGridRepresentation::SetLineWidth ( double  val)
◆ SetMaterial() [1/2]
virtual void vtkHyperTreeGridRepresentation::SetMaterial ( std::string  name)
◆ SetMaterialTexture()
virtual void vtkHyperTreeGridRepresentation::SetMaterialTexture ( vtkTexture *  tex)
◆ SetMetallic()
virtual void vtkHyperTreeGridRepresentation::SetMetallic ( double  val)
◆ SetNormalScale()
virtual void vtkHyperTreeGridRepresentation::SetNormalScale ( double  val)
◆ SetNormalTexture()
virtual void vtkHyperTreeGridRepresentation::SetNormalTexture ( vtkTexture *  tex)
◆ SetOcclusionStrength()
virtual void vtkHyperTreeGridRepresentation::SetOcclusionStrength ( double  val)
◆ SetOpacity()
virtual void vtkHyperTreeGridRepresentation::SetOpacity ( double  val)
◆ SetPointSize()
virtual void vtkHyperTreeGridRepresentation::SetPointSize ( double  val)
◆ SetRenderLinesAsTubes()
virtual void vtkHyperTreeGridRepresentation::SetRenderLinesAsTubes ( bool  )
◆ SetRenderPointsAsSpheres()
virtual void vtkHyperTreeGridRepresentation::SetRenderPointsAsSpheres ( bool  )
◆ SetRoughness()
virtual void vtkHyperTreeGridRepresentation::SetRoughness ( double  val)
◆ SetSpecularColor()
virtual void vtkHyperTreeGridRepresentation::SetSpecularColor ( double  r,
double  g,
double  b
◆ SetSpecularPower()
virtual void vtkHyperTreeGridRepresentation::SetSpecularPower ( double  val)
◆ SetFlipTextures()
virtual void vtkHyperTreeGridRepresentation::SetFlipTextures ( bool  )
Forwarded to Actor.
◆ SetOrientation()
virtual void vtkHyperTreeGridRepresentation::SetOrientation ( double  ,
double  ,
double
Forwarded to Actor.
◆ SetOrigin()
virtual void vtkHyperTreeGridRepresentation::SetOrigin ( double  ,
double  ,
double
Forwarded to Actor.
◆ SetPickable()
virtual void vtkHyperTreeGridRepresentation::SetPickable ( int  val)
Forwarded to Actor.
◆ SetPosition()
virtual void vtkHyperTreeGridRepresentation::SetPosition ( double  ,
double  ,
double
Forwarded to Actor.
◆ SetScale()
virtual void vtkHyperTreeGridRepresentation::SetScale ( double  ,
double  ,
double
Forwarded to Actor.
◆ SetTexture()
virtual void vtkHyperTreeGridRepresentation::SetTexture ( vtkTexture *  )
Forwarded to Actor.
◆ SetUserTransform()
virtual void vtkHyperTreeGridRepresentation::SetUserTransform ( const double  [16])
Forwarded to Actor.
◆ SetEnableScaling()
virtual void vtkHyperTreeGridRepresentation::SetEnableScaling ( int  val)
◆ SetScalingArrayName()
virtual void vtkHyperTreeGridRepresentation::SetScalingArrayName ( const char *  val)
◆ SetScalingFunction()
virtual void vtkHyperTreeGridRepresentation::SetScalingFunction ( vtkPiecewiseFunction *  pwf)
◆ SetMaterial() [2/2]
virtual void vtkHyperTreeGridRepresentation::SetMaterial ( const char *  val)
◆ SetLuminosity()
virtual void vtkHyperTreeGridRepresentation::SetLuminosity ( double  val)
◆ SetRepeatTextures()
virtual void vtkHyperTreeGridRepresentation::SetRepeatTextures ( bool  )
◆ GetRepeatTextures()
virtual bool vtkHyperTreeGridRepresentation::GetRepeatTextures ( )
◆ SetInterpolateTextures()
virtual void vtkHyperTreeGridRepresentation::SetInterpolateTextures ( bool  )
◆ GetInterpolateTextures()
virtual bool vtkHyperTreeGridRepresentation::GetInterpolateTextures ( )
◆ SetUseMipmapTextures()
virtual void vtkHyperTreeGridRepresentation::SetUseMipmapTextures ( bool  )
◆ GetUseMipmapTextures()
virtual bool vtkHyperTreeGridRepresentation::GetUseMipmapTextures ( )
◆ SetInterpolateScalarsBeforeMapping()
virtual void vtkHyperTreeGridRepresentation::SetInterpolateScalarsBeforeMapping ( int  val)
◆ SetLookupTable()
virtual void vtkHyperTreeGridRepresentation::SetLookupTable ( vtkScalarsToColors *  val)
◆ SetMapScalars()
virtual void vtkHyperTreeGridRepresentation::SetMapScalars ( bool  val)
false: maps to VTK_COLOR_MODE_DIRECT_SCALARS true: maps to VTK_COLOR_MODE_MAP_SCALARS
See also
vtkScalarsToColors::MapScalars
◆ SetStatic()
virtual void vtkHyperTreeGridRepresentation::SetStatic ( int  val)
Static data means that the mapper does not propagate updates down the pipeline, greatly decreasing the time it takes to update many mappers. This should only be used if the data never changes.
◆ SetSelection()
virtual void vtkHyperTreeGridRepresentation::SetSelection ( vtkSelection *  selection)
◆ GetActor()
vtkActor* vtkHyperTreeGridRepresentation::GetActor ( )
inline
Definition at line 231 of file vtkHyperTreeGridRepresentation.h.
◆ GetColorArrayName()
const char* vtkHyperTreeGridRepresentation::GetColorArrayName ( )
Can return nullptr if:
  • GetInputArrayInformation returns nullptr, of
  • the Input array information has no FIELD_ASSOCIATION, or
  • the Input array information has no FIELD_NAME.
◆ SetUseShaderReplacements()
virtual void vtkHyperTreeGridRepresentation::SetUseShaderReplacements ( bool  )
◆ GetUseShaderReplacements()
virtual bool vtkHyperTreeGridRepresentation::GetUseShaderReplacements ( )
◆ SetShaderReplacements()
virtual void vtkHyperTreeGridRepresentation::SetShaderReplacements ( const char *  )
Please refer to the XML definition of the property for details about the expected Json string format. Only used if UseShaderReplacements is true.
◆ SetupDefaults()
virtual void vtkHyperTreeGridRepresentation::SetupDefaults ( )
protectedvirtual
If the subclasses override any of the iVar vtkObject's of this class e.g. the Mappers, GeometryFilter etc., they should call this method again in their constructor. It must be totally safe to call this method repeatedly.
◆ FillInputPortInformation()
int vtkHyperTreeGridRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
Fill input port information.
◆ RequestData()
int vtkHyperTreeGridRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
◆ AddToView()
bool vtkHyperTreeGridRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkHyperTreeGridRepresentation::RemoveFromView ( vtkView *  view)
◆ UpdateColoringParameters()
virtual void vtkHyperTreeGridRepresentation::UpdateColoringParameters ( )
protectedvirtual
◆ GetRenderedProp()
virtual vtkActor* vtkHyperTreeGridRepresentation::GetRenderedProp ( )
inlineprotectedvirtual
Definition at line 309 of file vtkHyperTreeGridRepresentation.h.
◆ UpdateShaderReplacements()
void vtkHyperTreeGridRepresentation::UpdateShaderReplacements ( )
◆ NeedsOrderedCompositing()
virtual bool vtkHyperTreeGridRepresentation::NeedsOrderedCompositing ( )
protectedvirtual
Unlike vtkActor::HasTranslucentPolygonalGeometry which cannot be called in Update, this method can be called in Update i.e. before the mapper has all the data to decide if it is doing translucent rendering.
◆ Mapper
vtkNew<vtkOpenGLHyperTreeGridMapper> vtkHyperTreeGridRepresentation::Mapper
Definition at line 329 of file vtkHyperTreeGridRepresentation.h.
bool vtkHyperTreeGridRepresentation::AdaptiveDecimation = true
Definition at line 330 of file vtkHyperTreeGridRepresentation.h.
◆ Actor
vtkNew<vtkPVLODActor> vtkHyperTreeGridRepresentation::Actor
Definition at line 333 of file vtkHyperTreeGridRepresentation.h.
◆ Property
vtkNew<vtkProperty> vtkHyperTreeGridRepresentation::Property
Definition at line 334 of file vtkHyperTreeGridRepresentation.h.
◆ Representation
int vtkHyperTreeGridRepresentation::Representation = SURFACE
Definition at line 336 of file vtkHyperTreeGridRepresentation.h.
◆ RepeatTextures
bool vtkHyperTreeGridRepresentation::RepeatTextures = false
Definition at line 338 of file vtkHyperTreeGridRepresentation.h.
◆ InterpolateTextures
bool vtkHyperTreeGridRepresentation::InterpolateTextures = false
Definition at line 339 of file vtkHyperTreeGridRepresentation.h.
◆ UseMipmapTextures
bool vtkHyperTreeGridRepresentation::UseMipmapTextures = false
Definition at line 340 of file vtkHyperTreeGridRepresentation.h.
◆ Ambient
double vtkHyperTreeGridRepresentation::Ambient = 0.0
Definition at line 341 of file vtkHyperTreeGridRepresentation.h.
◆ Specular
double vtkHyperTreeGridRepresentation::Specular = 0.0
Definition at line 342 of file vtkHyperTreeGridRepresentation.h.
◆ Diffuse
double vtkHyperTreeGridRepresentation::Diffuse = 1.0
Definition at line 343 of file vtkHyperTreeGridRepresentation.h.
◆ VisibleDataBounds
double vtkHyperTreeGridRepresentation::VisibleDataBounds[6]
Definition at line 344 of file vtkHyperTreeGridRepresentation.h.
◆ UseShaderReplacements
bool vtkHyperTreeGridRepresentation::UseShaderReplacements = false
Definition at line 345 of file vtkHyperTreeGridRepresentation.h.
◆ ShaderReplacementsString
std::string vtkHyperTreeGridRepresentation::ShaderReplacementsString
Definition at line 346 of file vtkHyperTreeGridRepresentation.h.
