vtkCPPythonScriptPipeline Class Reference
#include <vtkCPPythonScriptPipeline.h>
Inheritance diagram for vtkCPPythonScriptPipeline:
Collaboration diagram for vtkCPPythonScriptPipeline:
typedef vtkCPPythonPipeline Superclass
- Public Types inherited from vtkCPPythonPipeline
typedef vtkCPPipeline Superclass
- Public Types inherited from vtkCPPipeline
int Initialize (const char *fileName)
 Initialize this pipeline from given the file name of a python script. More...
int RequestDataDescription (vtkCPDataDescription *dataDescription) override
 Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More...
int CoProcess (vtkCPDataDescription *dataDescription) override
 Execute the pipeline. Returns 1 for success and 0 for failure. More...
int Finalize () override
 Finalize the pipeline before deleting it. More...
static vtkCPPythonScriptPipeline * New ()
static vtkCPPythonScriptPipeline * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkCPPythonPipeline
static vtkCPPythonPipeline * SafeDownCast (vtkObject *o)
static int DetectScriptVersion (const char *fname)
 Starting with ParaView 5.9, there are two versions of Python scripts that ParaView supports. More...
static vtkSmartPointer< vtkCPPythonPipeline > CreatePipeline (const char *fname, int default_version=1)
 Detects the script version, if possible and created appropriate subclass. More...
static vtkSmartPointer< vtkCPPythonPipeline > CreateAndInitializePipeline (const char *fname, int default_version=1)
 Same as CreatePipeline, except that if the pipeline instance is successfully created also calls appropriate Initialize method on it. More...
static VTK_NEWINSTANCE vtkCPPythonPipeline * NewPipeline (const char *fname, int default_version=1)
 These overloads are provided for Python wrapping since vtkSmartPointer doesn't seem to be wrapped correctly. More...
static VTK_NEWINSTANCE vtkCPPythonPipeline * NewAndInitializePipeline (const char *fname, int default_version=1)
- Static Public Member Functions inherited from vtkCPPipeline
static vtkCPPipeline * SafeDownCast (vtkObject *o)
 vtkCPPythonScriptPipeline ()
 ~vtkCPPythonScriptPipeline () override
virtual void SetPythonScriptName (const char *)
 Set/get macro functinos for setting PythonScriptName. More...
virtual char * GetPythonScriptName ()
- Protected Member Functions inherited from vtkCPPythonPipeline
void FixEOL (std::string &)
 For things like programmable filters that have a '
' in their strings, we need to fix them to have \n so that everything works smoothly. More...
std::string GetPythonAddress (void *pointer)
 Return the address of Pointer for the python script. More...
 vtkCPPythonPipeline ()
 ~vtkCPPythonPipeline () override
- Protected Member Functions inherited from vtkCPPipeline
 vtkCPPipeline ()
 ~vtkCPPipeline () override
Class that creates a coprocessing pipeline starting from a coprocessing script. This class only does operations with respect to the script and uses the name of the script as the module to hide its definitions from other python modules.
Definition at line 16 of file vtkCPPythonScriptPipeline.h.
Definition at line 20 of file vtkCPPythonScriptPipeline.h.
◆ vtkCPPythonScriptPipeline()
vtkCPPythonScriptPipeline::vtkCPPythonScriptPipeline ( )
◆ ~vtkCPPythonScriptPipeline()
vtkCPPythonScriptPipeline::~vtkCPPythonScriptPipeline ( )
static vtkCPPythonScriptPipeline* vtkCPPythonScriptPipeline::New ( )
virtual const char* vtkCPPythonScriptPipeline::GetClassName ( )
Reimplemented from vtkCPPythonPipeline.
static int vtkCPPythonScriptPipeline::IsTypeOf ( const char *  type)
virtual int vtkCPPythonScriptPipeline::IsA ( const char *  type)
static vtkCPPythonScriptPipeline* vtkCPPythonScriptPipeline::SafeDownCast ( vtkObject *  o)
void vtkCPPythonScriptPipeline::PrintSelf ( ostream &  os,
◆ Initialize()
int vtkCPPythonScriptPipeline::Initialize ( const char *  fileName)
◆ RequestDataDescription()
int vtkCPPythonScriptPipeline::RequestDataDescription ( vtkCPDataDescription *  dataDescription)
If coprocessing does need to be performed this time step it fills in the FieldNames array that the coprocessor requires in order to fulfill all the coprocessing requests for this TimeStep/Time combination.
Implements vtkCPPipeline.
◆ CoProcess()
int vtkCPPythonScriptPipeline::CoProcess ( vtkCPDataDescription *  dataDescription)
◆ Finalize()
int vtkCPPythonScriptPipeline::Finalize ( )
A default no-op implementation is given. Returns 1 for success and 0 for failure.
Reimplemented from vtkCPPipeline.
◆ SetPythonScriptName()
virtual void vtkCPPythonScriptPipeline::SetPythonScriptName ( const char *  )
protectedvirtual
◆ GetPythonScriptName()
virtual char* vtkCPPythonScriptPipeline::GetPythonScriptName ( )
protectedvirtual
