Similar to vtkCPAdaptorAPI provides the implementation for API exposed to typical adaptor, such as C, Fortran, except that is adds the ability to initialize the coprocessor with Python capabilities. More...
#include <vtkCPPythonAdaptorAPI.h>
| typedef vtkCPAdaptorAPI | Superclass |
Public Types inherited from vtkCPAdaptorAPI | |
Public Member Functions inherited from vtkCPAdaptorAPI | |
| vtkCPAdaptorAPI (const vtkCPAdaptorAPI &)=delete | |
| void | operator= (const vtkCPAdaptorAPI &)=delete |
| static vtkCPPythonAdaptorAPI * | SafeDownCast (vtkObject *o) |
| static void | CoProcessorInitialize (const char *pythonFileName) |
| Call at the start of the simulation. More... | |
Static Public Member Functions inherited from vtkCPAdaptorAPI | |
| static vtkCPAdaptorAPI * | SafeDownCast (vtkObject *o) |
| static void | CoProcessorInitialize () |
| call at the start of the simulation More... | |
| static void | CoProcessorFinalize () |
| call at the end of the simulation More... | |
| static void | RequestDataDescription (int *timeStep, double *time, int *coprocessThisTimeStep) |
| this is the function that determines whether or not there is anything to coprocess this time step More... | |
| static void | NeedToCreateGrid (int *needGrid) |
| this function sets needgrid to 1 if it does not have a copy of the grid it sets needgrid to 0 if it does have a copy of the grid but does not check if the grid is modified or needs to be updated More... | |
| static void | CoProcess () |
| do the actual coprocessing. More... | |
| static vtkCPDataDescription * | GetCoProcessorData () |
| provides access to the vtkCPDataDescription instance. More... | |
| static vtkCPProcessor * | GetCoProcessor () |
| provides access to the vtkCPProcessor instance. More... | |
| vtkCPPythonAdaptorAPI () | |
| ~vtkCPPythonAdaptorAPI () override | |
Protected Member Functions inherited from vtkCPAdaptorAPI | |
| vtkCPAdaptorAPI () | |
| ~vtkCPAdaptorAPI () override | |
Static Protected Attributes inherited from vtkCPAdaptorAPI | |
| static vtkCPDataDescription * | CoProcessorData |
| static vtkCPProcessor * | CoProcessor |
| static bool | IsTimeDataSet |
Definition at line 12 of file vtkCPPythonAdaptorAPI.h.
Definition at line 15 of file vtkCPPythonAdaptorAPI.h.
Reimplemented from vtkCPAdaptorAPI.
Users can still call CoProcessorInitialize() without arguments, in which case Python interpretor will not be initialized and hence unavailable.
