vtkCPPythonStringPipeline Class Reference
#include <vtkCPPythonStringPipeline.h>
Inheritance diagram for vtkCPPythonStringPipeline:
Collaboration diagram for vtkCPPythonStringPipeline:
typedef vtkCPPythonPipeline Superclass
- Public Types inherited from vtkCPPythonPipeline
typedef vtkCPPipeline Superclass
- Public Types inherited from vtkCPPipeline
int Initialize (const char *pythonString)
 Initialize this pipeline from a given Python string script. More...
int RequestDataDescription (vtkCPDataDescription *dataDescription) override
 Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More...
int CoProcess (vtkCPDataDescription *dataDescription) override
 Execute the pipeline. Returns 1 for success and 0 for failure. More...
int Finalize () override
 Finalize the pipeline before deleting it. More...
static vtkCPPythonStringPipeline * New ()
static vtkCPPythonStringPipeline * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPPythonPipeline
static vtkCPPythonPipeline * SafeDownCast (vtkObject *o)
static int DetectScriptVersion (const char *fname)
 Starting with ParaView 5.9, there are two versions of Python scripts that ParaView supports. More...
static vtkSmartPointer< vtkCPPythonPipeline > CreatePipeline (const char *fname, int default_version=1)
 Detects the script version, if possible and created appropriate subclass. More...
static vtkSmartPointer< vtkCPPythonPipeline > CreateAndInitializePipeline (const char *fname, int default_version=1)
 Same as CreatePipeline, except that if the pipeline instance is successfully created also calls appropriate Initialize method on it. More...
static VTK_NEWINSTANCE vtkCPPythonPipeline * NewPipeline (const char *fname, int default_version=1)
 These overloads are provided for Python wrapping since vtkSmartPointer doesn't seem to be wrapped correctly. More...
static VTK_NEWINSTANCE vtkCPPythonPipeline * NewAndInitializePipeline (const char *fname, int default_version=1)
- Static Public Member Functions inherited from vtkCPPipeline
static vtkCPPipeline * SafeDownCast (vtkObject *o)
 vtkCPPythonStringPipeline ()
 ~vtkCPPythonStringPipeline () override
- Protected Member Functions inherited from vtkCPPythonPipeline
void FixEOL (std::string &)
 For things like programmable filters that have a '
' in their strings, we need to fix them to have \n so that everything works smoothly. More...
std::string GetPythonAddress (void *pointer)
 Return the address of Pointer for the python script. More...
 vtkCPPythonPipeline ()
 ~vtkCPPythonPipeline () override
- Protected Member Functions inherited from vtkCPPipeline
 vtkCPPipeline ()
 ~vtkCPPipeline () override
Class that creates a coprocessing pipeline from a coprocessing string.
Definition at line 15 of file vtkCPPythonStringPipeline.h.
Definition at line 19 of file vtkCPPythonStringPipeline.h.
◆ vtkCPPythonStringPipeline()
vtkCPPythonStringPipeline::vtkCPPythonStringPipeline ( )
◆ ~vtkCPPythonStringPipeline()
vtkCPPythonStringPipeline::~vtkCPPythonStringPipeline ( )
static vtkCPPythonStringPipeline* vtkCPPythonStringPipeline::New ( )
virtual const char* vtkCPPythonStringPipeline::GetClassName ( )
Reimplemented from vtkCPPythonPipeline.
static int vtkCPPythonStringPipeline::IsTypeOf ( const char *  type)
virtual int vtkCPPythonStringPipeline::IsA ( const char *  type)
static vtkCPPythonStringPipeline* vtkCPPythonStringPipeline::SafeDownCast ( vtkObject *  o)
void vtkCPPythonStringPipeline::PrintSelf ( ostream &  os,
◆ Initialize()
int vtkCPPythonStringPipeline::Initialize ( const char *  pythonString)
The string is stored in PythonString. Returns 1 for success and 0 for failure.
◆ RequestDataDescription()
int vtkCPPythonStringPipeline::RequestDataDescription ( vtkCPDataDescription *  dataDescription)
If coprocessing does need to be performed this time step it fills in the FieldNames array that the coprocessor requires in order to fulfill all the coprocessing requests for this TimeStep/Time combination.
Implements vtkCPPipeline.
◆ CoProcess()
int vtkCPPythonStringPipeline::CoProcess ( vtkCPDataDescription *  dataDescription)
◆ Finalize()
int vtkCPPythonStringPipeline::Finalize ( )
A default no-op implementation is given. Returns 1 for success and 0 for failure.
Reimplemented from vtkCPPipeline.
