vtkCPXMLPWriterPipeline Class Reference
#include <vtkCPXMLPWriterPipeline.h>
Inheritance diagram for vtkCPXMLPWriterPipeline:
Collaboration diagram for vtkCPXMLPWriterPipeline:
typedef vtkCPPipeline Superclass
- Public Types inherited from vtkCPPipeline
int RequestDataDescription (vtkCPDataDescription *dataDescription) override
 Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More...
int CoProcess (vtkCPDataDescription *dataDescription) override
 Execute the pipeline. Returns 1 for success and 0 for failure. More...
virtual void SetOutputFrequency (int)
 Set the output frequency for this pipeline. The default is 1. More...
virtual int GetOutputFrequency ()
virtual void SetPaddingAmount (int)
 Set the padding amount for the time index portion of the generated files. More...
virtual int GetPaddingAmount ()
virtual void SetPath (std::string)
 Set the path to the generated files. More...
virtual std::string GetPath ()
- Public Member Functions inherited from vtkCPPipeline
virtual int Finalize ()
 Finalize the pipeline before deleting it. More...
static vtkCPXMLPWriterPipeline * New ()
static vtkCPXMLPWriterPipeline * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPPipeline
static vtkCPPipeline * SafeDownCast (vtkObject *o)
 vtkCPXMLPWriterPipeline ()
 ~vtkCPXMLPWriterPipeline () override
- Protected Member Functions inherited from vtkCPPipeline
 vtkCPPipeline ()
 ~vtkCPPipeline () override
Generic PXML writer pipeline to write out the full Catalyst input datasets. The filename will correspond to the input name/channel identifier with time step and file extension (e.g. "input_0.pvtu" for an unstructured dataset with no padding).
Definition at line 16 of file vtkCPXMLPWriterPipeline.h.
Definition at line 20 of file vtkCPXMLPWriterPipeline.h.
◆ vtkCPXMLPWriterPipeline()
vtkCPXMLPWriterPipeline::vtkCPXMLPWriterPipeline ( )
◆ ~vtkCPXMLPWriterPipeline()
vtkCPXMLPWriterPipeline::~vtkCPXMLPWriterPipeline ( )
static vtkCPXMLPWriterPipeline* vtkCPXMLPWriterPipeline::New ( )
virtual const char* vtkCPXMLPWriterPipeline::GetClassName ( )
Reimplemented from vtkCPPipeline.
static int vtkCPXMLPWriterPipeline::IsTypeOf ( const char *  type)
virtual int vtkCPXMLPWriterPipeline::IsA ( const char *  type)
static vtkCPXMLPWriterPipeline* vtkCPXMLPWriterPipeline::SafeDownCast ( vtkObject *  o)
void vtkCPXMLPWriterPipeline::PrintSelf ( ostream &  os,
◆ RequestDataDescription()
int vtkCPXMLPWriterPipeline::RequestDataDescription ( vtkCPDataDescription *  dataDescription)
If coprocessing does need to be performed this time step it fills in the FieldNames array that the coprocessor requires in order to fulfill all the coprocessing requests for this TimeStep/Time combination.
Implements vtkCPPipeline.
◆ CoProcess()
int vtkCPXMLPWriterPipeline::CoProcess ( vtkCPDataDescription *  dataDescription)
◆ SetOutputFrequency()
virtual void vtkCPXMLPWriterPipeline::SetOutputFrequency ( int  )
◆ GetOutputFrequency()
virtual int vtkCPXMLPWriterPipeline::GetOutputFrequency ( )
◆ SetPaddingAmount()
virtual void vtkCPXMLPWriterPipeline::SetPaddingAmount ( int  )
The default is 0.
◆ GetPaddingAmount()
virtual int vtkCPXMLPWriterPipeline::GetPaddingAmount ( )
◆ SetPath()
virtual void vtkCPXMLPWriterPipeline::SetPath ( std::string  )
◆ GetPath()
virtual std::string vtkCPXMLPWriterPipeline::GetPath ( )
